Old 07-10-2009, 06:23 AM   #7576
Originally Posted by PartTime View Post
The 8-32 screws in the front end were bent.
My car is not spinning out, the rear tires are spinning when I get on the gas. Like when going threw a switch back I can hear the inside rear tire pick up and spin. The side bite is the same the whole run and really nice, just lacking forward traction.
I have a set of pink rear to try so those are gona be next. Will go from there. Just hate to goto yellow cause of how easy they chunk.
DK
Did you say you are using the thin flex plates? That happens when using them in switch backs. Go to a little stiffer lube in the tubes to settle it down.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-10-2009, 12:46 PM   #7577
My car is RTW, Ready To Win, , ended up mounting.
The only mistake is for the rear shok length, for a 1mm droop i have to go from 76 mm (3.0"), +10 mm as the manual.
Finally in front, i put 3 shims up, for a 0.25mm front droop, i think with 2 is sufficient, but the low spring mount is very near to the tyre, and is proud to touch.
I like very much, the servo mount, the rear motor pods, and the rear diff,axle.
I put 10000wt diff grease, in tubes, and 35wt copper spring in the shock, have good feeling, but i need to test in track.
I run in mod, i go to test, with 5.5T nosram motor, and ISTC speed control, with 4 cell, the Gen-X with this configuration, run very well, i think this car handled well the power.
Greetings, Luis C.
PD: Ysyracing, Hello ĦĦĦ,
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 07-10-2009, 01:11 PM   #7578
Uga
Uga's Avatar
I guess the instructions are still from the old version DB12R, DB12RR has longer shock and the big springs in front.
Jason, any chance of seeing an updated manual for both DB12RR and DB10RR? I am not complaining as I know the car from A to Z, but for starters it really might be a bit frustrating
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 07-10-2009, 03:10 PM   #7579
Originally Posted by chris moore View Post
I would be surprised if anyone has, the car is designed to run the single cell lipo, no t-bar so no need for a split pack. Where are those avalible, I have'nt even seen those before?
Thanks for you reply. The battery of LRP or Nosram, when you use one unit are 3,7v, because it is one element of Lipo. If you use two batteries conected in line are 7,4v.
I am interested in using one unit.
Do you know someone who use it?
Regards,
P.D. The same for you, friend Luic.
ysyracing is offline   Reply With Quote
Old 07-10-2009, 07:57 PM   #7580
Moderator
Clegg's Avatar
So I got my RR-LiPo all setup, lots of weight saving stuff done other than replacing all steel screws with Alloy... I didnt do that due to fragility concerns.
Total weight ready to race with some nearly full size tires, and new body on came to 724gm. Some pics later, but there isnt much weight savings left on the car. I may replace a few screws with an Alloy or Ti, but not much because that few gm of savings isnt worth it. Thats with a relatively heavy Orion Version 2 Vortex 10.5T, fairly heavy Novak GTB 4 cell w/ large cap, and a large Airtronics Rx and a voltage booster.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 07-11-2009, 03:38 AM   #7581
PartTime's Avatar
Why? Legal weight is 730 grams. Im at 723. Only a few grams shy with out watching my weight.
DK
PartTime is offline   Reply With Quote
Old 07-11-2009, 06:46 AM   #7582
My car is a lighter heavy, is 875g, with full size tyres, receiver pack, ISTC with full heatsink, and 4 cells, but the cells are 290g (10.22 oz) , bodyshell include, as the weight of Lipo? , 100-150g ?
Ysyracing, if refer to this:
http://www.nosram.com/en/products/ne...c-74v/details/
Is a sandled pack, divide it and have 2 3.7v batteries, for dimensions are more small, 69x47x23.5mm.
Greetings, Luis C.
Old 07-11-2009, 08:26 AM   #7583
PartTime's Avatar
Greetings, Luis C.
Yes, 4cell brushless should be 900 grams.
Those lipo packs look awsome but...you cant use them. There 2cell 2400 each. 1/12th use 1 cell.
DK
Old 07-11-2009, 08:38 AM   #7584
abailey21's Avatar
Trader Rating: 36 (100%+)
Those cells are also to tall
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-11-2009, 08:39 AM   #7585
Uga
Uga's Avatar
DK
Wrong, those are 2x3.7v packs in series, meaning that splitting the pack you will get two 4800 single cell packs. I guess it works if your club doesn't have any reguations, you won't be able to drive with those packs in ROAR events for sure.
-=Xray XB4=-
-=Xray T4=-
Racing in Latvia
Old 07-11-2009, 08:52 AM   #7586
PartTime's Avatar
If they were two 3.7s wired in series then there wouldnt be a balance port on the case. But there is a balance port on each case so its 7.4 wired in parallel. I didnt think to look at the height. If they are 3.7 each then I dont see why the wouldnt be legal other than the height.
DK
Old 07-11-2009, 09:38 AM   #7587
I think, PartTime is right, i don´t konw sure, but i compare with others brands saddle Lipo packs, 2S2P, and are the same height and weight.
GM 4200 35C, Hiperion HK , Robitronic, Speedpower,...
Greetings, Luis C.
Old 07-11-2009, 09:44 AM   #7588
Khador12's Avatar
The DB12RR lipo was a lot of fun to build. I took my time and cleaned all the exposed edges. I also thought I would put a picture up of how the Fantom Lipo fits.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 07-11-2009, 10:24 AM   #7589
protc3's Avatar
That came out real nice buddy. Thanks for posting pics.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-11-2009, 12:48 PM   #7590
Very nice work Khador12, mine is 4 cell chassis, i have done recently and i have to mount all the electronics and only can me solder wires in motor.
I put a fast ball end in front the shock, with this metod i change or put fast the batteries in a race, is very apreciated, when you head is coming and the battery is just to charge. i respect the total height from original ball.
But i don´t have time to test this week, possible next weekend.
Greetings, Luis C.
BMI's DB12R-p1010105-medium-.jpg   BMI's DB12R-p1010106-medium-.jpg   BMI's DB12R-p1010107-medium-.jpg   BMI's DB12R-p1010108-medium-.jpg
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
