This version of car, run well with 4 cell NiMh ?, or is only for a Lipo batteries.
Here, at moment, nobody run with Lipo, but i think that may soon change that.
I run in asphalt, low grip tracks, i've raced with different chassis for now i run with CRC, some years, and now i thinking in a change, i see this car, an i like the desing, in performance words, think that this car may be equally or more competitive in these conditions?, or is best desing for carpet racing.
Thanks in advance, Luis C.
## NOSRAM##HB TC Blue Edition##BMI DB12RR+##:)
Hey Luis,
We offer the car with either the lipo chassis or the 4 cell chassis. The lipo chassis will allow you to run 4 cell also but does not have the for and aft battery adjustment of the 4 cell chassis. If you wanted to get the standard car and buy the lipo chassis seperate, you would have ultimate adjustability.
Our car excells on all surfaces. We have had alot of success on asphalt of all traction levels and also on carpet of all traction levels. You will really enjoy the car and its ease of adjustablity and also the ease of setup. If you have any more questions please feel free to ask.
Jason Breiner
BMI Racing
www.bmiracing.com
DB12RR lipo edition cars now available
Thanks Jason, for the fast response.
The Ref. number is DB1000, for the 4 cells version of car, isnīt it?.
And when i decide to change from Lipo, i only need to change the chassis, in this version?.
Can i use the stabilizer bar in front, from Carpet Knife, (associated front end), in this car, i always have good feeling with it in my cars, gives steering and smooth front end.
Well finally, , can i use the springs for central shock, from Asso or CRC, are the same diameter, or is diferent.
And, the most important thing, can i pay with Paypal in your shop?.
Greetings, Luis C.
Greetings, Luis C.
The stabilizer bar you refer to is the aluminum brace spanning the front upper arm mounts correct? If so, try the car without it first. You will be pleasantly surprised. The graphite BMI uses seems much stronger than what the other manufacturers use.
Float like an anvil. Sting like a Q-Tip!
Ok, i tested without it, but when i buy the car , thank you very much.
Greetings, Luis C.
Greetings, Luis C.
Hey Luis,
DB1000 is the 4 cell car. You can upgrade to the lipo car with just the chassis plate. The front arm brace for the carpet knife will fit but we normally dont use one. The center shock spring from AE or CRC will work just fine. We do accept paypal payments. Hope this helps.
Jason Breiner
BMI Racing
www.bmiracing.com
The Ref. number is DB1000, for the 4 cells version of car, isnīt it?. And when i decide to change from Lipo, i only need to change the chassis, in this version?.
Do you know you can run 4 cells with the lipo chassis and just lose the ability to move the 4 cells?
Let us know how your testing goes!
Yes, i know, but for now i only run with 4 cells, and i need the option to move the batteries, although almost always take the batteries forward, always run on asphalt tracks, with very different conditions, it is more than a setup.
Now it's time to get accounts, and to convince my wife , this car is necessary for win Nationals, , we will keep you informed.
Thanks, Luis C.
I will be racing my new DB12RR lipo car in a 17.5 class. What would be the best way to get propper rollout for tih class? Would running the tire close to stock be the way to go or true down the tires and gear it to the moon?
The new Parma tires are 1.77in. (45mm) front and 1.85in. (47mm) rear.
Jaco tires are 1.88in. (47.7mm) front and 1.9in. (48.2mm) rear.
X-Factory X-60 Fantom motor and lipo
Hotbodies D4 WCE Fantom motor and lipo
Hotbodies TC Fantom motor and lipo
BMI DB12RR lipo 1/12th Fantom motor and single cell lipo
Khador12,
On carpet, your tires are a bit large try 44.50 on the rear. Give yourself 2mm of set on the fronts (42.50). As for the roll out, it depends on the track length and how technical. On a 110' plus track you can start around 96 +/-. Don't forget to make your set up soft when running Lipo's.....
Ive been cutting them to 1.7 front and 1.8 rear to start. Gives good bite and a pretty good feel. By time they get down to race hight (1.65 front and 1.75 rear) the car is ready to rock.
Anyone got a gearing suggestion for a 10.5 on LiPo? Thanks.
With Sphere TC, over 58 mm, is good point for start, and for SPX 52-54 mm.
The kit go with front suspension spacers, and front upper suspension arm mount (dinamic caster blocks) set ?
What springs are in the kit, 0.20" in front and gold rear?
I need this information, for is not in the kit buy at same time.
I hope help you, Luis C.
Hey Luis,
Our car comes with our new .020 linear front springs and a gold shock spring. The flex plates are the standard thick ones. This is a very good starting point.
Jason Breiner
BMI Racing
www.bmiracing.com
