Old 06-02-2009, 09:33 PM   #7411
EricF's Avatar
Originally Posted by CrashRipRock View Post
Thanks for the info Gadgt..
Ebay auction using your exact verbage, 370199350183, is this you guys? Your not Canadian, your from right here on the West Coast of Fla right?
Can you define the colors listed to the tire performance?
What color = what stickyness?
Thanks Joe
From BMI website-
Black - 40S: Special tire for insane traction carpet tracks. Does not get gummy like Purple. If you don't have insane traction you car will push with these.
Purple - 40S: Good for medium bite conditions in stock racing. This compound is getting popular again because of Jack the Gripper traction compound. With Jack Purples do not get too sticky.
Lilac - 37S: Great front tire for stock carpet or if dbl. pink is too much steering.
Double Pink - 35S: This is the standard front tire for carpet in all classes. Its is used front and rear for 19T and Mod carpet and front and rear in all classes on asphalt.
Grey - 35S: This is a low natural rubber compound. It is just as hard as dbl. pink but it had FAR LESS traction. It is used to free up the rear of stock powered carpet cars for more efficiency and corner speed. This is the old standard rear carpet tire, most stock carpet racers use the softer yellow compound now for more forward grip.
Magenta - 32S: Its softer than dbl pink so if you need more steering than dbl. pink use these up front. If you need more rear traction than dbl. pink use these in the rear.
Pink - 30S: This tire is used in mod 1/12th on carpet and asphalt if the traction is low. If the traction is high it will lock in the rear of the car and make it push.
Yellow - 30S: This is a low natural rubber compound. It is the standard rear tire for Stock racing. It is used to free up the rear of stock powered carpet cars for more efficiency and corner speed.
White - 25S: This is a low natural rubber compound. It was the standard rear tire for 1/10th on road carpet racing. Its a little softer than yellow.
E
EricF is offline   Reply With Quote
Old 06-03-2009, 03:13 PM   #7412
Carpet track has opened near me recently and I was going to try 13.5/1 Cell Lipo. The 4 cell setup below is one I saved from an earlier post. Anyone with 1 cell experience know if it's about the same or needs a tweak or two? Thanks!
Front:
5 degree block w/ 4 degree castor
.020 linear springs and #4 surlube on the kingpins
3.5mm ride height
servo flat w/ medium ballstuds on the steering blocks
Lilac front tires cut to 1.650
.25mm droop
Rear:
Gold center shock spring
Silva shock w/ 60 wt AE oil
Medium ballstud on shock mount
batteries in the middle
#4 surlube in the tubes
Stock flex plates mounted in short position
no tweak screws
Yellow rear tires cut to 1.750
172mm rear width
1mm pod droop
Pod Level at ride height
3.5mm ride height
LAGuy is offline   Reply With Quote
Old 06-03-2009, 04:35 PM   #7413
chris moore's Avatar
Trader Rating: 87 (99%+)
That may work depending on the tacktion level, but I'd suggest softer on the lube and center shock.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 06-03-2009, 05:07 PM   #7414
Trader Rating: 16 (94%+)
I would change to Double Pink front tires, #3 Sure Lube for the Tubes and Kingpin's, and 35-40wt oil in the shock, with a blue or gold center spring depending on overall traction.
With the LiPo, you are losing a lot of weight on the front tires, and with the 13.5T motor, you will need some extra grip. We have been running Double Pink fronts and have only been experiencing about .5mm wear from 4-heats of racing.
KSN
kn7671 is offline   Reply With Quote
Old 06-04-2009, 01:36 AM   #7415
Thanks Guys! I am running a 10lb center/40 weight and XX Pinks all around right now in 4 cell/17.5. I'll keep it soft and go lighter and faster with the 13.5/1 cell lipo.
Old 06-04-2009, 01:09 PM   #7416
Am I reading right? No LHS support for parts?
The tire hubs, do you need specific rims to work? Can these be purchased at LHS?
Probably newb questions but I simply dont know.
Thanks......
CrashRipRock is offline   Reply With Quote
Old 06-04-2009, 01:35 PM   #7417
Thanks......
Well unless your running AE or have a large 1/12 class mail order is going to be your friend. Because 1/12 is a small class at many local levels most shops only carry what is easy to get from distributiors like Horizon. If you have a large enough group running the same car then your lhs may help out and stock the parts.
The good news is that Jasons product is really bullit proof, unless you hit everything in sight you will get by with very few spares. As the frontend is AE those parts you should be able to get local, past that you need some spare side links and rear pivots, simple list.
As for tires if there is an ongoing 1/12 class at your track the lhs should have tires in stock that are the most popular for that surface. I run the Jaco prizms and BSR brand tires most but have tried some other brands too.
Sponsered by:
Old 06-05-2009, 03:26 PM   #7418
protc3's Avatar
We have as good of LHS support as any 1/12th manufacturer. If the track run them and supply 1/12th parts, you will usually find our parts there. We also sell off of our website and through other online shops as well
Sorry for the big delay in the 1S lipo chassis pics guys. I got the flu this week and will be back at it now and will have pics up beginning of the week. The chassis are going to be available in 2 weeks. We are also going to offer the DB12RR as a 4 cell or 1S lipo car for those who want to buy the car and also offer the DB12RR conversion as a 4 cell or 1S lipo option. There will be no price differences in the chassis plates,kits or conversions. The option of which you would rather have when purchasing will be the only difference. Thanks for looking guys
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-05-2009, 05:25 PM   #7419
mike ivy's Avatar
Trader Rating: 50 (100%+)
NIIIIIIIICCCCCCCEEEEEEEE!!!!!! Cant wait to get one.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 06-05-2009, 06:51 PM   #7420
abailey21's Avatar
Trader Rating: 36 (100%+)
Excuses excuses!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 06-06-2009, 06:59 AM   #7421
protc3's Avatar
Hey guys,
I looked into the rear flex plate pivot housings and didnt find anything unusual about them. They are the same as they have always been and seem to be the same strength as our origionals. However, i will increase the wall thickness around the pivot balls being that there are some of you that are having problems with breakage. I will be making the new ones as of monday and will throw away the inventory i have now. The center pivot will not go through any changes as we found by strengthening it moved the breaking point to more expensive areas of the car. The rear pod took too much abuse when i beefed up the center pivot.
I will also be putting together a new monthly incentive deal for the month of june and will announce it on monday. This will be to help everyone get ready for the up and coming carpet season. Have a great weekend guys.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-06-2009, 03:58 PM   #7422
EricF's Avatar
Jason,
Are you making an 1s lipo chassis for the wgt as well?
Thanks,
Eric
Old 06-06-2009, 04:36 PM   #7423
protc3's Avatar
The WGT car will not need a new chassis. It will be getting a locator plate as we found the car to work really well with the !s lipo as is.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-09-2009, 07:56 AM   #7424
avs
avs's Avatar
a carpet track just opened this month in my area and am trying various tuning suggestions for carpet.
i recall a suggestion (by Jason i think) to run the servo flat and fwd with the ballstuds between the horn and servo. (the search engine seems fouled up lately and i can't find the post)
anyways, when i try to use this position the servo body interferes with the front arm. i am using a 9650.
also to manage bump steer with this setup, you use the medium ballstud. (the kit supplied ballstud for the front shock mount?)
that is so tall, has anybody tried inverting the steering arms?
thanks for any suggestions.
avs is offline   Reply With Quote
Old 06-09-2009, 12:21 PM   #7425
protc3's Avatar
That is correct. I dont use bottom screws for the servo. I only use the top mounting holes.
I never did flip the steering blocks as i just used the medium ballstuds. You can try it and see how it goes. Keep me posted.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
