Old 03-17-2009, 03:40 AM   #7201
Originally Posted by Johnny Carey View Post
So who all will be at the Nats?
Mike Sr.
Larry F.
Greg D.
Steve W.
There has to be others
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 03-17-2009, 04:31 AM   #7202
3rd-dan's Avatar
Thanks Gadge,
now i see the difference.
3rd-dan is offline   Reply With Quote
Old 03-18-2009, 04:51 PM   #7203
Trader Rating: 8 (90%+)
Track looks good and tight. Cant wait to get on it.
Johnny Carey is online now   Reply With Quote
Old 03-20-2009, 05:53 AM   #7204
protc3's Avatar
Good luck to all of you guys going to the nats.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-20-2009, 06:37 AM   #7205
CFR
CFR's Avatar
can the xray front end be fitted to the RR chassis?
CFR is offline   Reply With Quote
Old 03-20-2009, 03:09 PM   #7206
protc3's Avatar
I am not really sure. I havent seen the xray front end in person yet.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-20-2009, 03:21 PM   #7207
I believe the Xray uses a smaller metric screw to bolt on much like the Hot Bodies car.
Old 03-22-2009, 09:54 AM   #7208
3rd-dan's Avatar
Hi,
is that right that the 12RR comes without a thrust bearing and washers?
Old 03-22-2009, 12:01 PM   #7209
protc3's Avatar
We do not use (or supply) a thrust bearing with the car. A thrust bearing hinders the diff action on the car due to the excess drag.(Thrust balls are sandwiched between washers which= drag). With using the flanged bearing as the thrust, there is almost zero side load as it uses the inner race to rest against and doesnt restrict rotation as it is tightened. The thrust bearings are great for use in club racing where you dont want to change the flanged bearing after a big hit. The thrust will increase time between rebuilds but when it comes to performance of the diff, the thrust bearing does hurt performance against a flanged bearing. This is why it is left to the consumer to make the decision if they want to use one. Hope that helps buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-23-2009, 10:42 AM   #7210
protc3's Avatar
Hey guys,
I am releasing new optional shock pistons for the silva shock. There will be a 2 and 3 hole piston in the kit that have holes that are .005 smaller than the stock piston. The piston edges are radiused for a super smooth feel. They will be sold as a pair and will sell for $7.99 a pair. I will have them up on the website tommorow.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-23-2009, 10:50 AM   #7211
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Really....
hmmmm
never thought about it that way.
I think the only pan car that uses one is the F103.
Now I'm thinkin' 'bout that too!
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 03-23-2009, 11:03 AM   #7212
wingracer's Avatar
Trader Rating: 23 (100%+)
Back in my 1/10th oval days we used an AE thrust bearing that road on the outer race of the ball bearing itself so there was no drag from the washer rubbing the bearing. This resulted in the smoothest and most free diffs I have ever seen. Unfortunately this set-up is too big to fit in a 1/12th wheel. I'm not sure if anyone makes a similar set-up that will.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-23-2009, 11:13 AM   #7213
protc3's Avatar
Where the resistance comes from is the direction of the load placed on the balls. Thrusts have the balls sandwiched between the 2 washers and therefor has more resistance than on that has none. The thrust can handle a ton more side load being that its intended perpose is to withstand heavy side load. Unfortunately, the flimsy flanged bearings we use now yield much better results in performance due to the lack of resistance. Right now we are only working against 1 set of sandwiched balls in the diff. Adding a thrust just adds more. That being said, a diff with a thrust bearing is very smooth. It just has more resistance during operation. I fully reccomend running a thrust for lack of maintenece and also durabilty purposes. For ultimate performance, i stick with the flanged bearing.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-23-2009, 12:37 PM   #7214
In the UK alot of us are running the thrust race from the corally SP12x you need to make up a spaces about 2mm to stop the nut hittind the carbon part of the axle makes for a really smooth low maintenance diff and seems to be better than the slapmaster one.
Jason
jasonb is offline   Reply With Quote
Old 03-23-2009, 01:02 PM   #7215
Moderator
Clegg's Avatar
From my experience - Note: I am not where near good enough to be able to tell the minute performance 'gains' from not running a thrust bearing - Running the thrust bearing offers more consistent performance. As Jason says one good hit and you've just toasted a normal flanged bearing. I've had issues in the past - pre thrust bearing - where I had a solid shunt and the rest of the day the car drove very weird. With the thrust bearing I find the back end to be very consistent no matter what happens.
If you are the kind of driver who never touches wood or PVC... then maybe you'd benifit, but either way I dont notice any additional drag from a thrust bearing if the bearings are lubed with Moly and kept clean.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
