Old 03-15-2009, 08:21 AM   #7186
wingracer's Avatar
Trader Rating: 23 (100%+)
Doesn't the CRC pro-strut front end use larger axles? If so, the front bearings will be different on the CRC.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-15-2009, 08:23 AM   #7187
Regional Moderator
CarbonJoe's Avatar
Originally Posted by SpraydbySprague View Post
Yes the bearings are the same size for the rear axle and the front wheels on the GenX and DB12RR.
The standard front bearings on the Gen X are 3/16" x 5/16", the DB12RR (standard Associated front end) are 1/8" x 5/16". The Gen X has a 3/16" axle, the DB12RR has a 1/8" axle.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-15-2009, 08:42 AM   #7188
3rd-dan's Avatar
Thanks guys for the answers.
As far as i can, i will order one of those carpet ripper machines.
Do you know some shops that deliver to germany?
My buddy has a hatzenbach a12 there will only fit a kimbrough spur gear.
Which one will fit the DB?
Can i use all aftermarket spurs?
3rd-dan is offline   Reply With Quote
Old 03-15-2009, 08:44 AM   #7189
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I totally forgot CRC went to a 3/16 front axle!
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 03-15-2009, 08:47 AM   #7190
Regional Moderator
CarbonJoe's Avatar
I've used Kimbrough before, but now all I use are RW spurs (for 17.5 brushless, I use a 78 tooth RW spur... some guys use 76 or 74 tooth spurs in order to get the right rollout). PRS spurs will also work. The DB12RR uses a standard IRS rear axle.
Old 03-15-2009, 08:48 AM   #7191
You can use 64p spur gears from Kimbrough, RW racing, Corally(DuMor), PRS, and Hot Bodies. If you plan on running 17.5 brushless, PRS and RW racing make some of the smaller spur sizes popular with that class.
Three words...
Old 03-15-2009, 09:08 AM   #7192
3rd-dan's Avatar
Hi,
i plan to run a 9,5T Motor in our logal race series called cs cup.
I will not run a mod or std motor.
Ive seen on the bmi web shop a 58T spur gear.
Is that also ok?
Our Roll-out ist about 46 to 51mm.
Is that correct that the assembly manual has only 10 pages?
Its a litle less or not?
I like step by step manuals with many pics
Old 03-15-2009, 02:40 PM   #7193
Hi,
Is that also ok?
The 58T spur gear BMI sells is a 48P gear, it is almost the same diameter as the 78T 64P gear BMI sells. You may wish to start with the kit supplied 88t 64P gear when running the 9.5 motor.
The assembly manual is great. Step by step instructions. Clear black and white photos with well written text to help you assemble the car. If you ever have any questions when building the car do not hesitate to hop on line here and ask. Jason and his customers are always willing to help.
Three words...
Old 03-15-2009, 03:11 PM   #7194
V12
V12's Avatar
AMC in the UK is a shop in Europe and sells to Germany. Thats where I bought my DB12RR also. I dont know if there are other shops in Europe but you could order from Jason directly also. I just went with AMC as there was very little time left before the race where I wanted using the BMI. I think ordering from the USA the kit had arrived after that race.
Im not sure why the Hatzenbach car could use Kimborough only as the rear axle is the same as any other car. Im running Kimborough and Xenon gears with my DB12RR. BTW the room in the powerpod on the DB12RR is incredible large. So you could use a much larger range on pinions than in any other car but also its much easier working on the motor (installing) also very easy access for installing/removing the sensorwire connector.
Im also running a 9.5T motor and a 88T/64DP spur is the perfect choice for that rollout. Thats what Im using as most other guys.
V12 is offline   Reply With Quote
Old 03-15-2009, 03:24 PM   #7195
V12
V12's Avatar
Today I have had very bad luck at the race. Before I had some major crashes were the car survived without any broken parts but today another car hit the rear of my BMI at full speed. No broken graphite parts and no broken rear axle, but all of the 3 pivot ball housings and the front ballstud from the centershock were broken what meant end of race for me as I had no spare pivot ball housings. Well this really was a hard crash and any other car maybe had damaged more than this.
Old 03-15-2009, 04:12 PM   #7196
Originally Posted by GLITTER LIDZ View Post
your paint job is very much like the DB12R, simple, effective, and just plain works, gotta love em both.
Thanks!
jawa is offline   Reply With Quote
Old 03-16-2009, 11:01 AM   #7197
3rd-dan's Avatar
Hi,
thanks to all for answering.
I made my choice and i will order the 12RR.
I hope for the future if i have some trouble with the car you can help me too.
So im looking forward to this car.
BTW is a 64dp Spur and pinion better, because i raced always with 48dp spurs and pinions.
Do i have a better range for roll-out with 64dp?
Old 03-16-2009, 01:58 PM   #7198
EricF's Avatar
Hi,
Yes, with 64p you have a better range in the sence that the ratio change is made in smaller increments.
E
EricF is offline   Reply With Quote
Old 03-16-2009, 03:14 PM   #7199
Trader Rating: 8 (90%+)
So who all will be at the Nats?
Johnny Carey is offline   Reply With Quote
Old 03-16-2009, 04:12 PM   #7200
Hi,
Maybe this will help show the difference between 48 and 64 pitch. The following calculation is done in mm. Here you can compare the difference that reducing the ratio by 1 tooth on the pinion in both 48 and 64 pitch.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
