Old 03-08-2009, 08:25 PM   #7171
MaxSp97's Avatar
Thanks Jason for the GREAT PRODUCT
I sold the 12R5 and got the DB12RR and it's the RIGHT choice.
The DB12RR is first time on the track "No practice" qualified 2 and finished 3.
The kit set up and Jason suggested the car is SOOOO easy to drive.
The car is enjoyable to drive but my driving skill is not...
I geared for SP17.5 with 55/88 the motor was a little warm and I ran out of pinions.
Calvin,
MaxSp97 is offline   Reply With Quote
Old 03-09-2009, 06:14 AM   #7172
protc3's Avatar
Calvin,
Thanks buddy. Im glad you like the car. Thanks for the kind words
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-09-2009, 03:25 PM   #7173
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Jason YGPM.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 03-11-2009, 03:07 PM   #7174
Default DB12R with A123
Here is my new DB12R which I wanted to use with A123 batteries (6.6V 2x1100 mah 2S2P configuration). It was not easy to place everything but I managed to make it fit. After several trial runs, I am very pleased with the driving and the handling of the car on asphalt. Thanks to Jason for his advices on setup.
jawa is offline   Reply With Quote
Old 03-13-2009, 06:15 AM   #7175
protc3's Avatar
Thats pretty cool buddy. Its nice to see people trying new things.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-13-2009, 06:49 AM   #7176
vctr1's Avatar
Trader Rating: 14 (100%+)
Default re: BMI12RR
Jason,
whats the difference between the 12R and the 12RR...
VSpeed Racing / FG SUPPLY
www.vspeedracing.com
www.fgsupply.com
www.vsmodelsport.com
vctr1 is offline   Reply With Quote
Old 03-13-2009, 08:40 AM   #7177
protc3's Avatar
The differences are that the 12RR has a wider pod to center the brushless motors and also allows for taller gearing,Shock location is changes and front to rear weight bias is also shifted forward a little, The flex plates now have a long and a short fixed mounting position to allow for more adjustment, We slotted the servo holes to now be able to fit any mini servo available, and the damper tubes are a little shorter.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-13-2009, 11:33 AM   #7178
Cool
Hey all, these changes may seem small, but they made a huge difference on the car. The R was already a great car, but the RR took another second off my lap times and has stabilized the overall consistency
PHI/BMI racer is offline   Reply With Quote
Old 03-13-2009, 11:50 AM   #7179
Originally Posted by Clegg View Post
so a friend and I both run DB12RR's and have had the same failure of the front shock mount ball stud. When using the long alloy stud, we have found they tweak or snap in collisions. Now I know we shouldnt hit stuff... but it happens.
Both of us recently have fallen out of mains and qualifiers from failure of that front ball. Now we know this is a legacy associated bit from the 12L3 series of cars, so its not a BMI design failure.
This usually happens when using the O Ring to hold the batteries in. When you hit something, the cells move forward, hit the shock (hard!) which either breaks the ball stud, or the shock cap.
What you have done is moved the shock well out of the way, but I find that making the front of the shock higher makes the car turn in less. If you use tape to hold the cells in, then the problem doesn't happen, and you get the sharp handling back again. HTH
SlowerOne is offline   Reply With Quote
Old 03-13-2009, 12:05 PM   #7180
Not entirly true auntie Pete
If you have a fully comitted accident you can bend the ballstud (even the medium one) I have bent a couple recently with the cells taped in mainly when you clip the inside track marker in a high speed corner then hit the outside one backwards
See you in the morning.
Jason
jasonb is offline   Reply With Quote
Old 03-13-2009, 12:18 PM   #7181
1rcracer's Avatar
Talking
Hey team driver!!!
Now u gotta drive that car faster.... u know the pre-nats dont mean anything... Lets see at the Nats....
Keep the peace!!
and leave the neighbour alone!!!
hehehehe
___________________________________
Team Novice!!
TEAM CORALLY RDX Φ - ZA
1rcracer is offline   Reply With Quote
Old 03-13-2009, 12:40 PM   #7182
Originally Posted by 1rcracer View Post
Hey team driver!!!
Keep the peace!!
hehehehe
Yeah, you cant corner cut the horse shoe at nats...
Dartanian is offline   Reply With Quote
Old 03-14-2009, 07:16 PM   #7183
GLITTER LIDZ's Avatar
your paint job is very much like the DB12R, simple, effective, and just plain works, gotta love em both.
Ken Miller...Team CFX...T2C X-Treme RC Products...RC Driver Magazine
Jack Smiths Sandwich Shops...."They're Stacked"
1NUTZRacing "what in the hell do we need 2 for!?"lol
I played to rough with my "WOODY" and it broke!
GLITTER LIDZ is offline   Reply With Quote
Old 03-15-2009, 04:29 AM   #7184
3rd-dan's Avatar
Hi guys,
got some questions.
Perhaps they answered few sites before but i donīt wanted to read 240 pages.
So here they are.
Are the Bearings in the car similar to the CRC Generation X ?
Can i mount the alloy upper arm mounts, 1/12 Front End Pro-Brace and spacers for the rear axle for shiming out from crc?
Wich parts should i buy with my car, break easily?
I saw the db12r live at a local race driven by a good friend of mine.
Looks very good.
I stopped racing 1 year ago but now i want to race again.
And this car ( db12rr ) is my fav to buy.
I had the SP12X by corally but i wasnt as fast as with my old G3.
Hope to get some answers.
3rd-dan is offline   Reply With Quote
Old 03-15-2009, 08:17 AM   #7185
Originally Posted by 3rd-dan View Post
Hi guys,
Yes the bearings are the same size for the rear axle and the front wheels on the GenX and DB12RR.
You can use the alloy upper arm mounts and brace, but they are not necessary at all. Just run the front end with the box stock parts.
If you are talking about the 1/4" i.d. shims CRC sells for the rear axle, yes they will work. I use the machined aluminum spacers BMI makes for the rear axle. Part #DB4050. Makes centering the axle so much easier.
As far as spares pick up some; lower front arms, 8-32 aluminum screws for the front arms, flex plates, a spare center pivot, brass king pin shims and nylon castor shims (in case you drop one of the little buggers ), front foam bumpers (from BMI, not Parma), some body posts, maybe some optional front end springs (get the linear front springs, very nice). Oh yea, pick up a package of DB4017, it's the little screw for the left clamp hub. The screw is an odd size, and if you ever need to replace it, they are nice to have on hand.
Here's a few optional parts you may want to consider later. DB5314, DB5315, and DB4316. These are the alloy ride height adjusters for the front end, very nice. DB5305 is a cool looking carbon fiber servo saver brace. I haven't broken a servo saver in years, but it's carbon fiber, so it's cool! . Of course don't forget the ultimate performance enhancing device, a BMI t shirt!
The car is quite durable, I still have the original front arms from the beginning of the season. The trick is to pre tap the mounting screw holes with an 8-32 tap. This will prevent the screw holes in the lower arms from stretching and possibly cracking.
At my local track. I've broken a couple of flex plates, and worn out some front bumpers and body posts. But that's about it. Hope this helps.
I made the jump from the SP12X to the BMI DB12RR and I'm never looking back! You will be quite pleased with the car and the company.
Three words...
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
