Old 03-06-2009, 08:51 PM   #7156
Moderator
Clegg's Avatar
Originally Posted by InspGadgt View Post
Also you can just swap it out with the long Corally ball stud which is steel
my hobby shop didnt know of any steel stud that was tall enough.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 03-07-2009, 01:28 AM   #7157
V12
V12's Avatar
It seems to me the long alloy ball stud was replaced with a medium ball stud in the latest kit. At least in my DB12RR kit what I just bought 2 weeks ago there was a medium size in the kit.
In my first race last weekend I had two heavy crashes at fullspeed on the long mainstraight and there was absolutely nothing broken or twisted on the car beside one of the GRP wheels.
V12 is offline   Reply With Quote
Old 03-07-2009, 05:53 AM   #7158
Default Corally long ball stud
InspGadgt do you know the part number of the Corally long ball stud?
scalematters is offline   Reply With Quote
Old 03-07-2009, 06:35 AM   #7159
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by Clegg View Post
so a friend and I both run DB12RR's and have had the same failure of the front shock mount ball stud. When using the long alloy stud, we have found they tweak or snap in collisions. Now I know we shouldnt hit stuff... but it happens.
Both of us recently have fallen out of mains and qualifiers from failure of that front ball. Now we know this is a legacy associated bit from the 12L3 series of cars, so its not a BMI design failure. But I went and found a solid solution.
After seeing the new 12R5 center shock mount position and then looking at the 1/10th offerings out there, I picked up a Darkside Motorsports Adjustible center shock mount (#140). I rocks. In the same position as the AE mount it takes a lil more distance on the shock to give the same geometry, but overall its perfect. I used a small Ti ball stud in it and its rock solid. It has a pre threaded delrin base that fits fine.
Its probably a few gm's heavier than the AE setup, but I have no fear of busting those long ball studs anymore. And it complements the cars looks rather nicely.
I did also... somehow... bust the Silvia shock cap. I snapped the threaded portion right off. so I put an aluminum 4x40 scew through the hole with a small Oring on it, and a thin nut on the other side, and its good as new and longer which works for the darkside setup.
hey clegg thats a sweet shock mount im gonna have to pick one of them up. the long irs ball stud always snaps and the corally is like 9 bucks and its metric so you need a different ball cup. thats why we run a medium height ball stud with 2mm spacers under the stock mount. same height as long ball stud without the snappage hey jason looks like you need to make an adjustable mount now buddy
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 03-07-2009, 06:37 AM   #7160
Trader Rating: 22 (100%+)
I have the older DB12. The problem I am having is upon acceleration it pulls to the left. I can't get it corrected. I am using the damper disk, and .20 springs. Bearings seems fine. Are there any obvious things to look for I am missing?
ghj1997 is offline   Reply With Quote
Old 03-07-2009, 08:09 AM   #7161
chris moore's Avatar
Trader Rating: 85 (99%+)
Originally Posted by terryh View Post
Off the start line my car pulls to the left, I have also noticed that the steering blocks are getting a little loose on the kingpin so there's a bit of play, could this be the problem?
The car is fine once it's rolling, any idea's??
Originally Posted by PHI/BMI racer View Post
Hey,
check front tire diameter is the same both sided, also for rear. If the camber is different left to right the car will pull a bit to one side. Also check ride height left to right and make sure its the same. Also under low traction conditions if the diff is too tight the back end will lose traction and swing out.
Good luck
Originally Posted by protc3 View Post
Also make sure your axle is centered properly. It needs to be centered almost perfect. If you face the shorter boss on the clamping hub towards the bearing in the pod plate, you will need 3mm of shims per side and you will be at 172 mm and perfectly centered. This is with the offset of jaco and the new parma black wheel.
All covered at the top of this page One additional thing is to check that the front springs are the same height
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-07-2009, 08:28 AM   #7162
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Also please note that both jiggly bits are deflecting at a 45 degree angle which means that those are real. But yet animated.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 03-07-2009, 10:50 AM   #7163
The threads are metric but the ball fits well in the standard rod end.
I also saw guys use the older style AE/CRC mount, which is higer, with a shorter ball stud then use spacers underneath the shock mount to raise it.
Old 03-07-2009, 12:03 PM   #7164
Moderator
Clegg's Avatar
I snagged it from RC4Less when I ordered some ceramic bearings. I think this is a great purchase. I can change the shock angle now pretty easily. And because its arc'd you dont need to reset your shock length as you move it up and down in the mount.
and it just looks bad ass
Old 03-07-2009, 02:08 PM   #7165
definitely a cool mount...I was looking at the aluminum one from CRC because it has a clamp for the roll over antenna but would have to space the heck out of it as it is super low.
Old 03-08-2009, 12:06 AM   #7166
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Someone has been watching Manswers on Spike TV!
Anyhoo. Had another good night with the DB12RR. Unfortunately I had a bad solder connection do me in during the main. Here's a question for everyone. How often do you reapply lube to the kingpins and damper tubes? I do them once a week.
Jason,
Wanted you to know the pink tires in the rear are holding up great. No where close to the amount of tire wear I had with the yellow tires.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 03-08-2009, 01:41 AM   #7167
Hi guis I just assembly my DB12RR and in the step5 I have stack because the upper suspension hinge pin it's very dificult to pass throu to the oter side of the reactive caster block.
Any ideas or tips?
drover is offline   Reply With Quote
Old 03-08-2009, 06:38 AM   #7168
protc3's Avatar
The hinge pin is supposed to be tight in the caster block. You only want it to be free in the arm. If it fits loosely through both the arm and caster block it will make the assembly sloppy. Remember that only the arm pivots on the pin.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-08-2009, 11:02 AM   #7169
Thanks Jason
Old 03-08-2009, 01:20 PM   #7170
Jason YGPM.
Three words...
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
