Old 03-02-2009, 04:15 AM   #7141
protc3's Avatar
Thanks buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-02-2009, 01:28 PM   #7142
terryh's Avatar
Off the start line my car pulls to the left, I have also noticed that the steering blocks are getting a little loose on the kingpin so there's a bit of play, could this be the problem?
The car is fine once it's rolling, any idea's??
terryh is offline   Reply With Quote
Old 03-02-2009, 04:24 PM   #7143
Hey,
check front tire diameter is the same both sided, also for rear. If the camber is different left to right the car will pull a bit to one side. Also check ride height left to right and make sure its the same. Also under low traction conditions if the diff is too tight the back end will lose traction and swing out.
Good luck
PHI/BMI racer is offline   Reply With Quote
Old 03-02-2009, 04:34 PM   #7144
protc3's Avatar
Also make sure your axle is centered properly. It needs to be centered almost perfect. If you face the shorter boss on the clamping hub towards the bearing in the pod plate, you will need 3mm of shims per side and you will be at 172 mm and perfectly centered. This is with the offset of jaco and the new parma black wheel.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-02-2009, 07:25 PM   #7145
Moderator
Clegg's Avatar
So Jason. In the DB12RR kit it comes with 3 lil brass washers to space out the rear axel. But your site sells the machined 3mm spacers. the 3 brass washers are about 1.5mm thick total (I dont have em with me). So does this mean that the kit as-is is too narrow on the back end?
I noticed when I had the 3mm spacers put in the rear wheels were stickin out from the body a bit so I went back to the 3 brass spacers.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 03-02-2009, 09:05 PM   #7146
The 3mm spacers bring the back out to 172mm when using the Jaco or the black Parma wheels. Other brand wheels have different off-sets so you need the shims to space it instead. Like with the CRC rims I believe I only had 1 shim on each side to reach 172mm.
Old 03-03-2009, 02:25 AM   #7147
Default weigh
Originally Posted by PHI/BMI racer View Post
Wow that's light, what batteries and motor are you using? I am at about 900g with mod brushless motor and 4600 mAh batteries.
Jason
I like the ".020 linear springs"
they work real good on my new front end
and i looks like they don't compresses
keep up the good work :-)
weigh
PHI/BMI racer
Johnny Carey
I have be working and focus on weigh whit my car
my car T*Star12 is not the BMI car but this things
apply to all 12 scale cars, sow I hope. I don't
piss off any one here.
I have my car down to 818 grams this is whit mod motor and
Orion 4200 SHO, and Laje ESC, and my custom parts, frontend, etc.
parts.
I can get the car down to 799 grams whit my custom built motor.
Alf
alf.skaar is offline   Reply With Quote
Old 03-03-2009, 04:20 AM   #7148
protc3's Avatar
There are a few different offsets on the wheels available so i sent enough with the kit to be at 172 with a 1.5mm offset as opposed to the 3mm offset. Some wheels have no offset. I came to this decision before parma went to a 3mm offset(jaco wheel) being that jaco had just released the only 3mm offset wheel.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-05-2009, 06:53 AM   #7149
Do you have an editable pdf setup sheet for the 12RR? If so could someone post it or PM it to me? Thanks. Easier to keep track of the setups and changes.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 03-05-2009, 09:11 AM   #7150
Trader Rating: 7 (89%+)
http://www.rctech.net/forum/5101602-post6166.html
Johnny Carey is offline   Reply With Quote
Old 03-05-2009, 05:01 PM   #7151
looking for some ideas on how to gain some Off-power steering. My car has great on power steering but off-power/ slow speed isnt as good.
currently have BMI .20 front springs
60 weight shock oil
Stock shock spring
sure lube 3 in tubes
ride height is 3.5mm front 4mm rear
double pink fronts and pink rears.
spruce is offline   Reply With Quote
Old 03-05-2009, 10:26 PM   #7152
gubbs3's Avatar
My first choice would be to move the battery back. Next go a step heavier on the center spring (red). Also try a little toe-out (I prefer about .020-.030). Then go to the next stiffer flex plate setting.
On our carpet I also find that Yellow rears are almost always faster than Pink. They feel like they have a similar amount of traction but allow the rear end to rotate a little more because they don't have the rubbery stick of pinks.
gubbs3 is offline   Reply With Quote
Old 03-06-2009, 05:41 AM   #7153
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Grey/Black f/r
period.....
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 03-06-2009, 08:48 PM   #7154
Moderator
Clegg's Avatar
so a friend and I both run DB12RR's and have had the same failure of the front shock mount ball stud. When using the long alloy stud, we have found they tweak or snap in collisions. Now I know we shouldnt hit stuff... but it happens.
Both of us recently have fallen out of mains and qualifiers from failure of that front ball. Now we know this is a legacy associated bit from the 12L3 series of cars, so its not a BMI design failure. But I went and found a solid solution.
After seeing the new 12R5 center shock mount position and then looking at the 1/10th offerings out there, I picked up a Darkside Motorsports Adjustible center shock mount (#140). I rocks. In the same position as the AE mount it takes a lil more distance on the shock to give the same geometry, but overall its perfect. I used a small Ti ball stud in it and its rock solid. It has a pre threaded delrin base that fits fine.
Its probably a few gm's heavier than the AE setup, but I have no fear of busting those long ball studs anymore. And it complements the cars looks rather nicely.
I did also... somehow... bust the Silvia shock cap. I snapped the threaded portion right off. so I put an aluminum 4x40 scew through the hole with a small Oring on it, and a thin nut on the other side, and its good as new and longer which works for the darkside setup.
Old 03-06-2009, 08:58 PM   #7155
Also you can just swap it out with the long Corally ball stud which is steel
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
