Old 02-25-2009, 08:32 AM   #7126
Could be the new pod, I haven't weighed it yet for comparison. Might be the body as well, I use the thicker protoform or parma body, the thin ones break to easily.
I never ran any stock class, but are the motors the same weight as in the mod motors? In brushed the stock motors are lighter than mod, so could be for brushless... anyone tried this???
Originally Posted by chris moore View Post
The last time I weighed mine it came in at 888g with novak 4-cell, 17.5, s9650, mini spectrum and cap, 4600's and pt. That was before I aded the brushless pod so I'm guessing its a bit heavier now.
PHI/BMI racer is offline   Reply With Quote
Old 02-25-2009, 08:51 AM   #7127
Trader Rating: 7 (89%+)
Everything I run is in a pic on the prev page. LRP Shere Comp w/ cap,futaba 9650, Spektrum mini rec, mrt pt, and a trinity duo 17.5. I am running aluminum screws in every spot other than major stress areas.
Johnny Carey is offline   Reply With Quote
Old 02-25-2009, 06:40 PM   #7128
I through my DB12RR on the tweak station and it is tweaked. How do I correct this?
kobiwan is offline   Reply With Quote
Old 02-25-2009, 07:18 PM   #7129
EricF's Avatar
What electronics are you using, can you post a picture of you chassis layout?
Check your tires, make sure they're the same size left to right.
check for a colasped front spring.
E
EricF is offline   Reply With Quote
Old 02-25-2009, 08:13 PM   #7130
gubbs3's Avatar
What EricF said... and also check the motor wires. This goes for any car but once you set the tweak you should put the body on and check again to make sure the body isn't rubbing any wires and causing a tweak that you wouldn't find without the body on.
I have seen a few BMI's that don't level out the pod perfectly on their own. Not sure why. Even with the motor wires disconnected and all the pivots working freely, there was a slight tweak when put on a tweak station. The wonderful thing is that although the board said it tweaked, they all drove perfectly on the track.
And on the previous question... My DB12R with 9650 servo, LRP esc, Novak 13.5, pt, lightweight Parma body, a handful of aluminum screws and HUGE JR receiver came to 870g. I have since put in a spiffy new KO 2.4ghz receiver which should put me right around the 865g mark.
gubbs3 is offline   Reply With Quote
Old 02-25-2009, 11:03 PM   #7131
The lightweight body makes a difference in weight!!
Also it is almost impossible to have a car with absolutely no tweak at all. When you measure tweak the table and tweak station need to be perfectly balanced and since we do the balancing it can't be done 100%. Also running mod with the DB12R and now the RR I never had a problem with tweak, I just hammer on the throttle at the start and the car goes straight
Old 02-25-2009, 11:12 PM   #7132
Originally Posted by protc3 View Post
I start my length at 2.950
inches or centimeters ?
drover is offline   Reply With Quote
Old 02-26-2009, 04:48 AM   #7133
Inches!
Centimeters would make it a very short shock
Old 02-26-2009, 05:16 AM   #7134
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by PHI/BMI racer View Post
Inches!
Thats what she said.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-28-2009, 03:29 PM   #7135
protc3's Avatar
Sorry for the delayed reaction. Yes, that measurement is in inches.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-28-2009, 10:57 PM   #7136
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Hey Jason,
The changes I made to the car worked great. Knocked .5 sec off my avg lap times! If I could only pull my head outta my @$$ and drive better. Oh well.
Here's the set up I ran.
FRONT
.020 linear springs
#2 Shurlube on the kingpins
10 degree blocks with 4 degree static caster
Jaco Lilac tires trued to 1.65
4.5 mm ride height
REAR
Standard flex plates, long mount
Silva shock, 40w associated oil, blue spring
#3 Shurlube in damper tubes
Jaco Pink tires trued to 1.75
4.5 mm ride height
BATTERIES
EnerG 4600 NiMh to rearmost position
BODY
Protoform Speed 12B
I'm surprised I actually got 3 weeks out of this body!
Car turned in very fast, but the back end stayed put. Shot outta the corners with ease, and no high speed drift thru the sweeping turns.Tire wear was excellent. Hardly look like I ran them. Gonna try 5 degree blocks, and drop down to 4mm ride height, just to see what happens.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-28-2009, 11:16 PM   #7137
Got my DB10RR in on Friday Looking forward to building it
Old 03-01-2009, 08:43 AM   #7138
Dude! I'm totally jealous!
Three words...
Old 03-01-2009, 09:02 AM   #7139
protc3's Avatar
Great job chris.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-01-2009, 10:45 PM   #7140
Good morning to all BMI Thread.
Jason I just start to built my DB12RR I want to tell you what you have very top notch material on the kit man very good job, keep the good work.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
