Old 02-24-2009, 07:57 AM   #7111
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Jeremy Otis View Post
By the look of those front tires it looks like you have about 4 degrees of postive camber going on there.
By the way is this still the BMI websight? I just stated what Jason has been thinking.
Lets talk about batteries forward as apposed to being back and what this does to the handeling of the car and track conditions. Jason?
I've experienced a terrible push with the weight foreward ... which didnt make sence to me. Sort of figuted more traction, more steering . I guess the weight didnt want to rotate.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-24-2009, 07:57 AM   #7112
wingracer's Avatar
Trader Rating: 23 (100%+)
I don't know about BMI's but it should be the same as every other car. What I have found is that batteries forward makes the car more stable by taking away a bit of steering. It's great if the front end is hooking so hard that the car is trying to traction roll.
Batteries back gives a bit more steering and more responsive.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-24-2009, 08:01 AM   #7113
wingracer's Avatar
Yeah, it's counter intuitive but it's the same for nearly all racecars big or small. Basically when you move weight forward it will put more vertical load on the fronts (meaning more traction) but the traction doesn't go up quite as much as the weight will cause in increased side loading when cornering.
This is why wings are so great. You get the increased vertical load but add very little weight.
Team Shepherd USA
Old 02-24-2009, 08:06 AM   #7114
The majority of the time I run my batteries forward. I believe it helps with high bite situations and helps to mellow the car out a bit. This happens becuase you have less weight transfer from back to front. Running your batteries back will give you lots of weight transfer and almost makes your car snap through the corner. It gives you a ton of corner speed but does take away a bit of exit steering. You can compensate for this though with the right setup/tires. It can be little bit harder to drive smooth. Never try batteries back in modified. It is a disasterous...
Jeremy Otis is offline   Reply With Quote
Old 02-24-2009, 08:33 AM   #7115
protc3's Avatar
Having the batteries forward will mellow the car out on corner entry and make it drive a little easier. However, you will have increased on power steering with the forward weight. With the batteries back, you will get more corner entry steering and a overall more aggressive car But you will lose some of your on power steering under accelleration. The key is to start back and creep the forward until the car feels comfortable to you. Some guys like a super aggressive car and some dont. It comes down to personal prefference and driving ability.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-24-2009, 12:02 PM   #7116
V12
V12's Avatar
Jason you have PM. Thanks.
V12 is offline   Reply With Quote
Old 02-24-2009, 03:16 PM   #7117
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Doing my monthly rebuild on my DB12RR and learned something new. (isn't that the best part of this hobby? )
When using the #6 aluminum front end ride height spacers (3mm) on the front end, the front 8-32 screws supplied with the kit will come thru and press against the bottom side of the upper arm. Just use the trusty Dremel tool to shave 1 to 2mm off the screws then re install them.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-24-2009, 03:19 PM   #7118
Trader Rating: 8 (90%+)
You are correct, you could leave it as is and adjust droop in the front. Totally kidding.
BTW, for reference, what is everyones cars weigh?? Mine that I posted on the previous page is 847g ready to race. Just wondering.
Johnny Carey is offline   Reply With Quote
Old 02-24-2009, 03:38 PM   #7119
I had to add 21 grams to my car to make weight at the snow birds...can't recall what the actual weight was though.
Old 02-24-2009, 11:45 PM   #7120
Wow that's light, what batteries and motor are you using? I am at about 900g with mod brushless motor and 4600 mAh batteries.
PHI/BMI racer is offline   Reply With Quote
Old 02-25-2009, 02:11 AM   #7121
That was with 4600 EP cells and 17.5 and 10.5 motors. I also have pretty small electronics in the car.
Old 02-25-2009, 03:25 AM   #7122
Probably the ESC. I am running the Novak 4-cell GTB, 4.5L motor, spektrum micro receiver, and personal transponder.
Old 02-25-2009, 06:48 AM   #7123
can you use the springs from the IRS shock on the new Silva shock?
kobiwan is offline   Reply With Quote
Old 02-25-2009, 07:54 AM   #7124
AOD
AOD's Avatar
Yes
AOD is offline   Reply With Quote
Old 02-25-2009, 08:23 AM   #7125
chris moore's Avatar
Trader Rating: 87 (99%+)
The last time I weighed mine it came in at 888g with novak 4-cell, 17.5, s9650, mini spectrum and cap, 4600's and pt. That was before I aded the brushless pod so I'm guessing its a bit heavier now.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
