Old 02-20-2009, 03:21 PM   #7066
There is a conversion kit from the DB12R to the DB12RR which can be found here:
http://www.bmiracing.com/webstore/ca...612a65c5798a50
As for the differences...well I came along after the original DB12 so I can not say what the difference between that and the DB12R are but here is the DB12R to DB12RR:
- Wider rear pod and recentered axle for brushless motor centering.
- Shorter diff side hub to recenter the axle.
- Longer rear pod to enhance rear suspension handling.
- Upper pod shock mount position moved over the center pivot.
- Chassis shortened to adjust for the longer pod and keep wheel base the same.
- Rear flex plates lengthened for better handling.
- Multiple shock mount positions added.
- Servo mount holes slotted.
I think that's pretty much it.
Old 02-20-2009, 03:22 PM   #7067
V12
V12's Avatar
I assembled half of the car now. OK I didnīt follow the instructions completely, I did begin with the rear as I wanted to see how the pod and flexplates are working. Front suspension, tubes and center shock will follow tomorrow. Regarding the graphite parts I just removed the sharp edges but didnīt seal the chassis this time.
Iīm really impressed with the quality of the DB12RR so far. Especially the graphite parts are much stiffer than you would find with some other brands. Also very nice aluminium parts and anodizing.
Just one small "flaw" I did find until now is the flathead screws are not completely flat/even with the chassis. I did find this with most other cars in the past also, I know this has to do with variance of thickness of flathead screws.
Itīs just the problem if you live in Europe you canīt get those 4-40 screws in numbers that easy so you could select the thinnest for perfect flatness. I know the aluminium screws are a little thinner usually but I have to say I donīt trust in them regarding strength.
One question regarding the flexplate pivot balls. After assembling I noticed these are working very smooth and I canīt detect any play. One side is extremly free working and the other side just is a little less free and very slightly binding but still smooth and falling down. I think this will work out perfectly after some runs.
The question is do you really need the setscrews for adjusting play? I think if you donīt use the setscrews itīs just much easier checking out if the pivot balls still are firmly fixed to the chassis.
Regarding the tubes I just have some CRC medium lube (white cap) and 20000 Wt siliconoil here. I think the 20000 maybe is a little too much, whatīs about the CRC lube?
V12 is offline   Reply With Quote
Old 02-20-2009, 06:27 PM   #7068
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by Johnny Carey View Post
So I just got my car back from deluxe, they did a great job on the aluminum.
hey johnny, did you have to give them raw aluminum or were they able to anodize all the stock pieces thanx and it looks killer
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-20-2009, 06:32 PM   #7069
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Looks like the 1/12 scale Serpent and X Ray wished they built! ^^^
Sweet ride.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-20-2009, 07:17 PM   #7070
EricF's Avatar
[QUOTE=Johnny Carey;5458324]So I just got my car back from deluxe, they did a great job on the aluminum.
QUOTE]
I don't care who you are, that there is TIGHT SON!!!
E
EricF is offline   Reply With Quote
Old 02-21-2009, 04:29 AM   #7071
protc3's Avatar
Originally Posted by ghj1997 View Post
What is the difference between the older db12, and the db12r and db12rr. I have lookde around but can't find a real answer. Could you also upgrade a db12 to the RR.
You can update the R to the RR for $99.99 and we have the upgrade kits in stock.
Here is what the kit consists of:
The chassis
lower pod plate
1 pc crossbrace
offset hub
top pod plate
flex plates
pod cross tube
damper tube pistons
As you can see this kit is a steal. I cut the prices on all the parts so that it wouldnt take a ton of money to have the latest and greatest.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-21-2009, 04:30 AM   #7072
protc3's Avatar
They strip the origional color and replate the parts to the new color. Deluxe does a great job.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-21-2009, 09:24 AM   #7073
Jason,
you have a PM
Jeremy Otis is offline   Reply With Quote
Old 02-21-2009, 10:13 AM   #7074
Trader Rating: 8 (90%+)
You got her. Deluxe does a great job. They are only like a 20min drive for me.
The open ended ball links are the losi captured ends. A6017
Johnny Carey is offline   Reply With Quote
Old 02-21-2009, 10:45 AM   #7075
thanx jason. im gonna give her a makeover for next season
Old 02-21-2009, 12:18 PM   #7076
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Lets just hope no one sits on it ...
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-21-2009, 01:44 PM   #7077
chris moore's Avatar
Trader Rating: 87 (99%+)
Thanks.
Well My first time out with the car on asphalt in months last night. I had updated the car with the new brushless pod but did'nt have the $ to do the whole upgrade kit so I'm still using the 12r chassis. This makes the car about 1/4" longer so I was'nt 100% sure about the handleing. The first couple of rounds I was fighting it a bit, the traction was low to med and with only three 1/12 and all the TC's runing rubber it did'nt get any better as the night wore on. But after a couple of changes the car was butter in the main. My top5, top10, and top20 laps were all within a tenth which is just the consistancy I want to see.
As expected the car is a bit pushy in this configuration and its a bit slower thru a tight corner than I'd like. But the offset is also true that its very stable and very easy to drive. When I can afford it I'll get the new chassis and get her back to flying thru the corners. Still really fun to drive just as it is.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 02-21-2009, 10:44 PM   #7078
Learned something new tonight with the car.
This weeks layout has a couple of chicanes I was trying to get the car to wiggle thru. I actually went softer from #4 to #2 shurlube in the rear, long flex links, and it worked. Seems like the car can now switch direction quicker (less pack in the tubes) but still has plenty of forward traction(long flex links). Everyone commented on how smooth the car looked. Gonna see what happens with lighter lube on the kingpins next week.
Three words...
Old 02-23-2009, 07:10 AM   #7079
Has anyone put the CRC Pro strut long arm front end on their DB12RR? If so did you like it better and what are the parts and part numbers I need to put the crc long arm front end on?
kobiwan is offline   Reply With Quote
Old 02-23-2009, 07:31 AM   #7080
Congrat's to Greg "ShowTime" and Mike Sr. for putting their 12RR's in the show in the last leg of the North East Grand Slam. There was some tough competetion there this weekend.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
