Old 02-08-2009, 06:24 AM   #6976
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by protc3 View Post
Dont worry about it buddy. I took care of it already.
Thank you Jason, I get back to work last Tuesday and its 14-14-12-10 hour work days... I'm just starting to get caught up.....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 02-08-2009, 07:16 AM   #6977
Zerodefect's Avatar
Does the DB12rr come with a pod thats balenced for brushless or brushed? If its balenced for brushless you just shim the brushed motor right?
I'm going to run brushed stock until I use up my old collection of motors then switch to 17.5 brushless.
Nice looking car.
Zerodefect is offline   Reply With Quote
Old 02-08-2009, 07:41 AM   #6978
protc3's Avatar
The pod is designed to be balanced for brushless. You can run brushed motors also and IRS has a motor plate shim for using brushed motors.
Brushless and brushed motors fit into the pod with ease and with no disassembly. If your not carful, either motor will fall out of the pod.
Thanks for the kind words about our car. We really are proud of it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-08-2009, 08:13 AM   #6979
You got mail.....
RC Tech member #11
Old 02-08-2009, 08:14 AM   #6980
Zerodefect's Avatar
Thanks thats all I needed. I just found the info for the rr. Looks like you fixed everything on the r car. I was looking at simple t-bar cars to jump into 12th scale with, but selecting t-bars doesn't seem simple at all. I like the ability the 12rr has to adjust roll and bump independantly and still roll like a t-bar car. Nice servo mount slots to, I stink at drilling servo mount holes.
The batteries look like a tight fit. I might just make the packs with a wire in the middle like a saddle pack to get them in and out. Someone recommended I get 2-3 packs so I can get enough track time.
Old 02-08-2009, 08:19 AM   #6981
You would be the first person I know of that would put a wire in the middle..... Ther are about 15-20 BMI racers in the DC area and we all use the straight 4 cell assemby....
RC Tech member #11
Old 02-08-2009, 09:25 AM   #6982
protc3's Avatar
Its not as tight as it looks. This is the most adjustable 1/12th car on the market. With other cars you will need to change out springs and T plates to adjust spring tension. Eache flex plate has 6 different spring rate options with no changed parts. You will find it to also be the most durable and tweak free also. If you need any help just let me know.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-08-2009, 09:33 AM   #6983
avs
avs's Avatar
You do not need that much steering throw. You will be fine setting it up the way you have it. Take a pic and post it for me when you can so i can see and make sure i am understanding exactly what you are saying.
the outside arm clears but the inside arm catches the head of the upper pin. if i raise the servo to the top of the mount then i just need to raise the ball on the steering arm to reduce bump steer? or do you run it like this? here is what i was describing.
avs is offline   Reply With Quote
Old 02-08-2009, 10:10 AM   #6984
protc3's Avatar
That is more than enogh steering throw. If you want more you can use the rear holes in the servo mount where it mounts to the chassis and run the ballstuds on the back of the servo saver. This will make the turnbuckles dead straight when looking down from the top of the car.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-08-2009, 01:08 PM   #6985
avs
avs's Avatar
ok thanks i will run it as is.
moving on i have a couple more (hopefully last) assembly questions.
1)
the instructions indicate that setting the 'overall shock length' to 66mm should provide 1.5mm droop. if i install the front shock support 1 hole fwd from the most aft position (see pic below) then i need to make the shock length 69mm (center to center of ball cups) to get 0.0 droop.
if i move the fwd shock support to most aft location then i get shock length to droop setttings more like the instrctions but then it looks like there is a battery clearance problem.
so is 69mm the right length?(use a longer ball cup) or should i raise (shim) the ball stud on the front mount?
2)
also regarding battery packs, it looks like the battery packs are one piece, (ie not saddle packs with a center jumper wire.
if so, then is it std practice to remove the shock to get batteries in and out?
thanks again for your patience and attention.
Old 02-08-2009, 01:17 PM   #6986
xtrememadness's Avatar
Send a message via AIM to xtrememadness
1)
2)
Attachment 415765
the 66mm setting is for the original shock. you are running the new silva bladder shock which is longer. so basically wherever hole you chose according to your setup you will just need to adjust the ball cups on the shock to get 1.5mm of droop. running the shock in the hole farthest back will give you the most steering.
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-08-2009, 01:19 PM   #6987
and yes we always pop off the shock to remove the battery. just need to remove it on the top plate side
Old 02-08-2009, 01:22 PM   #6988
avs
avs's Avatar
ok thanks, i will do that.
so you don't fiddle the front mount height to tune the shock just the fore aft position?
Old 02-08-2009, 01:30 PM   #6989
PartTime's Avatar
Care to expand on that? I can think of 4, but 6?
DK
PartTime is offline   Reply With Quote
Old 02-08-2009, 01:53 PM   #6990
ok. sorry. yeah for high bite carpet we run a medium height ballstud(black) and 2mm shims under antenna mount. this is the same as running the tall ball stud except the tall ball stud bends like a prezel the shims under the mount is a jason schreffler trick. the higher the shock the more entry steering i believe
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
