Old 02-03-2009, 09:51 PM   #6931
tdu verney's Avatar
Default BMI @ the Birds
Scheff just a few questions;
1. track dimensions.
2. roll out.
3. motor, servo & sec used.
4. radio settings.
tdu verney is offline   Reply With Quote
Old 02-03-2009, 10:05 PM   #6932
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
I was wondering what the deal is with the heavy lube in the tubes for even in some of the asphalt setups. I can see for use in carpet racing, but asphalt is the bit of a shocker for me.
CarlosG. is offline   Reply With Quote
Old 02-04-2009, 04:11 AM   #6933
protc3's Avatar
Thats actually pretty standard in all cars carlos. Asphalt usually uses a heavier dampening than higher bite to help to keep the car from doublesteering.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-04-2009, 05:01 AM   #6934
Hi Jason
I sent you a regular comment, because I could not PM you. It said your inbox was full.
PHI/BMI racer is offline   Reply With Quote
Old 02-04-2009, 06:31 AM   #6935
schreff's Avatar
Send a message via AIM to schreff
2. roll out.
4. radio settings.
Let's see...
1a. The track dimensions, at SnowBirds, I think was 100x50
2a. 3.17" rollout
3a. Motor = Duo 17.5 (set to lowest timing setting). Servo = Futaba 9650. Speedo = Tekin RS set to Max timing boost on 1.89 software
4a. As for radio settings, not really sure what you're looking for here. I don't play with anything major on the radio. I know the Dual Rate was at 51% with 100% end points. Other than that, everything was standard. Radio is a DX3R.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-04-2009, 07:50 AM   #6936
protc3's Avatar
Originally Posted by PHI/BMI racer View Post
Hi Jason
I cleaned out my pm box. Please send again. My email has been messed up for some reason.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-04-2009, 07:51 AM   #6937
protc3's Avatar
Hey Schreff, are those losi ballcups on the steering turnbuckles? A customer is curious and i dont know for certain. Also, Can you post your setup for WGT on the DB10R thread for the customer to see?
I will call you this week bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-04-2009, 07:55 AM   #6938
Trader Rating: 7 (89%+)
Yes. Losi A6017.
Johnny Carey is offline   Reply With Quote
Old 02-04-2009, 08:28 AM   #6939
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I use the losi ball cups also but they work best on losi ball studs, Titanium ones are my favorite.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-04-2009, 08:35 AM   #6940
schreff's Avatar
Johnny has the part number right on the ball cups. And you really should use the Losi titanium studs for them as with normal ball studs, they might be a little loose and cause excess slop.
And with the WGT setup, I'll work on that tonight. It's still in the trunk of my car.
-Jason Schreffler-
Old 02-04-2009, 08:59 AM   #6941
protc3's Avatar
Thanks dude.
Larry and Jason, Can you guys both send me a copy of your setups from the birds so i can get them on the website? Thanks guys and great job at the birds. You guys both did a great job on and off the track.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-04-2009, 09:08 AM   #6942
protc3's Avatar
Hey Guys,
I want to let you know that i will be adjusting the website to offer free domestic shipping for the whole month of february. I will try to get this done today. Thank you to all of you who support BMI Racing.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-04-2009, 10:40 AM   #6943
Yeah the Losi ball cups I got from Larry were a bit loose on the regular nickel ball studs but really helped with steering throw with the laid down servo. I used the old o-ring trick and that really tightened it up nicely but I want to pick up some Losi ball studs so I don't have to.
Old 02-04-2009, 11:42 AM   #6944
Default good starting set up
Having run my car on four occasions and it couldnt have gone better.Here is my final set up
Front
camber 1.5 degrees
caster static 5 degrees
caster active 5 degrees
020 springs CRC type
servo up
bottom strut IRS AE cut down
10,000wt on king pins
ride height 3.5mm
rear
red spring
shockt 35wt
tubes 20,000 wt
shocj centre position
batteries as far back as possible
2mm shim under fron shock ball joint
droop 1.5mm
long thick side plates
ride height 3.5mm
Used Jaco yellow rear, Jaco D/Pink fronts
Carpet GT PRIMA FELT
Body was a Parma 8 HD
Car was excellent through out the meeting.Dont really think i can improve the car any more.
Except some extra speed.
tellan is offline   Reply With Quote
Old 02-04-2009, 05:22 PM   #6945
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by schreff View Post
Let's see...
2a. 3.17" rollout
hey schreff, i see you ran the battery all the way back. what did this do for you and the handling of the car. thanx bro
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
