Just completed the build 2 hours 40 mins and another 2 hours kit it out.What do you think guys.
BMI 12RR If it goes as well as it looks watch out.
Wow thats a fast build! took me 2 nights. 1 night to just build the front end and sand/CA the chassis, and the second night to get electronics on it and get it running.
-Joe
For Racing: BMI DB12RR-LiPo, For Fun: HPI Blitz
RCP 1/12th Scale 2009/2010 spec - Updated Often: http://www.rctech.net/forum/5734711-post1754.html
R/C Racing is: 10% skill, 10% equipment, 20% luck, 50% bullshit and drama.
Jason, (or anyone for that matter) can you please explain what changing the front droop does for the cars handling.
ie; changing from 3 shims to 2 shims above the upper pivot ball.
Is there an optimum difference in tire dia from front to rear? Perhaps a ratio you can use like the rear tires are for example should be 1.05 times bigger than the fronts.
Droop in the front makes the car a little more predictable. This is at the expense of a slight bit of on power steering. With no droop, the car will feel very direct and almost feel like it wanders a little. Some guys like that. I prefer to have the car a little more predictable.
I usually always run a .100 split. The .100 difference from front to rear just gives me the feel i am looking for. When i run a .050 split, I feel the car has spongy feel. The .100 works well for me. I have seen many variances is preffered split.
Jason Breiner
BMI Racing
www.bmiracing.com
DB12RR lipo edition cars now available
Thanks Jason,
one more thing. On the weekend I was getting a little bit of double steer on the car. We were running outdoors on Ashfelt. What would I do to correct this without sacrifising any rear grip?
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
Thanks Jason,
Try running the flex plate in the short mounting position
Jason Breiner
BMI Racing
www.bmiracing.com
came out of a sweeper too wide and bounced off a wall a long time ago. I bent the pod plate back as best I could and had meant to replace it. I forgot to actually change it over though !
Can someone tell me the difference, if any, between jaco yellow rears and pink rears, they have the same shore rating but I wasn't sure if there was a difference. I heard the pinks just don't chunck as easy.
That's definitely a useful guide, I was honestly pretty clueless as to what all the foam compounds are, just been running what everyone's been telling me to run, lol.
Tamiya TRF - Peak Racing - BMI Racing - KO Propo - AKA - Parma - Manutech - Slapmaster Tools - Pound It Paints
