BMI's DB12R
Old 01-11-2009, 12:33 AM
  #6721
Uga
Uga's Avatar
Originally Posted by xtrememadness
the new irs arms are weak. you can minimize breakage by first tapping the arms with an 8/32 tap before you screw them in. also use either titanium or steel front screws. the aluminum bends like prezels and breaks the arms.
Anybody knows where to get a 8/32 tapper? Haven't seen in hobby shops and as I'm living in the metric part of the world, the hardware stores are not stocking them as well.
Uga is offline
Old 01-11-2009, 03:14 AM
  #6722
t4mania's Avatar
You can get them here:
http://www.mcmaster.com/
t4mania is offline
  #6723
Default 8-32 tap
Try a company called model fixing.they also take paypal .Next day delivery.
email address [email protected]
hope that helps.
tellan is offline
Old 01-11-2009, 04:23 AM
  #6724
protc3's Avatar
Originally Posted by kobiwan
I have the new silva center shock, and I am having problems with it. First I couldn't seem to build it without it getting air in it or sounding squishy. I mentioned that on this thread and got some building tips that seemed to work. But after a day of racing it makes that squishy noise until I rebuild it again, and then it is fine until I race again. Any help would be appreciated. I am currently looking to replace it with another shock. Will the nickel teflon macro shock (part #DB3060) work on the DB12RR or is that for the 1/10th scale pan car?
DB3060 does work fine on the DB12RR. It will require longer ballcups but it works great. Let me see if i can repeat this problem and come up with a solution. I havent had any problems with mine so far. I will let you know what i can find.
protc3 is offline
Old 01-11-2009, 04:41 AM
  #6725
I know there was some tips on building the silva shock but I just cant find it. Anyone have those tips handy? Thanks!
windsor is offline
Old 01-11-2009, 04:57 AM
  #6726
Uga
Uga's Avatar
Thanks for all replies, I will look into those links.
Uga is offline
Old 01-11-2009, 06:30 AM
  #6727
Is the DB3060 a better shock by design? Do you recomend it over the Silva shock? Do you have a part number on those longer ball cups you mentioned? Just by looking at the DB3060 and the Silva, the DB3060 looks like a better shock. Thanks
kobiwan is offline
Old 01-11-2009, 06:31 AM
  #6728
xtrememadness's Avatar
uga. lowes home improvement. kobalt 8/32 tap. 6 bucks. works perfect
xtrememadness is offline
Old 01-11-2009, 06:56 AM
  #6729
Uga
Uga's Avatar
hmm, if that's a shop in the States, then I will stick with online ordering, as traveling over the Atlantic for a 6 buck worth tapper was not in my plans Thanks for info though..
Uga is offline
Old 01-11-2009, 07:42 AM
  #6730
I made a typo in my previous post. Part# DB3060 IS the Silva shock. I meant to ask if the shock which is part# DB3150 will fit on the DB12RR. Sorry. Just wanted to make sure I clarified what I was asking, Thanks.
kobiwan is offline
Old 01-11-2009, 07:46 AM
  #6731
protc3's Avatar
DB3150 is a larger 1/10th macro shock. It will not work on the 1/12th. I will see what i can find on the 1/12th shock before you give up on it. It really is an awesome shock.
protc3 is offline
Old 01-11-2009, 07:51 AM
  #6732
I was told to try the Hot Bodies 1/12th scale shock, but I heard it was the same shock as the Silva.
kobiwan is offline
Old 01-11-2009, 09:02 AM
  #6733
protc3's Avatar
They are about the same. I am going to be looking into making some optional pistons for the silva shock. Try running 60 wt oil in the shock. I ran 35 wt when i 1st got it and it seemed to develope some air bubbles. With the piston having holes in it, it makes the shock need alot heavier oil to have the same feel as an IRS of VSC shock.
protc3 is offline
Old 01-11-2009, 09:10 AM
  #6734
I have been running Losi 45 weight in it. Should I still go to 60 weight? How musc is going from 45 to 60 weight going to effect the handling? Is it possible that I have a faulty shock?
kobiwan is offline
Old 01-11-2009, 09:14 AM
  #6735
protc3's Avatar
There isnt much that can be fault on the shock. If you install the shock shaft with a dry Oring you can damage the Oring but thats the only part that can leak.
45 wt. is going to be too light for most conditions. 50-60 wt. is going to be around 30-35 in the IRS shock. 45 is going to be more like 20-25 wt.
protc3 is offline
