Old 01-05-2009, 06:05 PM   #6646
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey jason i ran the new car yesterday and added another lap to my time awesome bro. now i think you should start working on your own front end or at least some lowers cause the irs ones are a little weak and can be a pain sometimes. just my 2 cents
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 01-05-2009, 06:09 PM   #6647
protc3's Avatar
Thats great news buddy. Im glad you are enjoying the new car. We had a snowbirds warmup race here this weekend. Both my DB12RR and DB10R were absolutely a dream to drive. I lost my 2 front body pins in the middle of the 1/12th main so i had to pull it off because the body kept lifting off but the car was a missile until that point. My DB10R was unreal and i took the TQ and won the main by a large margin. It was nice to get out and run again
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-05-2009, 06:11 PM   #6648
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Kick A$$!! Congrats.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 01-05-2009, 06:19 PM   #6649
Moderator
Clegg's Avatar
I am starting to get down with the RR and get some consistent pace... tonight I knocked off 2/10ths off the fast time from the race that we had yesterday from the winner and matched his pace after only a few tweaks. ( I came in 3rd in the race after having my receiver go dead mid way and needing to have the car shut off and powered back on to start running again)
The car is so easy to drive I find myself maybe driving it a bit too hard and fuzz over the tires a bit too fast.
A good firend just ordered a RR and some goodies with it to join in the fun here at the local track
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-05-2009, 06:20 PM   #6650
a dream to drive hits the nail on the head
Old 01-05-2009, 07:14 PM   #6651
protc3's Avatar
Thanks a ton for the nice comments guys.
Here is the setup i ran this past weekend. The traction was medium and we use jack the gripper for compound.
Front:
5 degree block w/ 4 degree castor
.020 linear springs and #4 surlube on the kingpins
3.5mm ride height
servo flat w/ medium ballstuds on the steering blocks
Lilac front tires cut to 1.650
.25mm droop
Rear:
Gold center shock spring
Silva shock w/ 60 wt AE oil
Medium ballstud on shock mount
batteries in the middle
#4 surlube in the tubes
Stock flex plates mounted in short position
no tweak screws
Yellow rear tires cut to 1.750
172mm rear width
1mm pod droop
Pod Level at ride height
3.5mm ride height
Car handled excellent. For higher bite i would go to a red center spring and move the cells all the way forward.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-05-2009, 08:24 PM   #6652
EricF's Avatar
Jason,
Where did you have the ball studs mounted on the servo front or back side?
E
EricF is offline   Reply With Quote
Old 01-05-2009, 08:35 PM   #6653
Trader Rating: 37 (100%+)
Nobody hits the boards harder than me!! I overdrive the car cause the speed it carries is unreal. Haven't broken any frontend parts. I did break the new long arms (on the long side right infront of the bend) but put the shorter ones on and worked for me better and haven't broke any.
Awsome car Jason.
4TH Annual Fall Cla$$ic: Mike's Hobby Shop November 12-14, 2010 www.easttexasrc.com www.mikeshobbyshop.com 17.5 Rubber Sedan, 13.5 Rubber Sedan, 17.5 1/12TH, 13.5 1/12TH, WORLD GT, stock sedan and SLASH
EXPRESS MOTORSPORTS : SCHUMACHER MI3 : ASSOCIATED 12R5 : ASSOCIATED 10R5 : TAMIYA TT 01 : LOSI XXXT-CR : LOSI BK : TRAXXAS SLASH : LOSI SLIDER : CUSTOM WORKS OUTLAW
steve crane is offline   Reply With Quote
Old 01-05-2009, 09:04 PM   #6654
Moderator
Clegg's Avatar
Front:
3.5mm ride height
.25mm droop
Rear:
no tweak screws
172mm rear width
1mm pod droop
3.5mm ride height
Hey Jason, I am running very similar on my car only with the long setting on the flex plates and my servo is raised. How do you use the medium ball stud on the shock mount and not hit or get interference from the cells? I am running the stock tall ball stud, with 1.5 mm of shims inbetween the stud and the ant mount and dont have issues, but I have seen with the batteries moved forward much and a lower stud, the shock hits the cells.
Old 01-05-2009, 10:12 PM   #6655
Trader Rating: 8 (90%+)
The stock ball stud for the shock is the medium IRS. Ive run mine, batts all the way forward, med stud, and 1mm shims under and havent had a problem with it.
Johnny Carey is offline   Reply With Quote
Old 01-06-2009, 03:07 AM   #6656
protc3's Avatar
Originally Posted by EricF View Post
Jason,
E
I run the ballstuds on the back of the servo saver.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-06-2009, 03:08 AM   #6657
protc3's Avatar
I dont run the antenna mount full short or closest to the cells. I run it so 1 hole is exposed and i dont have any interference.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-06-2009, 09:06 AM   #6658
What does that change when you move the mount forward or back??
Old 01-06-2009, 09:18 AM   #6659
protc3's Avatar
A longer shock increases rear traction and the shorter shock decreases rear traction. I run it in the middle.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-06-2009, 02:56 PM   #6660
Ffejdat's Avatar
Jason, I see on your setup, you list the Silva shock as your shock, is that the normal type shock, like the older Assoc 12th shock, or the new bladder HB style shock and what do you feel the 60 wt oil does for you, Thanks!
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
