Old 12-30-2008, 07:42 AM   #6571
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
Leon,
What time will the track be ready?
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
Old 12-30-2008, 10:26 AM   #6572
Trader Rating: 7 (89%+)
Originally Posted by gubbs3 View Post
Here's the setup from Sunday:
DB12R (not rr)
Novak 13.5 71mm rollout
Track was open 90x48 med/high bite carpet
Front:
Spring- AE .020
2000 on kingpins
10* block shims back
3.75mm ride height
black jaco tires 1.69" 1/2 compound Paragon
flat servo
0* toe
Rear:
standard flex plates (DB12R)
7000 tubes
Center shock- red spring, 40wt
jaco gray 1.75 full paragon
4mm ride height
2.5mm pod droop
batteries middle
Parma Speed 8 lightweight body
I was thinking the pod droop might be the problem but it was also lifting the front tire off power. My first thought was to go up in the damper tubes but anytime I've tried 10,000 it was slower than with 7000. Another racer dropped to 5000 and was very pleased.
Here's a link to the full results:
http://jlapracemanager.com/cgi-bin/J...ATE=12_28_2008
Jeff, Kevin, and myself (Troy) were all running BMI in Super Stock.
Try 5* Blocks and a little thicker front lube.
Johnny Carey is online now   Reply With Quote
Old 12-30-2008, 02:49 PM   #6573
fatbear's Avatar
Send a message via Yahoo to fatbear
Hi guys,
I need suggestions for a setup for a very low grip smooth ashfelt track.
I will be using the new RR and there is no tire additive allowed.
Just some ideas for a good base setup to start with.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 12-30-2008, 07:14 PM   #6574
Impulse_racer's Avatar
How often should the foam ring, the orange and black O-rings be replaced in the Micro Shock?
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
Old 12-30-2008, 08:51 PM   #6575
Originally Posted by islander360 View Post
Leon,
good question bud im thinking that it will be the same time as always around 5 or 6 but since there are some people coming in from out of state to get a run on the snowbirds layout i think mike will try to get it started a little earlier but im not sure
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 12-31-2008, 11:08 AM   #6576
CREWMAN's Avatar
Trader Rating: 19 (100%+)
I just finished upgrading my db12 r to the rr. The body is pretty beat, but i havent tried the car yet. The holidays have really slowed me down but after now im ready to go full bore
BMI's DB12R-100_1455.jpg   BMI's DB12R-100_1456.jpg   BMI's DB12R-100_1457.jpg   BMI's DB12R-100_1459.jpg   BMI's DB12R-100_1461.jpg
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 12-31-2008, 12:26 PM   #6577
chris moore's Avatar
Trader Rating: 85 (99%+)
Looks nice crewman, what frontend is that? I dont recall seeing one with the blue alum piece you have there.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 12-31-2008, 12:49 PM   #6578
protc3's Avatar
Looks to me like the IRS castor blocks and upper arms with the castor blocks anodized blue. Very nice looking
Sorry i havent been on here as much guys. My home computer took a dump and i havent had a chance to get to the store yet with the holidays here. After tonight i should have the time. I will be back more often again shortly.
Everyone have a safe and happy new year and be sure to drink way too much. See you guys next year.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-31-2008, 01:00 PM   #6579
Trader Rating: 23 (100%+)
Those are indeed the IRS castor blocks... http://www.teamirsrc.com/caster.html...available in plain or blue. Very well made and also allows for four different hinge pin locations. The upper arms are VERY durable. Yes, I have proven that on a number of occasions.
SteveL is offline   Reply With Quote
Old 12-31-2008, 03:28 PM   #6580
CREWMAN's Avatar
Yep that is the irs front end. thing works great for me. And it looks cool too
D&K HOBBIES!!!!
Old 12-31-2008, 04:11 PM   #6581
Very cool indeed, thay looked like the ones I've had on my 1/10 oval pan cars from IRS, just did'nt know thay made them for 1/12
Sponsered by:
Old 12-31-2008, 04:13 PM   #6582
CREWMAN's Avatar
yea they make it for 1/12 as well. Alot of guys think that this front end will only work for oval but i have found for me that it works great on road coarse. give it a try
D&K HOBBIES!!!!
Old 12-31-2008, 04:19 PM   #6583
A bit too pricey for my budget, I'll have to go with a bit less bling
Sponsered by:
Old 12-31-2008, 04:30 PM   #6584
xtrememadness's Avatar
Send a message via AIM to xtrememadness
happy new year to the entire bmi family and jason i will drink too much but i will be building my db12rr tommorrow so i have to take it easy on the booze so i dont put anything together backwards
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-31-2008, 04:41 PM   #6585
protc3's Avatar
Im all set. Off to a party in a bit. Just went to the local fireworks stand and got my grand finale mortar bomb. I hope to have all 10 fingers tommorow.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
