Old 12-29-2008, 09:09 AM   #6556
c-lyon's Avatar
I ran my double R for the second time last night, even better than the first. One word to describe it might be smooooth. Another (better) racer took it for a few laps and suggested a softer shock spring, so I'm looking forward to trying that next week. Thanks for a great car Jason.
c-lyon is offline   Reply With Quote
Old 12-29-2008, 09:26 AM   #6557
protc3's Avatar
Thanks buddy. Im glad you are enjoying the car.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-29-2008, 11:31 AM   #6558
Moderator
Clegg's Avatar
Even while I posted back that I busted some stuff... the car is just flat out fantastic. It is SO fast and stable that its pretty unexpected the pace increase I saw. Its easily .5 to a full second improvement over my old T bar car. I went form lagging the leader(s) by 5 or 6 laps in a 8 min main. To helping set the pace and being less than a lap off the real fast guy(s) at the track.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-29-2008, 12:03 PM   #6559
protc3's Avatar
Thats great to hear buddy. We wanted to make a top notch car that was easy to maintain and work on. Im glad you guys are enjoying it. I know i do.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-29-2008, 12:18 PM   #6560
gubbs3's Avatar
Great showing for BMI yesterday at our monthly Sunday race. TQ and 2nd qualifiers and winner were BMI.
Question- My car was a missile all day but when the bite came up real high in the 3rd round, my inside front tire started lifting a little, and caused a traction roll once. What should I do to prevent this without taking away too much steering? For the main I just used a little less compound on the front tires which worked, but made it push a little.
gubbs3 is offline   Reply With Quote
Old 12-29-2008, 12:28 PM   #6561
chris moore's Avatar
Trader Rating: 85 (99%+)
What springs and tire combo were you using?
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 12-29-2008, 12:29 PM   #6562
Just got my 12rr conversion and i picked up the new shock also how much would i have to go up in shock weight to get the shock the same at the moment i have had 35 in the stock shock but as the new shock has a proper piston just would like to know what you recommend.
Quietman is offline   Reply With Quote
Old 12-29-2008, 12:52 PM   #6563
protc3's Avatar
50 wt. seems to run similar to 35. Its maybe just a tick lighter to be honest.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-29-2008, 04:20 PM   #6564
protc3's Avatar
Try bumping up your spring rate on your center shock. What was your setup?
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-29-2008, 08:21 PM   #6565
gubbs3's Avatar
Here's the setup from Sunday:
DB12R (not rr)
Novak 13.5 71mm rollout
Track was open 90x48 med/high bite carpet
Front:
Spring- AE .020
2000 on kingpins
10* block shims back
3.75mm ride height
black jaco tires 1.69" 1/2 compound Paragon
flat servo
0* toe
Rear:
standard flex plates (DB12R)
7000 tubes
Center shock- red spring, 40wt
jaco gray 1.75 full paragon
4mm ride height
2.5mm pod droop
batteries middle
Parma Speed 8 lightweight body
I was thinking the pod droop might be the problem but it was also lifting the front tire off power. My first thought was to go up in the damper tubes but anytime I've tried 10,000 it was slower than with 7000. Another racer dropped to 5000 and was very pleased.
Here's a link to the full results:
http://jlapracemanager.com/cgi-bin/J...ATE=12_28_2008
Jeff, Kevin, and myself (Troy) were all running BMI in Super Stock.
Old 12-29-2008, 08:59 PM   #6566
Ffejdat's Avatar
Troy, I cut my blacks down a little smaller than out of the box, and glued the sidewall a little, that helped ALOT for the traction roll... Have to measure them to see how big....
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 12-29-2008, 09:06 PM   #6567
Default tire diameter.
troy,
the blacks i were running started out at 1.65 yesterday, only time they pushed was in hot laps(hadn't used the since WOW) but after that they were awesome(gojo rules)
shaggy1 is offline   Reply With Quote
Old 12-30-2008, 02:12 AM   #6568
Just got my OD wire and roll over antennas in today. Thanks OD! This wire looks and feels awesome! Not too thick of insulation and very flexible. Now all I need is the CRC sensor wire harness I ordered to come in and I can finish my car for this weekend's race
Old 12-30-2008, 06:53 AM   #6569
Hey Jason are you going to be at the carpet race on friday night for practices??
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 12-30-2008, 07:01 AM   #6570
protc3's Avatar
I will be there bro.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
