Old 12-27-2008, 02:53 PM   #6526
xtrememadness's Avatar
Send a message via AIM to xtrememadness
i would get a titanium screw set
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-27-2008, 02:55 PM   #6527
hey guys what grade sandpaper do you use to sand the edges of the chassis. just wondering cause i usually do it with 600 but it takes forever thanx
Old 12-27-2008, 03:03 PM   #6528
Scottrik's Avatar
Trader Rating: 241 (100%+)
I collected a complete set of aluminum screws and compared them with the weight of steel screws that come with the 12R kit. Net savings...12 grams. Less than 1/12 ounce. Titanium will save a little weight from the steel but will still be heavier than the aluminum screws.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 12-27-2008, 07:50 PM   #6529
protc3's Avatar
Originally Posted by Uga View Post
So I want to lighten up my car a bit, I want to get aluminium screw set, so which one would fit best for the DB12RR - AE or CRC? Or maybe is there a better option than those 2?
One of my local dealers sells an aluminum screw kit for the car. i will contact him for you
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-27-2008, 08:43 PM   #6530
Moderator
Clegg's Avatar
I did the same, but with a few of each screws and extrapolated out... the weight savings wasnt worth the headache of stripped and busted screws.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-27-2008, 10:14 PM   #6531
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I did mine with 400 grit sandpaper. Just sanded enough to dull the sharp edge of the chassis down. At first glance, it doesn't look like much, but you can feel the difference with the tip of your finger.
Gotta question. I'm well aware of how silly small of a tire I can run on the DB12RR, but how small is too small? Seems like the rears go below 1.700 things start to get a little unpredictable.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-27-2008, 10:32 PM   #6532
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Chris,
The smallest I ran mine where 1.58" to 1.60 front to about a 1.68 rear On my car. My car ran fine, you just have to let the traction soak in a little longer. A larger Dia tire will hold traction longer than a smaller Dia tire. I just think you went too heavy in the dampner tubes.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-28-2008, 07:53 AM   #6533
I'll try letting them soak longer. Gotta mount up a new set for next week any way. These things r worn out ( maybe 1.62?) See you at the track.
Three words...
Old 12-28-2008, 09:58 AM   #6534
Twin 1 Kevin's Avatar
Default flex plates
What does mounting the "flex plates" using the longer position (12rr car) as opposed to the standard position (12r car). How will this effect the handling of the car.
I updated my 12r to the 12rr version
Twin 1 Kevin is offline   Reply With Quote
Old 12-28-2008, 10:39 AM   #6535
mike ivy's Avatar
Hey Twin 1 Kevin,
The Longer Flex Plates mellows the car out they work great on high bite tracks.
Hope this helps.
Mike
Old 12-28-2008, 11:14 AM   #6536
Thanks Mike.
Old 12-28-2008, 12:59 PM   #6537
thanx spraydbysprague time to get sanding yeah things get a little hairy at the end of a run with small tires if you dont have enough traction compound on em
Old 12-28-2008, 01:08 PM   #6538
Moderator
Clegg's Avatar
So I truly busted the first parts on my DB12RR today.
THe track I race at has a long sweeper after a 50+ ft straight. We are running 17.5/4 cell. I was running fast lap times for the first qualifier and lost composure (either I did or the car did) and hit the far wall in the sweeper pretty hard, snapping both flex plates.
So I figured "oh well - live and learn" So I went and replaced the busted flex plates since I had a spare set.
Went back out for the second heat - once again setting fast laps for the day (improved on my earlier fast lap by .2 sec)... and this time to pass someone who was hugging the line but was far slower than me around the sweeper I went inside and just barely nicked the inside corner and it cause the car to lose ballance and head into the same wall as before - this time it not only snapped both flex plates but also popped the pivot off in the center of the chassis. No other damage - but my day was over as I am out of flex plates.
The weird thing is.. this track has been setup like this for 3 weeks and I have run 3 weekends now, and a bunch of practice and never busted a part before... just a bad luck day. (and just starting to realize how expensive the flex plates are)
An order has been placed at BMI - now all I can do is hope they come in soon
Old 12-28-2008, 02:58 PM   #6539
Uga
Uga's Avatar
Wow, that's really bad luck! I've been driving the car for 1.5 years now with 5.5 modified and had numerous bad crashes and I have not broken a single link bar, the only damage over this time has been a broken side wing, 2 battery locators and bent both front upper arm hinge pins.
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 12-28-2008, 03:41 PM   #6540
terryh's Avatar
Someone I know had the same problem, and he was the only guy breaking flex plates. Turned out he was doing the set screw up to tight so that the pivot ball couldn't move freely, next time he fitted new flex plates he loosened off the set screw just enough so that the pivot ball moved around freely and without slop, he's never broken one since.
HTH
terryh is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
