Old 12-22-2008, 12:33 PM   #6511
terryh's Avatar
Originally Posted by InspGadgt View Post
Taping the holes definately helps...I am guessing the BMI aluminum spacers also helps...they fit much tighter to the screw so I think they reduce the arm movement in impacts. I noticed in my old Darkside car with the plastic spacers I was cracking arms too...but when I switched to the BMI car with the BMI aluminum spacers it stopped happening.
I think the aluminium spacers are spot on greatly reduce the risk of bending the screws, it is still a weak point though but I have found that using the IRS .060 lowered arms are also good. Some mentioned earlier about using steel or titanium screws, I was advised that the alloy screws although a weak point act as a stress factor in a hit and save a lot more potentially expensive damage, so, I have stayed with the alloy ones to be safe. Best advise of all though, dont hit anything
terryh is offline   Reply With Quote
Old 12-22-2008, 01:06 PM   #6512
Terry,
Replied to your queris on racechat.
Jason Butterfield
jasonb is offline   Reply With Quote
Old 12-22-2008, 01:23 PM   #6513
protc3's Avatar
Originally Posted by terryh View Post
I raced my car on Friday night and it performed better than it had ever done before, the difference between fastest and average laps was about 4/10th sec and the car was very easy to drive consistently . I had previoulsy been using a setup more suited I think to a high traction surface, but we run on Prima Felt GT with a low to medium level of traction. Here's the setup I used.
Front
5deg blocks, 6deg static castor, 1.5 deg negative camber
Silicone lube on kingpins (it dries fully so nothing sticks)
1 deg toe out
Jaco 2x pink, 80% additive, 42 mm dia
4mm ride height, servo up, AE 0.020" springs
Rear
5000wt oil in side dampers, forward position on pod plate
Gold spring, 30wt oil in centre shock, 1mm spacer under forward ball stud (HB Shock)
Thin L plates, stock roll centres on all three balls
Batteries fully back
Jaco Yellow, full width additive, 44.5 mm diameter
4mm ride height, pod level, 1.5 mm droop
Nosram Matrix Evo 07 (2,4,0,0) Hacker 10.5 motor.
PF Speed 12 shell
This setup (for me) was awesome, but now I have just received my 'RR' conversion, any ideas on what, if any changes I should make to the setup.
And, what is the shock lenght needed to get 1.5mm of pod droop on the RR?
Jason, this car just gets better and better, keep up the good work
Im glad to see the car working well for you buddy. Thanks for the kind words.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-23-2008, 05:43 AM   #6514
AdrianM's Avatar
All the new BMI Big Wheel pinions 45T-60T are online and for sale now.
www.bmiracing.com
Adrian Martinez
Old 12-23-2008, 05:57 PM   #6515
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I actually had a discussion with Dave Irrgang about using the titanium screws in the IRS brand front arms. He explained the ti screws are slightly larger in diameter than the aluminum screws. This increases the chance of cracking the front arm, especially the front screw hole where the material is thinner.
While I'm posting, any suggestions as to what kinda setup changes to try when the traction starts to come up?
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-23-2008, 06:08 PM   #6516
Trader Rating: 8 (90%+)
Less reactive castor, glue tires, widen the front end, narrow the rear.
Johnny Carey is offline   Reply With Quote
Old 12-23-2008, 07:23 PM   #6517
xtrememadness's Avatar
Send a message via AIM to xtrememadness
merry xmas and happy holidays to the entire bmi family
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-24-2008, 02:23 PM   #6518
mike ivy's Avatar
Trader Rating: 50 (100%+)
Like to wish the BMI Crew and The Team A very Merry Christmas and a Happy New Year
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-24-2008, 02:45 PM   #6519
protc3's Avatar
Have a very Merry Christmas to all of you. I hope everyone has a safe and happy one.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-25-2008, 04:05 PM   #6520
racer x 1's Avatar
Trader Rating: 27 (100%+)
anyone know a good place to get a db12?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 12-25-2008, 04:16 PM   #6521
You can get them from BMI's website at www.bmiracing.com
Old 12-25-2008, 06:35 PM   #6522
finally i got my db12rr conversion kit!!! i love xmas
Old 12-26-2008, 04:39 AM   #6523
protc3's Avatar
Man, im tired. Im glad everyone had a nice christmas.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-26-2008, 09:11 AM   #6524
protc3's Avatar
Hey Guys,
For some reason i am having difficulty receiving emails at [email protected]. If possible, please send all emails to [email protected] with any technical info requests or questions.
Thanks and have a great weekend.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-27-2008, 10:48 AM   #6525
Uga
Uga's Avatar
So I want to lighten up my car a bit, I want to get aluminium screw set, so which one would fit best for the DB12RR - AE or CRC? Or maybe is there a better option than those 2?
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
