Old 12-19-2008, 05:00 AM   #6481
protc3's Avatar
Originally Posted by sportpak View Post
I have good luck with Nexus......
http://www.nexusracing.com/product_i...oducts_id=2395
The pics are rough, but this is how I'm gonna try the lipo. The battery will be taped in, and the receiver pack will taped to the battery. Wiring in the Deans plug really sucked and will take some getting used to, but it seems to all fit under the body. The receiver battery on the side helps balance the chassis, I still have to mount the transponder up in front of the servo too.Tomorrow night I'm going to try it.
As a note, you have to take the battery position bracket out of the car so that this battery will fit low enough to clear the shock. I made some aluminum "feet" that I shoe gooed into the battery slots to position this battery. Jason, you may want to fiddle with something like that. I don't have the time to make 100 of them, so consider that idea a gift.
Thats pretty awesome. I will hopefully have a lipo pack shortly. I will work on a locator.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-19-2008, 11:12 AM   #6482
DriftDreamer06's Avatar
looking for some advice. i am going to put a 19t checkpoint into my db12r and i am wondering what changes should i make in setup from the 27t.
the track surface will be carpet(club level) low traction early and higher traction later rough surface.
currently: angled servo, -1* camber, 1* out toe, 5* blocks 1 washer front and back, 30 weight, silver(?), thick sticks, 4 front 4 middle 4.5 rear 1 pod droop, lilca front white rear, batteries back, 42mm front 44mm rear(?)might be 44mm&46mm, shur lube 3 in tubes, ....
this was easy to drive others tried it out and said it was slow.
Racin'4-Fun
DriftDreamer06 is offline   Reply With Quote
Old 12-19-2008, 11:40 AM   #6483
AdrianM's Avatar
I just added the DB12RR and DB10RR rear pod conversion kits to the BMI web store. These just update the rear pod not the main chassis and are a great way to update your car for not a lot of $$
Adrian Martinez
Old 12-19-2008, 01:10 PM   #6484
chris moore's Avatar
Trader Rating: 85 (99%+)
Sweet, just the thing I needed to complete my order.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 12-19-2008, 04:22 PM   #6485
After getting my conversion kit and seeing the length difference in the rear pod it brought a question to mind...does the pod only conversion have the same length pod as the DB12R so the wheelbase stays the same?
Old 12-19-2008, 05:33 PM   #6486
AdrianM's Avatar
No it will make the wheelbase 1/8" longer with the old main chassis.
Adrian Martinez
Old 12-19-2008, 05:36 PM   #6487
are there stretch limo bodies available for pan cars ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 12-19-2008, 05:36 PM   #6488
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
So I'm guessing the new main chassis is shorter?
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-19-2008, 06:42 PM   #6489
AdrianM's Avatar
Its not shorter. Things were moved on it to maintain the balance of the car and the standard wheelbase.
Adrian Martinez
Old 12-19-2008, 06:51 PM   #6490
How/where does it get the additional 1/8"? I just ordered it but I still have the original 12r pod bulkheads; will this be a problem to bolt onto the new lower and top plates?
Chris
Sponsered by:
Old 12-19-2008, 06:58 PM   #6491
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
Originally Posted by xtrememadness View Post
that is correct. they are allowing it in stock with 17.5 nimh
wow, thats interesting. I dont have the guts to start racing at 360 now, because it feels intimidating. I bought my stuff a month before, and now im already at a disadvantage with my brushed setup and nimh
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 12-19-2008, 07:06 PM   #6492
RCSteve93's Avatar
We are all friendly at 360. We will get you up to speed. The Brownie's Hobbies crew has some dialed set ups for 360. I have a set-up, but I am taking a break from 1/12th until LiPo is figured out. With brushed and NiMh, you will actually be at an advantage. Brushed is lighter, and if you rebuild frequently and have a good motor, you will be much faster than a 17.5. LiPo in 1/12th still has is flaws IMO.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 12-19-2008, 09:45 PM   #6493
The main chassis plate is shorter but the complete chassis is the same length.
Old 12-19-2008, 09:49 PM   #6494
Chris
The lower pod plate is longer to give more room in the pod and improves the rear suspension geometry. So adding just the new pod to the original chassis will lengthen the wheelbase. The new chassis keeps the original wheelbase with the new pod.
Old 12-20-2008, 10:20 AM   #6495
Moderator
Clegg's Avatar
So does the DB10R have the same geometry advancements of the DB12RR? Or is there going to be a new DB10RR coming out soon?
My track is starting to ponder some WorldGT action and I figure since I already have a 12RR, might as well get a BMI 1/10th chassis.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
