Old 11-30-2008, 08:02 PM   #6226
I've noticed on mine the left to right front being off as well...I just put a rear axle shim under the low side on both screws and it worked just fine. Also check the pre-load on the springs...you might have more droop on one side then the other.
Old 11-30-2008, 08:13 PM   #6227
CraigM's Avatar
Trader Rating: 34 (100%+)
Thanks for the info. How do you measure the preload - do you just check the spring length with verniers?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-30-2008, 08:16 PM   #6228
By the number of shims on the front end. To check for a difference left to right lift one side axle and see if there is a gap between the lower arm and the steering block. If there is you'll have droop so you want to make sure both sides have the same gap.
Old 11-30-2008, 09:44 PM   #6229
Zdiddy's Avatar
Originally Posted by mrrcguy View Post
Yeah so BMI currently holds the 1/12th lap record at our local carpet track by four tenths!
And now ANOTHER BMI holds the new track record by 2 hundreths!!
Zdiddy is offline   Reply With Quote
Old 11-30-2008, 10:12 PM   #6230
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
And piloted by a total homo!
mrrcguy is offline   Reply With Quote
Old 12-01-2008, 07:05 AM   #6231
darnold's Avatar
Originally Posted by WIITA View Post
darnold, Were you using the new holes provided in the new flex plates or the original ones?
The new holes with no "tweak screws".
Team Top Racing USA,Team Pro One Tires, Team Speed Passion USA
darnold is offline   Reply With Quote
Old 12-01-2008, 08:21 AM   #6232
MrSlow's Avatar
Default New Kit
Jason I have sent you a PM
RR MANIA IS SOAKING INTO MY SKIN!!!
MrSlow is offline   Reply With Quote
Old 12-01-2008, 12:44 PM   #6233
Originally Posted by protc3 View Post
Hey Guys,
I got to run the car today on the rug and it was very impressive. The traction was low so i went back to the standard flex plate mounting(short) to gain initial steering. Its nice to be able to go back and forth like that. The car instantly stood out. I wound up getting 2nd in a very close field of fast drivers. I was real happy with that. Leon was super fast and would have won the main if his electronics didnt shut down. He was the fastest car on the track. Im glad he was running the DB12RR also.
I TQ'ed and won the World GT class. The DB10R was an absolute missile. I ran the same set of tires all day(Lilac spec tires) With almost no wear.
It was definitely a good day of racing. as many know mike boylan puts on a great show.
my car was absolutely awesome!! to say the least. I put it into complete cruise control with three minutes left in the race only to smoke a speed control with 25 seconds left to go DOH! crap happens though. however, I think a BMI wrapped up the FCC championship
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 12-01-2008, 12:50 PM   #6234
heres a little carpet setup info for you carpet guys as well
Front
.22 linear springs
5k pin lube
5 degree caster blocks**
1 shim in front and back of the block
flat servo
SHOCK
gold spring
700wt xray buggy shock oil = 50-60 wt assc/losi
one ball cup unscrewed bout 2mm from bottomed out
REAR
battery moved forward
std. flex plate mounting position
15k damper tube lube
33/88 Novak 10.5
Speed 12B light
purple fronts and grey rears
Jack the Gripper tyre dope
Leon McIntosh
Old 12-01-2008, 03:11 PM   #6235
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
What all does the DB12R to DB12RR conversion kit come with? Does it have all the new rear pod pieces?
Rfury is offline   Reply With Quote
Old 12-01-2008, 03:29 PM   #6236
New chassis plate, new lower pod plate, new upper pod plate, new chassis brace, and new flex plates.
Old 12-01-2008, 03:32 PM   #6237
Rfury's Avatar
So, if I want the lowered side pieces that lower the rear axle I would have to get those separately. I think I will stay with my DB12R for now and not upgrade.
I hope to get it on the track soon. Had to drop out of RC for a few months due to financial constraints.
Old 12-01-2008, 03:42 PM   #6238
JayBee's Avatar
Trader Rating: 31 (100%+)
I see you lurking Paul
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-01-2008, 03:43 PM   #6239
Yeah I don't think the lowered pod plates come with it...they really are not needed but are nice to have. If you are not yet running BL either you will be fine with the stock DB12R too...well either way you'll be fine with the stock DB12R...the RR just refines the design a bit.
Old 12-01-2008, 03:52 PM   #6240
Rfury's Avatar
I will be running the new SMC LiPo and a 13.5 most likely. I doubt I am good enough of a driver to worry about it. I doubt I could tell a difference. I can always upgrade parts as I break them.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
