Old 11-25-2008, 05:16 PM   #6121
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Originally Posted by DriftDreamer06 View Post
i am looking for a little help.
carpet track 40X80 rough(not a good tape down) and does not get a good groove?
i found a set up for carpet, but i am looking for what changes i should make for this track?
stock class(27t)
Thanks for input
Just a couple of guidelines to try. If the carpet is not smooth, get the ride height up a little more than normal. This will keep the chassis from dragging on the irregular surface. No groove, then try to maximize your traction without causing excessive drag. Just things to keep in mind when at the track.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-25-2008, 05:18 PM   #6122
RCSteve93's Avatar
Originally Posted by hanulec View Post
don't forget the 2mm hex driver for the left hand hub.
Hanulec you drive me nuts man... I have been using a 5/64... that is why my screws are stripped out.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-25-2008, 06:14 PM   #6123
hanulec's Avatar
Trader Rating: 27 (100%+)
nice! maybe you should spend less time hanging out at the Losi touring car table . i know Jason and IRS sell replacement screws. i think i have some - stop by the next time your at the track...
Schreff - hopefully you will make it out to the ROAR Region 1 Carpet Regionals at 360.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-25-2008, 08:30 PM   #6124
Trader Rating: 8 (90%+)
ygpm jason-
Johnny Carey is offline   Reply With Quote
Old 11-25-2008, 08:37 PM   #6125
gubbs3's Avatar
2mm is only 6 ten thousandths (.0006") larger than 5/64. You shouldn't have a problem unless you constantly use the driver at an angle when a Jaco wheel is still attached.
gubbs3 is offline   Reply With Quote
Old 11-25-2008, 08:39 PM   #6126
Yep, I bet if you measured a 2mm tip its the same as a 5/64 tip.
Old 11-25-2008, 09:35 PM   #6127
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Originally Posted by CraigM View Post
Got the metric stuff covered, wish the whole car was metric - when will people see the light
Has anyone fitted the 7.4v lipo to their BMIs? I know the US looks like its heading the single cell lipo route but here in Oz with basically nothing but asphalt tracks 12th isn't really seen as an entry level class so there isn't as much of a movement to slow them down and there is a bit of support for the 2 cell/17.5 route
I posted some pics of my car with a 2cell a few pages back.
mrrcguy is offline   Reply With Quote
Old 11-25-2008, 11:16 PM   #6128
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I am looking to switch from my AE 12R5 to the DB12R. I am curious however, I love the front suspension of the S120, does anyone know if the Serpent front end will fit on the BMI?
Also, Jason, if I order from your online store, does the kit come with the latest offerings?
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-25-2008, 11:28 PM   #6129
I haven't seen one first hand but from the pics it looks like the screws are smaller and wouldn't work. The S120 front end is pretty but sure looks heavy. The CRC front end is setup much like the Serpent design and bolts right on if you want to go with a pillow ball type suspension. Also it is easier to change the caster shims on it. Right now I am messing around with the CRC front end on my car using the long upper suspension arm conversion and it is working very nicely. That said the AE/IRS front suspension that comes with the car is pretty awesome in itself.
Old 11-26-2008, 12:25 AM   #6130
Uga
Uga's Avatar
You can actually get a metric screw set for your BMI, but I wouldn't want to go over the whole car re-tapping all threads..
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 11-26-2008, 03:30 AM   #6131
Default part number question
Originally Posted by protc3 View Post
Kits have been shipping out all week. If you can, give a buzz to the shop and my wife can take all of your info. Both conversion kits and car kits are in stock.
Hi Jason what is the part number for the conversion kit?
drover is offline   Reply With Quote
Old 11-26-2008, 04:15 AM   #6132
level-4's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to level-4
hey Jason
i'm getty ready to switch over to the RR upgrade kit and have a question, do you add weight to offset the weight of the speedo. i noticed on your photo you don't have any.
X6 | X60 | SC10 | Ve8
level-4 is offline   Reply With Quote
Old 11-26-2008, 05:01 AM   #6133
protc3's Avatar
I didnt need to add weight with the LPF speedo. With the regular GT speed i had to add a 1/4 oz.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-26-2008, 05:01 AM   #6134
protc3's Avatar
Yes. All of the 1/12th cars being sold now are the updated versions.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-26-2008, 05:03 AM   #6135
protc3's Avatar
The Part # is DB1001
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
