Old 11-20-2008, 04:41 PM   #6046
protc3's Avatar
Originally Posted by Johnny Carey View Post
Let me know when that package is ready Jason-
Should be tommorow buddy. I will shoot you an email
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-20-2008, 04:41 PM   #6047
protc3's Avatar
Originally Posted by SpraydbySprague View Post
Santa showed up early!
Got the parts spread all over my bed.
To heck with it!
I'll sleep on the floor!
You got PM. (well not quite yet, I gotta type it)
Thats awesome bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-20-2008, 06:36 PM   #6048
Hey Jason,
Just sent ya an e-mail for our order. Let me know if you don't get it and I'll PM it to you.
Old 11-20-2008, 06:42 PM   #6049
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Does anyone have a setup for 17.5 for a low to medium grip track?
CarlosG. is offline   Reply With Quote
Old 11-20-2008, 07:03 PM   #6050
darnold's Avatar
Yeah, packages are going out...the new updates are here. Can't wait for mine to come in..Christmas...early style. Thanks Jason, these updates are the bomb.
Team Top Racing USA,Team Pro One Tires, Team Speed Passion USA
darnold is offline   Reply With Quote
Old 11-20-2008, 07:06 PM   #6051
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey CarlosG.
Try This:
Front:
Jaco prizms Purple
.20 front spring
#4 shur lube Lube on the Kingpins
1* Camber
0* toe
Center shock 35-40 weight try a blue spring (car may push) then go to a gold spring.
Battery position: Start out and the rear position it helps with rear traction but the trade off you may lose alittle on power steering.
Try 3# or #4 Irrgangs shur lube
Rear
Jaco Yellows you might what to true your (Rear) tires a little larger because a smaller size wont hold the traction as well.Also play with your rear track width go to a narrow width and see how that goes.
Lower your rear ride hide slightly heres a example:
front ride hight 4mm rear 3.5mm lowering the rear helps gain some traction
You may also want to try out a high down force body protoform speed 12 or a parma HD or a zytec body.
I think thats it if I missed something let me know
Hope this helps
Mike
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 11-20-2008, 07:07 PM   #6052
protc3's Avatar
Originally Posted by InspGadgt View Post
Hey Jason,
Cool, thanks buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-20-2008, 07:12 PM   #6053
CarlosG.'s Avatar
Thanks Mike, but I forgot to mention that it is an asphalt track. We race outdoors all year round weather permitting. Now the track is getting cooler and traction is alittle less than when we raced during the heat also it gets dusty once in awhile due to the winds blowing.
Old 11-20-2008, 07:37 PM   #6054
protc3's Avatar
Originally Posted by mike ivy View Post
Hey CarlosG.
Try This:
Front:
Jaco prizms Purple
.20 front spring
1* Camber
0* toe
Rear
Hope this helps
Mike
I run this setup somewhat on asphalt. I run magenta fronts with 2x pink rears,1.5 degree camber,35 wt. oil with gold spring,Everything else is about the same. I run 1.5mm pod droop.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-20-2008, 08:15 PM   #6055
CarlosG.'s Avatar
Again, thanks guys for the help. I will try this setup this wekend. I just need to know what the voscocity equivilance is the shurelube to diff lube.
Old 11-21-2008, 02:40 PM   #6056
protc3's Avatar
The most common bottles of surelube you will find yourself using is #3 and #4. #3 seems to be similar to maybe 15,000 and #4 is more like 20,000. I could be wrong but that is what it seems like to me.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-21-2008, 04:41 PM   #6057
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Jason, YGPM
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-21-2008, 07:58 PM   #6058
gubbs3's Avatar
Last weekend I ran on some carpet that hadn't been run on for a year+ after it was pulled up from being glued down. Traction was terrible until the main with a preset groove that pulled the car around. By the main my car was absolutely dialed. I ran:
Front:
Old style Jaco purple 1.60"
4mm ride height with .010 droop
.020 spring (AE style)
5000 kingpin lube
1.5 camber
0-.5 toe out
10 blocks both shims back
Rear:
Jaco Prism Gray 1.70"
IRS 3.5 ride height spacers down ~3.75mm ride height
Center shock 40wt, red spring, 2mm droop
Battery one position back from full forward
Stock flex plates
7000 in the tubes
Parma Speed 8 lightweight
This is for a Jack only track. Coat front tires 3/5 inside and full rear for as long as possible (about an hour). First ever TQ and first ever win racing with this crowd. This is with the original version of the car btw.
Hey CarlosG.
Try This:
Front:
Jaco prizms Purple
.20 front spring
1* Camber
0* toe
Rear
Hope this helps
Mike
gubbs3 is offline   Reply With Quote
Old 11-21-2008, 08:30 PM   #6059
RobS's Avatar
Well tonight was the first official race with the DB12R. Set TQ with a new track and lap record and won the A-main! Very happy with the car! Although in the main I had one spectacular crash and chipped the chassis right behind one of the battery slots. Kind of weird but still run able.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 11-21-2008, 09:42 PM   #6060
Congrats dude!
Just finished building my DB12RR. What a terrific kit. Easy to build, excellent fit and finish. I'd have to say the last time I built a car this well made was my X ray T1 Evo2. Jason was a big help in gettin me pionted in the right direction with what spares to buy. If anyone is thinking about picking up the new Silva shock BMI sells, GO FOR IT! Easy to build and smoooooooooooth. Gonna put the car on the track 1st time tomorrow. Looking forward to some fast laps.
Three words...
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
