One thing I really like about this design that I haven't seen mentioned yet is the rear pivot mount is bolted to the rear pod and not to the chassis like all the other link cars...why does this matter you ask? Well with the pivot mount bolted to the rear pod it then moves with the rear pod. So you can move the motor all the way foward and not have to worry about it rubbing on the pivot and causing binding or tweaking.
i also forgot to mention that the rear pivot balls are broached to fit a hex wrench to allow you to tighten them down during assembly.
Jason Breiner
BMI Racing
www.bmiracing.com
DB12RR lipo edition cars now available
i will need to look into that.i want to include as many high performance things that i can that will actually improve the cars performance.this may be an area where i need to sacrifice to keep the cost down.to bevel the battery slots like i have done on all my kits in the past will require an extra operation with machining.if i have room i will do it but with all of the expensive upgrades i am putting in the kit it may be tough to include that.i will try though
Jason Breiner
BMI Racing
www.bmiracing.com
i am developing new servo mounts that will allow you to run the servo flat or angled.the car will come with my asphalt setup and the carpet setup we used for testing.both setups work extremely well.i will put together some pics tommorow to go in depth with an explination on our new rear suspension system.it is very unique and is extremely durable.my car has not seen a tweak station since february and is still tweak free.
Hey Jason,
will these servo mounts be availible seperatey, if so I would like a set, along with the rear pod.
Xray 007 Euro, Much More Racing Andy Moore Edition Pit Equipment, Futaba 3pks 2.4ghz Fasst System, Novak, Team Brood Motors
