Old 11-15-2008, 05:31 PM   #5956
protc3's Avatar
Thanks for the video mike. That was awesome.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-15-2008, 05:31 PM   #5957
protc3's Avatar
Originally Posted by lorider75 View Post
I have found parmas to be the cat's meow.
The two of us with db12's run magenta front and rear and the car is wicked. granted Jason told us what we should be doing for set-up and thats what we are using with little tweaks here and there for driving style.
The only problem i have encountered with the parmas is breaking rims. That was when getting "tapped" at full clip going into the one high speed corner and it resulted with hitting the wall,not the boards, about 4ft of the ground. Surprisingly the rim was all that broke and the car never tweaked. Lets see you t-bar or link guys do that! lol
Might hafta look into the "update" kit after x-mas.... maybe santa will deliver it with a new brushless motor and controller???
Very cool
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-15-2008, 05:43 PM   #5958
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jason ygpm Bro
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 11-15-2008, 05:58 PM   #5959
spurcheck's Avatar
My second season running the car. Irrgang, Mike Ivy and Schreff turned me onto it. Very impressive with the rear pod improvement. Keep up the good work.
The Punter or The Punt-ee,,,,,,,,,,,,,,,,,,,who you be??
HORSHAM, home of the ROAR carpet nationals,,,again!
No Apologies Racing, don't believe me, try me!!!!!
spurcheck is offline   Reply With Quote
Old 11-15-2008, 06:10 PM   #5960
protc3's Avatar
Thanks buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-15-2008, 06:25 PM   #5961
Originally Posted by hanulec View Post
Swampracer - be careful w/ Jaco Yellow rears. they will unglue from the rim after one run. you need to apply a small amount of CA between the rim and foam on the outside edge of the tire. i end up switching rear tires every run when i run yellows and re-glue the tires i took off and let them dry before using them again (heck - i just make sure to have enough tires to one run them for a race day/weekend)
Great video thanks!
I have the same thing happen with Magenta and Dbl Pink tires which is one of the reasons why I make sure I have 1 set of tires for each run I do. That way I get a chance to re-glue tire edges before the next race which if you don't do is going to give you major chunking.
Old 11-15-2008, 06:28 PM   #5962
Originally Posted by xtrememadness View Post
or you can just run parmas and not have that problem sweet video mike. i love watching myself bounce off the boards i was sleeping during that main
I haven't tried the new parmas yet but have found that every brand I've tried has eventually had this problem...some just faster then others. The only tires I had which really held up well were the ones I mounted myself. Probably because they were not mass produced I took more time to do the little things that helps the glue hold better. With the cost of pre-mounts now though I don't bother with mounting my own.
Old 11-15-2008, 06:31 PM   #5963
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey chris. yes the offset is different. with the parmas you need 3 to 4 gold shims per side to bring you to 172mm. with the new conversion we are only gonna need like 1 shim on the right and 2 or 3 on the left or the other way around. schreff showed me on his car but i forgot
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 11-15-2008, 07:12 PM   #5964
chris moore's Avatar
Trader Rating: 85 (99%+)
Hmm. cool thanks.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 11-15-2008, 07:16 PM   #5965
Did Schreff have the new off-set hub on his car? If you'll notice in the pics Jason posted he has his normal 3mm spacers on both sides of the car so at least on that car the spacing should be the same on both sides.
Old 11-15-2008, 08:24 PM   #5966
schreff did have the new hub. good point
Old 11-15-2008, 08:40 PM   #5967
schreff's Avatar
Send a message via AIM to schreff
I had 1 gold shim on the RR and 2 gold shims on the LR. The overall rear width on my car is 171.44mm. I need one more thin washer to truly push it to 172mm.
And Hanulec, you just had to show me blow out about 2 minutes in, didn't ya. That first minute was tough dodging traffic with Dave G on my rear bumper. That was a fun main.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 11-15-2008, 09:03 PM   #5968
RobS's Avatar
So what is everybody running setup wise for carpet? I finally got my car ready to rock, just need to set the car up... Tire wise I'll be running double pink/yellow, any recommendations on where to start out?
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 11-15-2008, 09:23 PM   #5969
schreff's Avatar
Here's what I ran this past weekend at 360 Raceway with the updated car...
-Front-
4 deg caster
5 deg reactive blocks
-1.25 deg camber
.020 BMI spring
.010 spring sag
#3 SureLube on king pins
servo on angled mounts (gonna try flat next time out)
Parma Magenta tires (41.6mm)
-Rear-
Hot Bodies shock w/ Losi 40wt oil and ASC gold spring
ASC shock mount raised with 2mm shims and medium ball stud on shock mount
shock all the way back on chassis
battery full forward
.070 side plates
#4 SureLube in damper tubes
Parma Grey tires (43.6mm)
Use whatever shims/ride height adjusters to get 4mm ride height. I also ran a Parma Speed 8 LW body since I was running 17.5.
-Jason Schreffler-
Old 11-15-2008, 10:15 PM   #5970
hanulec's Avatar
Trader Rating: 23 (100%+)
don't worry, i have a few of the qualifiers on tape where you were putting down solid runs. at least you didn't eject yourself twice in the main, in the same spot -- i have commitment to my line! maybe worse yet i captured on tape Dave G's electronics falling apart -- i cannot believe his batteries become unsoldered otherwise he had everyone by at least a lap in the main.
also, i just posted you taking down the 13.5T foam A-main. it should be processed by youtube w/in the next hour...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
