Old 11-10-2008, 06:48 AM   #5851
schreff's Avatar
Send a message via AIM to schreff
Hi guys!
Just thought I'd chime in after a busy weekend at 360 Raceway.
As everyone else has said so far, the changes Jason made to the DB12R have definitely improved the handling of the car. The setup I used on the car was actually more of a conventional setup than what I used at SnowBirds. The car was VERY smooth and very easy to drive. I still do have to work on fine tuning some things to my liking, but that'll come with more track time.
It was also fitting to be able to mix it up with the likes of Donny, Jari, and Dave G. They were all quick and made the racing exciting.
Anyway, you guys won't be disappointed with the update. The changes really did help the car.
And no, the car I ran at Cleveland was not the UPDATED car.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 11-10-2008, 07:32 AM   #5852
EricF's Avatar
Originally Posted by protc3 View Post
... You can send your chassis back to me and i will add the new front mounting holes for the flex plates for $10.00 so you can now use the linear position. ....cool:
If that does help convince anyone to run this Chassis over ther other what will. I've been in a out of this sport for 15 years and I don't recall ever seeing anything like this from a chassis manuf.
Great job and support!!
E
EricF is offline   Reply With Quote
Old 11-10-2008, 08:33 AM   #5853
protc3's Avatar
Thanks buddy. I dont want to see anyone feel like they have to spend more money if they dont have to.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-10-2008, 08:42 AM   #5854
E
The only thing that comes to mind that is similar was when Trinity would mill out battery slots and a hole to lower the motor in a Losi Streetweapon chassis back before Losi did it themselves on the IWC version of the car. I think it around $20 per chassis to have them milled out.
Serzoni is offline   Reply With Quote
Old 11-10-2008, 06:16 PM   #5855
Jason,
In your opinion is a "gear ratio a gear ratio" or does running different size spurs give you different results in terms of torque? Assuming the rollout is exactly the same in all situations.
Hope that makes sense...
Jeremy
Jeremy Otis is offline   Reply With Quote
Old 11-10-2008, 06:36 PM   #5856
I've heard this in the past that a bigger spur will give more torque because it has more leverage on the axle and that a smaller spur will be higher top speed due to the smaller mass of the gear. Personally I think the torque theory cancels itself out. I'd have to do the math to figure it out for sure. Think of it this way, yes a larger spur is going to have more leverage on the axle but to keep the same roll out or gear ratio means going to a bigger pinion as well, and the motor is going to have a harder time turning the bigger pinion. My guess is that the 2 cancel each other out.
On the flip side a case can be made that a smaller spur will give you both more top end and torque due to it's lighter mass makes it easier to spin. But then the same question comes into play...does the effect of the reduced mass outweigh the reduction of leverage from the gear.
Even if they don't cancel each other out, any gain would be so minor as to be nearly indetectable...Anyway that's my theory
Old 11-10-2008, 06:44 PM   #5857
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jason
Sweet!!! great news, cant wait to get one for sure
Originally Posted by schreff View Post
Hi guys!Just thought I'd chime in after a busy weekend at 360 Raceway.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 11-10-2008, 06:45 PM   #5858
RCSteve93's Avatar
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-10-2008, 07:04 PM   #5859
protc3's Avatar
Originally Posted by Jeremy Otis View Post
Jason,
Jeremy
I understand what you mean. Gear ratio is gear ratio to an extent. You can get the same gear ratio with a 100 spur as you can with an 88 but the larger the pinion(that you need with a 100 spur) will make the motor freewheel so to speak and have the effect of a large flywheel. This helps keep up your corner speed. I always try to run the largest spur i can that will allow me to achieve my desired rollout.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-10-2008, 07:05 PM   #5860
darnold's Avatar
New Parts, New Parts, New Parts.... Jason you have done it again!!! The only question for me good buddy is when can I get my 'grubby lil hands on them".
Great to hear about how well they worked and congrats Schreff on another great race!! Please tell Yari that he better be back at the Carpet Nats in March at the Gate and that I said hi.
Team Top Racing USA,Team Pro One Tires, Team Speed Passion USA
darnold is offline   Reply With Quote
Old 11-10-2008, 11:54 PM   #5861
The larger you can get both the spur gear and the pinion, the more efficient the drive. Large spur/pinion combinations allow more teeth to be in contact, so sharing the load and reducing the angles of approach and departure of the teeth. This is also what you see as Jason's 'freewheel' effect - it is a smoother mesh so it will roll better.
However - the larger the spur and pinion together, the larger the rotating weight and so the slower the acceleration of the drive train. For our purposes, this can be ignored, and the weight difference is very small compared to the overall weight of the rear axle in total.
The leverage effect of a large spur is a spurious argument. These are rotating forces, not linear ones, and the 'leverage' is about the ratio itself, not the sizes of the spur and pinion. If your surmise was correct, a vehicle gearbox would be twice the size to take advantage of this effect!!
The advantages are miniscule, ceratinly less than one missed apex or one clipped corner marker. Find a ratio that works using what you have in your box and drive better - that'll get you the results!! HTH
SlowerOne is offline   Reply With Quote
Old 11-11-2008, 03:25 AM   #5862
Well like I said the advantages or disadvantages pretty much wash themselves out...leverage may not be the proper term but the effect is the same which is why people claim to have more torque with a larger gear. The force applied to the tooth of a gear is essentially perpendicular to the radius of the gear. So if you think about it as the tooth being a lever arm used to turn the axle then you can see how the longer lever arm is easier to turn the axle, hence the thinking that a large spur gear gives you more effective torque then a smaller one.
But again as I said what really matters is the ratio itself...getting the same ratio with a small spur gear or a large spur gear is so minimal in difference that you really won't be able to notice it.
Old 11-11-2008, 05:11 AM   #5863
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
So lemme see if I got this right. If the larger gears roll better, then the car will maintain more momentum off power, requiring less throttle and energy to get back up to speed. Is this where the efficiency comes from?
SpraydbySprague is offline   Reply With Quote
Old 11-11-2008, 08:32 AM   #5864
protc3's Avatar
Hey Guys,
Here is a few pics of our updated parts on a car that is all wired up for brushless so you can see how neat the wiring can be with the new layout. Also enclosed is a pic of the new silva bladder shock that we are now carrying.
BMI's DB12R-db12rr1.jpg   BMI's DB12R-db12rr2.jpg   BMI's DB12R-db12rr3.jpg   BMI's DB12R-silva-shock.jpg
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-11-2008, 08:39 AM   #5865
darnold's Avatar
SWEET Pic's!!!!
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
