Old 10-18-2008, 06:24 PM   #5641
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey steve i have no idea how to get the pics over here
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 10-18-2008, 10:47 PM   #5642
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by InspGadgt View Post
He's having a problem with the tie rod hitting the upper hinge pin not the servo hitting the lower arm.
As Jason said you want the tie rods straight or a little foward but shouldn't be so far foward that they are hitting the upper hinge pin. If they are then either your servo is too far foward or you are running the ball studs on the front of the servo saver instead of on the back. There are 4 holes in the chassis where the servo mounts, 2 on each side of the servo. There are also 2 holes on the bottom of each servo mount. This gives 4 combinations of how far foward or back the servo can be mounted. Different servos have different heights so your servo may not fit right in the exact holes the instructions say. Move your servo back until the tie rods are as straight as possible. The furthest back would be the 2 back holes on the chassis and the 2 foward holes on the servo mounts. That should move the tie rods far enough away from the upper hinge pin so that they don't hit except at extreme steering which you shouldn't be using that much anyway.
Explain where these are
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-18-2008, 11:04 PM   #5643
If you look at step 12 of the on-line manual you will see 2 sets of servo mounting holes. Step 25 further explains these.
Old 10-18-2008, 11:10 PM   #5644
JayBee's Avatar
I have to check that out but....can you see these from the bottom of the chassis?
Old 10-18-2008, 11:32 PM   #5645
JayBee's Avatar
I get it now, you were trying to say that there are 4 holes on one side of the SERVO MOUNTS & 2 holes on the other side
Plus the 4 holes on the bottom of the chassis for the servo mounts.
Old 10-19-2008, 12:15 AM   #5646
Well you get the idea...2 holes on the bottom of each servo mount and the 4 holes in the chassis...I didn't really address the holes that the servo itself mounts to...just where the mounts bolt to the chassis.
Old 10-19-2008, 04:27 PM   #5647
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jason ygpm question for ya
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-19-2008, 07:37 PM   #5648
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
I have a question about the shock oil being used. What is the reason for the heavier weight oil (35wt) used in this car compared to a 12l4 maybe 20 to 25 wt)?
CarlosG. is offline   Reply With Quote
Old 10-19-2008, 11:03 PM   #5649
JayBee's Avatar
Sure do, thanks bud Sorry, I was confused.
Old 10-20-2008, 12:12 AM   #5650
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
Hey CarlosG,
Because the car has a lot of grip at my track, I use heavier oil to carry more corner speed.
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
Old 10-20-2008, 11:50 PM   #5651
Couple of new things I'm playing around with on my DB12R If all goes well I'll get to test them at this weekend's race
Old 10-21-2008, 04:34 AM   #5652
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
The other reason is that the car does not use a T-plate for front to rear suspension thus requiring heavier oil to help hold the car up.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-21-2008, 10:40 AM   #5653
chris moore's Avatar
Trader Rating: 87 (99%+)
I'll bet that you'll really like the way the CRC frontend feels gadgt. I like it alot, just check the kingpin every couple of runs. It has a tendency to work loose every so often.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 10-21-2008, 11:14 AM   #5654
Well personally I don't like pillow ball type suspensions...and there some other minor design issues I have with it on principal. But even with the upper arm still a hair tight the suspension feels super smooth and dead level from what I can tell initially. I'm still waiting for bearings to check the ride height left to right.
Old 10-21-2008, 12:37 PM   #5655
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Velco?
Like to see more pics of that....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
