Old 10-06-2008, 05:45 PM   #5551
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey steve, glad to see the setup changes worked. your car looked real good on sunday. i will bring the thin plates ,linear springs and king pins for you sunday. the car will be even better. hey jason thanx for the continued support with the car and just in general. we all appreciate it very much its also great to have a track like 360 with the kind of support and friendship we get there. so we wont hold it against them for running speed merchants. hey steve we will show em how its done on sunday, bmi style
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 10-06-2008, 05:51 PM   #5552
Originally Posted by protc3 View Post
it may be sooner. Im giving myself a window.
Open the curtains just a smidge so I can see in
OMG I'm sounding line a on-line car peeping Tom!
Old 10-08-2008, 11:44 AM   #5553
Uga
Uga's Avatar
Anybody has a good setup for a fresh CRC carpet and a large track..? I won't have much track time before the races
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-08-2008, 12:43 PM   #5554
RCSteve93's Avatar
That sounds awesome Craig. And that is my mission... to show everyone how good the BMI really is.
RCSteve93 is offline   Reply With Quote
Old 10-08-2008, 01:36 PM   #5555
protc3's Avatar
It was good enough to finish ahead of all the link cars at the snowbirds without any issues. It was a very close race between a DB12R and a T bar car. It could have went either way. This car is capable of winning at any level and has proven that. We just dont bother going with a big team to prove it. I prefer to have a happy customer base than a big payroll of team drivers. Products should speak for themselves.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-08-2008, 01:38 PM   #5556
protc3's Avatar
Here is what i run on carpet. If the front tires gum up, go to black fronts until the fuzz goes away. This is with Jack the gripper compound.
Front:
10 degree reactive castor blocks w/ 6 degrees castor(2 shims to back of
arms)
.020 linear front springs
5000 wt diff oil on kingpins
purple front tires cut to 1.650
1 degree camber
Servo flat with medium ballstuds on steering blocks
3.5mm ride height
I remove 2 kingpin shims to accomodate the linear front springs
sauce 1/2 the inside of the front tires
Rear:
Red center spring w/ 40 wt. oil
batteries forward position
20,000 wt. in tubes
3.5mm ride height
1mm pod droop
gray rear tires cut to 1.750
pod level at all 4 corners
172mm rear width
speed 12 body
let me know if i missed anything.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-08-2008, 06:26 PM   #5557
jason, you forgot the side plates. thick or thin. and when you say you remove 2 shims for the linear springs is that on the stock king pins or are you using the long 1/10th king pins
Old 10-08-2008, 07:13 PM   #5558
protc3's Avatar
I use the stock flex plates. I am using the stock kingpins.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-09-2008, 02:03 AM   #5559
Uga
Uga's Avatar
thanks, will try it out next week
-=Xray XB4=-
-=Xray T4=-
Racing in Latvia
Old 10-11-2008, 09:15 PM   #5560
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Well, I can now finally say that the DB12R has finally got the podium finish in San Antonio,TX. I had the worst day with it. I could not get rear traction during the last half of my quailifers except my last qualifer. The track was loose. I ended up going to a Delta silver spring which a fellow racer had from his days driving a Delta car, and using about a eigth of a can of Paragon to get it to hold for atleast 3/4 of the race. I really had no plan of getting first. I decided to play with the guy in front of me, then decided to just follow him as close as I can without getting into trouble till he spinned out in the 18th lap and that allowed me to take the lead from their where I just was finally relaxed cause I knew everytime I get into the lead I would screw up.It always happens like clock work for me except this time. The second place guy was .3 of a second behind me as we crossed the finish line. So right now I am a happy camper.
CarlosG. is offline   Reply With Quote
Old 10-11-2008, 09:31 PM   #5561
Well I have me a Speed 8 HD mounted on the car this time and will be trying that out tomorrow. I'm guessing the vents in the front are meant to act like a diffuser and lower the air pressure under the front of the car to create more front down force. I only cut out the middle 2 vents because the ones over the wheel well are so thin I'm not sure they are supposed to be or not. Looked like too much of a chore to even try. The angle molded into the 2 I did cut out make it a real pain to cut them out. If anyone figures out any tricks in cutting them out let me know. If this body works out this race I'll be switching to it full time. I really like the look of this body. If not there's always the Speed 12B to go back to
Old 10-11-2008, 10:16 PM   #5562
Scottrik's Avatar
Trader Rating: 243 (100%+)
Front:
arms)
1 degree camber
3.5mm ride height
Rear:
20,000 wt. in tubes
3.5mm ride height
1mm pod droop
172mm rear width
speed 12 body
Hey J--is this a Stock or SuperStock (or both) setup?
What would you adjust on a non-Jack setup? Tire compounds, or...? I use Niftech which I find to be pretty interchangeable, handling-wise, with Paragon. Just can't find myself digging Jack...
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-12-2008, 03:08 AM   #5563
protc3's Avatar
That setup is for 10.5BL. The car was extremely fast. I wouldnt make any changes until you try it. I havent tried the niftek so i really cant say. Let me know what it does for you and i will make suggestions.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-12-2008, 03:10 AM   #5564
protc3's Avatar
Great to hear bro. If you need a hand getting rear traction,send me the car and i will give it a once over to see if i find anything odd with it. I really have never had a rear traction issue.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-12-2008, 05:34 AM   #5565
Trader Rating: 61 (100%+)
Have you tried a lower shore compound in the rear yet? What brand and shore are you using for front and rear tire combo's?
I have the same setup as Jason and minor changes with no problems. I use 30K in the tubes, dry kingpins, and Twister Tires instead and the car is perfect on my carpet track.
fav0re is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
