Old 09-28-2008, 12:07 PM   #5521
JayBee's Avatar
Trader Rating: 31 (100%+)
I'm still fine tuning my high-bite/med. size asphalt track set-up guys; I've switched to 13.5, so give me a few days
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-28-2008, 12:47 PM   #5522
tdu verney's Avatar
Default 12th Scale @ Mike's
Jason,
Thank you for the tire conversion.
Yang,
I apolagize for punting you off the track.
The DB12R goes on...
tdu verney is offline   Reply With Quote
Old 09-28-2008, 12:59 PM   #5523
Personally I prefer the Corally 12X ceramic thrust race to the Slapmaster one, you do need to get a smaal (2mm) spacre machined down to if it though.
Jason
jasonb is offline   Reply With Quote
Old 09-29-2008, 03:33 PM   #5524
JayBee's Avatar
Originally Posted by Scottrik View Post
Hey JB,
The Niftech diff lube is my favorite. Particularly in the syringe.
As indicated in the previous post, the Slapmaster diff kit bolts right into the DB12R.
I think so too but Schumacher's diff lube is a VERY CLOSE 2nd Does that Slapmaster thrust work THAT good?
Old 09-29-2008, 03:50 PM   #5525
chris moore's Avatar
Trader Rating: 87 (99%+)
I'v been using one for about a yr now, have'nt replaced the outside bearing in that time. The only downside to the Slapmaster; imo; is that it seems to have a fairly small window of adjustment. But once you have it set, you just forget about the diff, very smooth. Its possible to get the same feel without it but not for the length of time it provides.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 09-29-2008, 07:05 PM   #5526
xtrememadness's Avatar
Send a message via AIM to xtrememadness
jason, would it be possible to get some rear axle shims made up for the parma wheels. i keep droppin all those little ones thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 09-29-2008, 07:14 PM   #5527
Old 09-29-2008, 08:31 PM   #5528
RCSteve93's Avatar
You can count me in for a set... of shims.
RCSteve93 is offline   Reply With Quote
Old 09-30-2008, 04:03 AM   #5529
protc3's Avatar
OK, I will work on a set for the parma wheels. I should have some real cool things available very soon.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-30-2008, 09:30 AM   #5530
I can now appreciate all the hype about the bmi front shim set. I just finished assembling the kit and thought i would mess with setting the ride height. definitly not as easy as i thought. Add shim, too much.Take away shim not enough. This is using the plastic shims that came with the kit.
I guess I need to get the shims sooner, rather than later.
skink is offline   Reply With Quote
Old 09-30-2008, 04:23 PM   #5531
cool jason. looking forward to it. always worth the wait
Old 09-30-2008, 04:27 PM   #5532
RCSteve93's Avatar
Jason I really appreciate it.
Old 10-01-2008, 11:31 AM   #5533
So when we going to hear more about this new cool stuff your working on?
Old 10-01-2008, 06:55 PM   #5534
WIITA's Avatar
Trader Rating: 42 (100%+)
Default rear axle
Hey there guys. I am putting my car together and I was doing some reading in the instructions that the large boss on the clamping hub is supposed to be facing in toward the bearing but on page 70 of this thread jason says to have the small boss facing the bearing. I am confused because I think I have a new manual which came with the SE car it says to have the shallow center boss out toward the wheel meaning the large boss would be facing the bearing. Anyone know what way its supposed to be? any help would be great thanks.
WIITA is offline   Reply With Quote
Old 10-01-2008, 06:58 PM   #5535
protc3's Avatar
You want the small boss facing the bearing. The instructions need to be changed. Sorry for the confusion buddy. We started running this way to make it so you use the same shimming left and right and still have the axle centered.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
