Old 09-15-2008, 05:15 PM   #5416
radio_car_racer's Avatar
Default UK Nationals R1 / Chesterfield
Had chance to run again at the weekend
here's a summary from my Chesterfield National
Red = change from last time out @ this venue
19T SPEC & 10.5 BRUSHLESS
FRONT
BMI .22 Linear Springs
No Oil on kingpin
3.5mm Ride Height
5' Castor blocks / teflon washer either side
Camber, set run foams flat
0' Toe
Laid Down Servo / Sanwa 141
REAR
C12 Hot Bodies Shock / Hara Medium spring / 35wt Oil
Shock Length to give approx 1-1.5mm pod droop
Kit ball studs plus 1mm shim on motor pod
0.070 flex plates (DB3010)
Tubes in rear position / 5000wt Oil in tubes
3.5mm Ride height
172mm wide
MISC
front tyre Jaco purple
rear tyre Jaco grey
CS Tyre Additive, Full front/rear
Cells Orion SHO 4200 = Middle
Hot Bodies HB61731 - C12 Mark-2 / Black Art Audi R10
Nosram 10.5BL on 58mmpr (or there abouts)
Steering exp @ 15%
Ran the HB C12 Mark-2 for 3 rounds on Sat with Purple/Grey foams and full addy front and rear. To much front end so dialled out dual rate. Round 4 & final switched to Audi R10. Car was poooooooo all day yet was keeping pace with those of similar ability as raced against at the SSO R3. Car was just to iffy. Didnít know Roger M was spotting for me and trying to help. Thanks Roger. Listend to him & PDW but got no were with car.
Sport & Open Modified
FRONT
No Oil on kingpin
3.5mm Ride Height
0' Toe
REAR
Tubes in rear position / PDW 5000wt Oil in tubes
3.5mm Ride height
172mm wide
MISC
front tyre Jaco Purple, Lilac, Double Pink
rear tyre Jaco Grey, Pink, Yellow
Additive NON, all day
Cells Cells SHO 4200 & Energ 4600 = 2/3rdís to rear
BlackArt Audi R10
Steering exp @ 20%
Had a sleepless night thinking about setup.
Woke up Sunday and had a idea. Choose to pull the front and apart and clean the king pins etc. One was a little stiffer than the other. Also upper A arm on left side had stopped falling under itís own weight (previous contact with wall may have caused this). Reamed out the steering blocks that I hadnít done before.
Trimmed the car back up on carpet, no shell or addy. At this point I noticed how it wanted to steer without addy on purple/grey foams. So for the open practice heat went out on purple/greys with Audi R10. Race control posted lap times from this and I was pleasenlty surprised to find I turned a lap 0.1s slower than I had managed on Saturday.
Round 1
NO ADDY Purple/Greys.
Audi R10, used from here on in.
Increased the dual rate on the run to the start line
Noticed lack of grip on rears when leaving on the start tone. As you donít need to nail from the start tone wasnít an issue as your time only startís from crossing the loop.
Ran OK but had to wait 3 to 4 laps before car came to me. On same pace as Saturday.
Front end clean & strip would seem to have sorted Saturdayís problems.
Round 2
NO ADDY Lilac/Pinks
Decreased dual rate due to more steering on run to line
Getting very close to Saturdays times
Still had to wait for front to come in. Rear OK
Round 3
Same as round 2 using the same foams
Round 4
NO ADDY, used Double Pink/Yellows
Recorded quickest time of my weekends racing
Q4 to make my 1st national A final, even it is only the Sport Modified Class
Final
NO ADDY, used Double Pink/Yellows, foams from R4
Finished 9th due to traffic issues. Got a good start and holding 3rd/4th until someone rejoined the track from there crash and all mayhem broke loose.
Recorded a sub 11s lap so happy with that
Roll on Crewe and Duo Carpet & Audi R10
radio_car_racer is offline   Reply With Quote
Old 09-15-2008, 06:23 PM   #5417
WIITA's Avatar
Trader Rating: 41 (100%+)
Default nice
Very nice setup jaybee. Car looks very neatly set up and very precise. Who makes the balance buttons that you have under the car?
WIITA is offline   Reply With Quote
Old 09-15-2008, 08:04 PM   #5418
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
So, whats the majorities opinion on what is the most common cause of bent shock shafts on this car? I personally have only been through 2 of them, but others at the track are going through 2 -3 per day!
I have read that some think its the battery hitting the shock during hard collisions. However some of the guys mentioned are using tape and the o-ring.
Thoughts?
mrrcguy is offline   Reply With Quote
Old 09-15-2008, 08:08 PM   #5419
Regional Moderator
CarbonJoe's Avatar
Yes, it is from the battery hitting the shock during a crash. You have to use tape to hold them in place. The o-ring just doesn't keep the battery in place by itself. I personally use tape and the o-ring. That, and don't crash as much.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-15-2008, 08:27 PM   #5420
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks WIITA.....I try I did improve the car a bit by switching over to the Hot Bodies shock (this thing is butter!), and twisting the wires up a bit better.
I can't remember whose balancing post those are......
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-15-2008, 08:33 PM   #5421
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
That is what I do also, just the O ring is not enough.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | McFactory | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 09-15-2008, 08:35 PM   #5422
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Jeremy Otis View Post
Good looking car.
You may want to trim those body posts down though before someone gets hurt.
those help him forget about his E.D.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-15-2008, 08:35 PM   #5423
skypilot's Avatar
Good looking car.
answer your phone JB
Old 09-15-2008, 08:43 PM   #5424
corallyman's Avatar
Trader Rating: 97 (100%+)
Hey Jaybee, why does your car have 5 roll over antenna's on it. Mine only has one.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 09-15-2008, 08:48 PM   #5425
JayBee's Avatar
Steve
'Cause roll-over takes skill
What's up buddy....when are you coming down?
Old 09-15-2008, 08:52 PM   #5426
Are you guys beveling the center piece of the battery locator? I found my batteries didn't sit all the way down into the chassis until I did that. Now the battery doesn't get loose as often.
Old 09-15-2008, 08:53 PM   #5427
corallyman's Avatar
Soon.............two weeks.
Seriously, I will let you guys know when I coming down. I am looking to run some 1/12th cause I still have not bought my TC yet
Steve
It looks good btw.
Old 09-15-2008, 09:01 PM   #5428
EricF's Avatar
They look like Xray balance buttons.
E
EricF is offline   Reply With Quote
Old 09-15-2008, 11:03 PM   #5429
JayBee's Avatar
E
Hey Eric....been racing lately? How's your car?
Old 09-16-2008, 01:05 AM   #5430
Xtant3150c's Avatar
Sweet looking setup Jay
ThanX Gadget
Car felt good that first round. Probably looked better as it was a little under powered with the XBR esc in there compared to the GTB 4 cell! It made it a little easier to drive but I could really feel the lack of power from the XBR esc.
I think I need to pick up a few more pinions if I am going to use this esc? Was running my 40t pinion (biggest I have now) and the motor was coming off around 150.
I just love running this car!
space for rent
Xtant3150c is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
