Old 09-06-2008, 04:43 PM   #5386
xtrememadness's Avatar
Send a message via AIM to xtrememadness
jason. with the new linear spring are we still using the same kingpin lube as with the standard springs. i usually use #5. thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 09-06-2008, 06:38 PM   #5387
protc3's Avatar
yes we do
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-06-2008, 08:26 PM   #5388
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Jason, what's the 'standard' kingpin lube and damper tube lube for med.-high bite asphalt?
Originally Posted by JayBee View Post
For high grip ashalt, what are the desired tire sizes and compounds to run front/rear?
How much droop to run in the front?
I started with Dbl. Pink Jacos all around @ 1.70"/1.80". Cool?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-06-2008, 10:04 PM   #5389
protc3's Avatar
For high bite asphalt i run my tires at 1.750 rear and 1.700 front. I run surelube #4 on the kingpins and in the tubes.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-07-2008, 10:56 AM   #5390
Trader Rating: 26 (100%+)
Hi Jason Whats your servo of choice?
eddie10 is offline   Reply With Quote
Old 09-07-2008, 11:40 AM   #5391
Trader Rating: 8 (90%+)
If I remember correctly, JB runs a Futaba 9602. But I could be wrong.
Johnny Carey is offline   Reply With Quote
Old 09-07-2008, 01:09 PM   #5392
protc3's Avatar
sure do. I go back and fourth between the KO949 and Futaba 9602
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-07-2008, 07:30 PM   #5393
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Jason, Damn I like this car! The car just keeps getting better. Two BMI's made the podium today here at RC Hobbies Raceway. Keep up the good work. Talk to ya tomorrow (when I place another order).
mrrcguy is offline   Reply With Quote
Old 09-09-2008, 10:52 AM   #5394
protc3's Avatar
Lowered pod plates are now back in stock
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-09-2008, 10:53 AM   #5395
protc3's Avatar
Great to hear buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-09-2008, 12:41 PM   #5396
Save me 2 sets...I'll put the order in in the next couple days...soon as I can focus on doing anything for more then 5 minutes.
Old 09-09-2008, 01:44 PM   #5397
protc3's Avatar
will do
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-09-2008, 09:56 PM   #5398
radio_car_racer's Avatar
Default DB12R setup's
have a look here for DB12R setup's
hopefully Jason will have a link on his homepage soon
radio_car_racer is offline   Reply With Quote
Old 09-09-2008, 10:02 PM   #5399
That's a nice site! Just to add on my setup it is with a flat servo...the other 3 DB12Rs running on the same track run angled servos with the stock setup.
Old 09-09-2008, 10:10 PM   #5400
Summer Shoot Out R3 / Chesterfield setup
Red = change from R2
FRONT
.022 BMI Linear Front Springs DB2101
No Oil on kingpin
3.5mm Ride Height
5' Castor blocks / teflon washer either side
Camber, set run foams flat
0' Toe
Laid Down Servo / Sanwa 141
REAR
Connected Chassis Side Wings
C12 Hot Bodies Shock / Hara Medium spring / 30wt Oil
Shock Length to give approx 1-1.5mm pod droop
Kit ball studs plus 1mm shim on motor pod
0.070 flex plates (DB3010)
Tubes in forward position / 5000wt Oil in tubes
3.5mm Ride height
172mm wide
MISC
front tyre Jaco Prism Lilac
rear tyre Jaco Prism Pink
CS Tyre Additive, Full front/rear
Cells = Middle
Black Art Audi
Nosram 10.5 on 58.5mmpr (or there abouts)
Nosram Evo esc 2-6-0-0
Orion Team SHO 4200’s
After a chat with PDW tubes moved to the front hole = Definately smoother in the corners.
0.070 flex plates installed after Jason B (UK) response in earlier post
Threw mine @ the wall @ almost full chat @ the end of the straight. Wouldn't drive straight after that . Looked under the hood to find the shock missing. Popped it back on and the stuck my 1st sub 12s lap in
Starting with the above @ the R1 UK nationals this weekend. Don't envisage much change though in basic setup. Trying another compound tyre & shell though.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
