Old 08-21-2008, 07:45 PM   #5311
chris moore's Avatar
Trader Rating: 85 (99%+)
Good luck to all those running the BMI at Vegas.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 08-21-2008, 07:49 PM   #5312
RCSteve93's Avatar
Bring home the hardware... I want some one to win with it to show how capable it is on carpet.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 08-22-2008, 10:51 PM   #5313
Hey Jason, How are those lowered pod plates coming along? Frank and I want em Also you may have a DB10R order from me soon
Old 08-22-2008, 10:56 PM   #5314
Go get em in Vegas guys!
Old 08-23-2008, 03:01 AM   #5315
protc3's Avatar
the pods are out for anodize and will be back this week.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-25-2008, 01:44 PM   #5316
WIITA's Avatar
Trader Rating: 41 (100%+)
Default question
hey guys I am just wondering when building the car how many of the spacers under the front steering assembly do you use for carpet? I am using the big ones and the big phillips screw is coming through and hitting the upper suspension arm and pushing the arm up a small amount. Thanks a ton for any help
WIITA is offline   Reply With Quote
Old 08-25-2008, 01:48 PM   #5317
RCSteve93's Avatar
Originally Posted by WIITA View Post
hey guys I am just wondering when building the car how many of the spacers under the front steering assembly do you use for carpet? I am using the big ones and the big phillips screw is coming through and hitting the upper suspension arm.FYI I will be running the car on carpet.
I run the shims that come with the arms. There is a small one and a big one, I run both... I also add 2 .01" shims between the pivot ball and the top of the knuckle and 3 on top between the pivot ball and the e-clip to add a little more steering to my car and take out slop. This front end setup with magentas all around gives me a ton of steering.
rm -rf /windows
Old 08-25-2008, 01:49 PM   #5318
Generally you will need the thick one and the thin one and some finner adjusting shims.
This spacing is used to set ride height so will vary with front tyre diameter. You want to be starting at about 4mm ride height for most circuits.
Jason
jasonb is offline   Reply With Quote
Old 08-26-2008, 04:33 PM   #5319
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Hey Jason, yesterday I called in a order for some 12th kits and I forgot to ask if they were in stock. Are they?
mrrcguy is offline   Reply With Quote
Old 08-26-2008, 04:38 PM   #5320
WIITA's Avatar
Default SERVO
HEY GUYS! WHATS THE BEST SERVO FOR THIS CAR IN YOU OPINIONS.? THANKS
Old 08-26-2008, 04:46 PM   #5321
gubbs3's Avatar
Many people like the Futaba 9650. For the screws and spacers... start with both thick and thin. That will get you close to ride height with new Jaco tires. I also have some shims that I've made out of Lexan that I can give you once the season starts that really makes it easy to get the right height. If you are going to run your front tires really small, you'll need some 1/2" screws for the front of the arm to use when you only have the thick spacers. They're not really needed though because tires that small start to get a bit twitchy.
gubbs3 is offline   Reply With Quote
Old 08-26-2008, 04:48 PM   #5322
Jason
If you have the extra money get the machined aluminum spacers that BMI makes for adjusting the front ride height. These make setup much easier.
Old 08-26-2008, 06:04 PM   #5323
Regional Moderator
mrrcguy's Avatar
Agreed!
Old 08-27-2008, 12:55 AM   #5324
Trader Rating: 14 (100%+)
Jason:
Hi,
Hope you have a HAPPY BIRTHDAY today!!!!!!!!!!!!!!
Tim
(all the good people's BDay's are in August!!!!!!!!)
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 08-27-2008, 03:00 AM   #5325
protc3's Avatar
Thanks buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
