Old 08-07-2008, 07:19 PM   #5251
Originally Posted by chris moore View Post
Man got to run my car for the first time in... well too long. It was great to run 1/12 again. But I need a little help, I started with some older batts to get the feel of things again and the car was good but when I put in a good fresh set with lots of juice the car wanted to step out alot, This was on black ozite carpet and I've never run on that before so I'm looking for some suggestions. My setup now is:
Silver center spring
30wt in the shock
.24 BMI springs front
Surelube #6, very thick purple colored lube
Batts all the way back
Dlp pink all around
Servo is angled
The tires I cannot change as thats all I have, same with the servo as I dont have the parts needed to lay it flat. So I'm thinking of moving the batts forward and mabey changing the spring/oil wt. Any thoughts?
I believe the silver spring is a stiff spring. You might try going to the red or the stock gold. Also if your tires have sat for awhile it may take some time for the traction compound to soak back into them to get back to the same level of grip as before.
Old 08-07-2008, 07:20 PM   #5252
Originally Posted by JayBee View Post
Anyone running on highbite asphalt?
What tire of choice do you recommend?
We're running on about medium bite asphault and run either dbl pinks all around or magentas all around.
Old 08-07-2008, 09:20 PM   #5253
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
I run Dbl Pinks front and pink rears of the Jaco brand.
CarlosG. is offline   Reply With Quote
Old 08-08-2008, 03:15 AM   #5254
protc3's Avatar
Silver is actually one step softer than the gold. I would go to the gold or red and drop down to #4 surelube. That should help a ton
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-08-2008, 04:31 AM   #5255
Uga
Uga's Avatar
Originally Posted by Uga View Post
Will the shock rebuild kit from CRC fit for the IRS shock?
And another question - what size is the screw for the left wheel hub, the hex on my is a bit worn out.
bump
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 08-08-2008, 06:05 AM   #5256
bump
I don't think so. The IRS shock shaft is a smaller dia than the AE and CRC one you need a diferent o ring.
Check out the IRS site dave lists both sizes.
Jason
jasonb is offline   Reply With Quote
Old 08-08-2008, 06:36 AM   #5257
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
11/32....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 08-08-2008, 07:08 AM   #5258
Uga
Uga's Avatar
thanks, guys!
-=Xray XB4=-
-=Xray XB8E=-
Racing in Latvia
Old 08-08-2008, 09:26 AM   #5259
EricF's Avatar
UGA-
for the left hub screw- you can use a 5/64" or 2mm hex driver. the 11/32" nut driver is for the diff. nut.
E
EricF is offline   Reply With Quote
Old 08-08-2008, 09:41 AM   #5260
Uga
Uga's Avatar
I have the correct hex driver, I just need to replace the screw. Sorry, I always get confused by inch sizes, as I am from Europe :P
-=Xray XB4=-
-=Xray XB8E=-
Racing in Latvia
Old 08-08-2008, 09:46 AM   #5261
Regional Moderator
CarbonJoe's Avatar
So far, this is the only place I've found to get replacement left side hub screws, which is at IRS, the vendor of the hub. You want IRS part number 214.
I have to order some myself:
http://www.teamirsrc.com/hubs.html
Edit: Stormer also has them.
https://www.ssl-stormerhobbies.com/c...c=ns&pn=IRS214
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-08-2008, 10:02 AM   #5262
chris moore's Avatar
Trader Rating: 87 (99%+)
Thanks gadgt and Jason, I'll get there early today for some testing
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 08-08-2008, 10:09 AM   #5263
EricF's Avatar
Chris- what and where are you testing?? Do you think you guys ae going to make it down to CH or are you going to stay in phx at speedsports?
E
Old 08-08-2008, 10:12 AM   #5264
EricF's Avatar
oh the 'screw size'... hmm, don't know!
E
Old 08-08-2008, 10:22 AM   #5265
E
Hi Eric, yep we're going to speedsports tonight. Alot of the guys are unhappy with the track conditions at CH right now. Runing the off-road track dry is making the carpet track a dust bowl from what I've been told.
Sponsered by:
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
