Old 07-21-2008, 06:25 PM   #5161
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by Nova F1 Racer View Post
I think the wrapping on the cell is better/thicker than the rubber based shrink wrap.... I dunno the answer.....
Originally Posted by InspGadgt View Post
Quite a bit thinner actually
Originally Posted by odpurple View Post
Oh BTW, I've used that technique on a number of cars that have been in service for a quite a long time and no one has had any problem with the shrink wrap melting or breaking down
What size wire do you use?
I put the 4-cell Novak wire on mine and you said you use good old Radio Shack Shrink wrap, I'll have to check into that...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 07-21-2008, 06:53 PM   #5162
Nice job, Gadget, very clean
When can I start sending you my backlog?
LOL thanks...I have a feeling I may end up with a backlog of my own locally...lol
Old 07-21-2008, 07:03 PM   #5163
I used 16 gauge wire and yes Radio Shack 1/8th" diameter heat shrink. I would have preferred buying longer tubes of heat shrink from a local electronics shop but when I wanted to work on this only Radio Shack was open.
I CA glued the wires together in 2 places. First obviously to form the trangle stack then used Shoe Goo to hold the stack to the chassis. Then after the 90 degree bend behind the battery I used a drop of CA glue to hold the 3 wires together in a flat configuration. All in all I am very happy with the way it came out and it went much faster then my previous attempts. The real pain in the butt was in mounting the ESC and then cutting the ends of the wire to length to solder to the solder posts. There isn't much room to work with there once everything is attached to the chassis to it made stripping the insulation to solder to the ESC very difficult.
Old 07-21-2008, 07:11 PM   #5164
racer x 1's Avatar
Trader Rating: 27 (100%+)
hows parts support for this car? and does anyone here run at bending corners raceway?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 07-21-2008, 10:10 PM   #5165
EricF's Avatar
parts support is top notch. I don't think Jason has been out of anything since the cars original release.
E
EricF is offline   Reply With Quote
Old 07-22-2008, 04:52 PM   #5166
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
agreed, parts are always available, and if its not, they are always interchangeable.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 07-23-2008, 09:59 AM   #5167
Fran's Avatar
Trader Rating: 151 (100%+)
The person who started this thread, Shookie used to race his DB12R at B.C.R.
IT was a early version of the current kit car. I purchased the car from him, and slowly brought it up to current level. I just ran it for the first time, the whole race day at our track north of B.C.R. in Camarillo. All I can say is this car is so easy to drive, and is PLANTED! My driving skills are the weak link in the equasion. That will come around much quicker with this car I believe.Coming from a 12L4, I had to constantly make sure the tweak was right.. and then slill, it wasn't very consistant. I finished a race series we had going with the 12L4, but have since sold it. All I own is a DB12R and just picked up a 10R to join the resurging 10th scale pan class. I'll try and make it down to Raffels sometime soon and look you up. Jason's da man! Great products, excellent quality and support second to none in my experience!
Fran is offline   Reply With Quote
Old 07-23-2008, 10:01 AM   #5168
Suspended
Trader Rating: 1 (53%+)
i agree jason is the man i just got one and raced it this past sunday car is awsome! i had a 12r5 bmi wins it baby!
MUGEN SEIKI MTX4R
MUGEN SEIKI MRX4R
DB12R
XRAYT2 007
rc action is offline   Reply With Quote
Old 07-23-2008, 10:16 AM   #5169
racer x 1's Avatar
Thats good to hear! well i have some ties with associated and the associated is already cheaper to begin with so im torn between the two at this point. i do like the look of the bmi car looks very promising. by the way this would be my first 1/12.
Matt Bell
Old 07-23-2008, 12:18 PM   #5170
protc3's Avatar
Thanks alot guys. I try my best.
You will find our car to cost a bit more than a R5 due to the upgrades included with our car. It comes with things like titanium front axles,Boca Bearings, IRS Axle w/ lightened diff rings, IRS center shock,IRS front hinge pins, 7075 Hard coated front pivot balls, Nickel Teflon rear pivot balls and ballstuds, Machined side and central pivots as opposed to molded ones(machined pivots are more accurate and have no slop) and much more. All the cars out are great cars. You will get what you pay for with each car.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-23-2008, 12:36 PM   #5171
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I stock both... I run the BMI... The 12r5's are on clearence. The BMI's are selling and the buyers love them.
mrrcguy is offline   Reply With Quote
Old 07-23-2008, 03:26 PM   #5172
theres boca bearings in here? sweeet, i didnt know.
Old 07-23-2008, 10:37 PM   #5173
racer x 1's Avatar
any other online shops carry the car?
Matt Bell
Old 07-24-2008, 03:51 AM   #5174
Stormer and BMI directly do...I do as well but I mainly just bring in parts when my local racers ask for them. Soon that will be growing.
Old 07-26-2008, 03:27 PM   #5175
Well I just finished up the wiring and electronics installation. Moved the reciever and PTX further to the right and mounted the capacitor on the right side as well. While doing the rebuild though I noticed wear on the corners of the chassis so I think I know why the handling was a bit messed up. The ride height got too low and the corners of the chassis are catching. So I'm going to reset ride height and go to 10000wt oil in the dampers to hopefully slow down and reduce the roll.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
