Old 07-21-2008, 09:35 AM   #5146
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Where did you get the shrink in that length?
nikos2002 is offline   Reply With Quote
Old 07-21-2008, 09:54 AM   #5147
Trader Rating: 24 (96%+)
InspGadgt - very very nice!
Is there some more detailed info on how one would go about doing that to their own car's wiring?
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
http://www.kolorsbykropy.net
nemix is offline   Reply With Quote
Old 07-21-2008, 10:30 AM   #5148
theisgroup's Avatar
the master of all thing 1/12 scales
www.OD12.com
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-21-2008, 10:40 AM   #5149
The heat shrink is only in 4" lengths, after triming the wire to length I really only used 3" of heat shrink but you will want to be longer to start with just to be sure. I got 8" lengths from Radio Shack.
Old 07-21-2008, 10:44 AM   #5150
www.OD12.com
Yup OD is the man when it comes to wiring. He sent pics a few pages back and I worked from those examples...or you can also look here:
http://s351.photobucket.com/albums/q...dio%20Control/
The photos are not quite in order but I'm sure you can figure out the proper order.
Note: I've added step numbers and descriptions to the album
Old 07-21-2008, 04:31 PM   #5151
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Do you think that stripping the wire and putting shrink wrap on it might present a problem with heat melting/scraping the wrap away?
It looks great but will it hold up?
THX
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 07-21-2008, 04:54 PM   #5152
If the battery gets that hot it will melt through it's own heat shrink long before it will melt through the heat shrink on the wire and you have a lot worse issue to worry about.
Old 07-21-2008, 05:09 PM   #5153
I think the wrapping on the cell is better/thicker than the rubber based shrink wrap.... I dunno the answer.....
RC Tech member #11
Old 07-21-2008, 05:18 PM   #5154
What Make and Compound Tires are BMI Racers using on Outdoor Asphalt? Track is sealed with Pop Additive. Thanks
ElliotCanada is offline   Reply With Quote
Old 07-21-2008, 05:28 PM   #5155
chris moore's Avatar
Trader Rating: 85 (99%+)
Originally Posted by ElliotCanada View Post
What Make and Compound Tires are BMI Racers using on Asphalt? Thanks
I've been using double pink all around but if thats too much for your track try liac front and double pink in back.
Thats a great wire job Inspector, looks every bit as good as OD's work.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 07-21-2008, 05:31 PM   #5156
Quite a bit thinner actually
Old 07-21-2008, 05:32 PM   #5157
Thanks Chris
Old 07-21-2008, 05:53 PM   #5158
odpurple's Avatar
Thanks Chris
Nice job, Gadget, very clean
When can I start sending you my backlog?
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 07-21-2008, 05:57 PM   #5159
odpurple's Avatar
Oh BTW, I've used that technique on a number of cars that have been in service for a quite a long time and no one has had any problem with the shrink wrap melting or breaking down
Old 07-21-2008, 06:21 PM   #5160
We run indoor asphalt and use purples in front and yellows in the rear. This is a high bite track ( 99 x 47 ) and smooth as glass....
RC Tech member #11
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
