Old 07-14-2008, 12:36 PM   #5116
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by InspGadgt View Post
I'll give that a try, won't that decrease rear traction though? Oh I forgot...I have the battery in the middle setting at the moment. I tried the foward setting when I first built the car but didn't have enough rear traction so I moved it back.
You got PM....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 07-14-2008, 01:28 PM   #5117
protc3's Avatar
Pod droop will increase rear traction. Going thicker in the tubes will add steering so you may want to go back to a gold center spring if you lose too much traction. It will keep the car flatter so you may not lose rear bite.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-14-2008, 05:05 PM   #5118
Sweet...sounds good. Are you measuring droop from the back of the pod or from the pivot?
Old 07-14-2008, 06:53 PM   #5119
AOD
AOD's Avatar
Hey Burt, Jason gives an explaination on how to measure pod droop on page 49 post #1447
AOD is offline   Reply With Quote
Old 07-14-2008, 07:12 PM   #5120
Ok cool...just wanted to make sure because I've seen it done a couple of different ways.
Old 07-14-2008, 07:18 PM   #5121
Originally Posted by protc3 View Post
Measuring pod droop in degrees is a pain in the azz What we do is measure the ride height on a flat surface. Then we lift the car slowly from the ballstud on the pod top plate until the shock fully extends and starts to lift the car. You want to lift it until the rear wheels are just about to leave the ground and then measure your ride height at the same area. The difference between the 2 ride heights in mm will give you the droop amount.
Found the pod droop measurement thanks Now looking at this there should be a way to calculate how far the pod should drop from level on setup blocks using geometry. With that it would make it easier to measure. Now to brush up on my geometry
Old 07-15-2008, 11:36 AM   #5122
POUNDITRACING's Avatar
Where is everyone getting parts on-line.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 07-15-2008, 01:20 PM   #5123
You can get BMI parts directly from BMI at www.bmiracing.com or from Stormer Hobbies at www.stormerhobbies.com. I bring in parts for our guys here in Hawaii and once my site is eventually fixed you'll be able to get them there too.
Old 07-15-2008, 01:54 PM   #5124
116spud's Avatar
I carry all the BMI parts if your looking for a on line store.
Just PM me for info.
116spud is offline   Reply With Quote
Old 07-15-2008, 06:19 PM   #5125
Here's our local track...location always the same but the layout changes every 2 races
Old 07-15-2008, 07:44 PM   #5126
chris moore's Avatar
Trader Rating: 87 (99%+)
Looks nice, what are you using to sperate the track, fire hose?
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 07-15-2008, 07:49 PM   #5127
Road Rails
Old 07-15-2008, 08:03 PM   #5128
CraigM's Avatar
Trader Rating: 34 (100%+)
where can I get a DB12R? is direct from BMI (currently out of stock by the look of it) the only option? I'm in oz btw so need somewhere that ships international
edit: just saw this post
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-15-2008, 08:07 PM   #5129
Look 4 and 5 posts up
Old 07-16-2008, 03:32 AM   #5130
Xtant3150c's Avatar
Yup I stole 3rd from InspGadgt on Sunday
I am very happy with my car! I have not driven it for over a month after letting a friend run it at the race before this one. And despite the lay off it was easy to get back in the groove with my DB12R!
I have said it before and will say it again I Love My DB12R
space for rent
Xtant3150c is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
