Old 07-10-2008, 04:36 PM   #5086
We run asphault. All the BMIs here run with their batteries all the back except for mine. I run mine in the mid position but that's only because I have to run a flat servo due to my servo case having no mounting ears on it. Here's my car:
Old 07-10-2008, 05:06 PM   #5087
odpurple's Avatar
Originally Posted by InspGadgt View Post
For those who know the GTB better thank I...I'm really not liking how thick the wires are leading to the cap...It makes it a real pain to place the cap where I like. Will it effect the performance noticably if I put a Dean's connector on it to make wiring easier or if I change out the wires to 16awg like the rest of the wires?
I always replace the capacitor wires on the GTB with 18ga. I usually place the cap on the side of the chassis opposite the esc to help balance the car, so the wires need to be a touch longer. I've never seen any performance difference on any of the cars I've done this to. I do the same thing on Sphere speed controls, although on those the cap wires are already small (looks like 20ga) but they are usually too short and very stiff. I'm not sure why you would want to put a plug on, I just replace the wires all the way from the esc to the cap
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 07-10-2008, 05:15 PM   #5088
Thanks OD that's what I was looking for. I was originally looking to put the capacitor up front by the transponder due to the size of the reciever...But I was having fits working with that hugely thick wire on the capacitor.
I've seen a few of your great wiring jobs here on RC Tech and was wondering...on chassis where you run the motor wires on the chassis, what do you use to hold it there? I've been using the sticker sheets that look like graphite but I haven't really been happy with that.
Old 07-10-2008, 05:17 PM   #5089
Scottrik's Avatar
Trader Rating: 241 (100%+)
Originally Posted by odpurple View Post
I always replace the capacitor wires on the GTB with 18ga. I usually place the cap on the side of the chassis opposite the esc to help balance the car, so the wires need to be a touch longer. I've never seen any performance difference on any of the cars I've done this to...I'm not sure why you would want to put a plug on, I just replace the wires all the way from the esc to the cap
+1
Inspector--are you underweight and NEED the weight of the nickel? If not (and I doubt you are) why not move your receiver and cap out to the right edge of the chassis and leverage their existing (and required) mass? Not sure it would get you ALL the way there (though I'm able to balance out my monster GTB) but at least maybe it gets you down to a dime (or less).
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 07-10-2008, 05:23 PM   #5090
Originally Posted by Scottrik View Post
+1
Well your really talking about 2 different cars...the cap I've been asking about is on a Novak GTB on a customer car. The car with the nickle on it is mine and the cap is the very small and light Tekin cap. Originally I had my PTX transponder where the nickle is so my electronics pretty much were all the way over and I still needed to add a little weight to balance it. Note I balanced it without the rear pod...trying that idea out too The servo I'm running is a bit lighter and more narrow then what most people run in 1/12th so it's likely not adding as much weight to that side as other servos. So it probably needed the nickle where people running a more common servo wouldn't need it.
Old 07-10-2008, 05:29 PM   #5091
116spud's Avatar
Originally Posted by 116spud View Post
Aluminum screw kits are in and for sale.
$19.00 a kit plus postage.
I have them red, blue, and purple, please PM me for orders.
Aluminum screw kits are ready to ship.
116spud is offline   Reply With Quote
Old 07-10-2008, 06:01 PM   #5092
odpurple's Avatar
...I've seen a few of your great wiring jobs here on RC Tech and was wondering...on chassis where you run the motor wires on the chassis, what do you use to hold it there? I've been using the sticker sheets that look like graphite but I haven't really been happy with that.
The nature of the silicone jacket on the wire we use makes it very difficult to attach it to the chassis. It just doesn't stick to anything that well. I've tried ca, shoo goo and epoxy and the best solution is the 5 minute epoxy I have been using. It doesn't stick all that well but better than the others, which the wire peels right off of as soon as it dries. At least the epoxy forms a filet around the wire and holds it in place pretty well.
All that being said, the wires mostly only need to be held in place until the batteries are installed
Old 07-10-2008, 06:32 PM   #5093
Hmmmm...not sure I'd like epoxy, that would be difficult to remove from the chassis. The wire may come off the epoxy fine but the epoxy off the chassis I just don't know if I want ti be that permanent. I've tried shoe goo since that works so well for electronics but with the small amount of contact area on wires it just doesn't work. I just had an idea though...I wonder how well Shoe Goo or another Silicone glue would work with a straw...maybe I can find some sort of plastic straw that the wire fits a bit tight into and Shoe Goo the straw to the chassis. Hmmmm
Old 07-10-2008, 06:43 PM   #5094
Scottrik's Avatar
Nope...just talking about your car. You have a cap. You have a receiver. Move 'em as far as you can to the right. Eliminate need for nickel. Leverage, my friend, leverage.
I think you're DEAD on with the balancing sans rear pod. I've been doing that on my cars for a while now and am very pleased with the results. Nothing like building a brand new car, aligning it with my Niftech bars, throwing it on the track and not even needing to adjust steering trim. I LOVE these cars!!
Old 07-10-2008, 06:51 PM   #5095
I did have the electronics further over initially...still wasn't quite balanced, maybe I was being to anal about a couple grams. Tekin stresses putting the cap as close to the ESC as possible so I've been following their advise as much as possible. I guess I should try moving it and seeing if there is a performance decrease.
I really like my old Holeshot alignment board...it's kind of an early Hudy type setup but with the toe gauge on the bottom instead of on the top.
Old 07-10-2008, 07:23 PM   #5096
odpurple's Avatar
Oh, definately do not use the epoxy if you think you will want to remove it, I never do but I'm sure you would have to sand it off. I don't think there is anything that sticks to the silicone wire jacket very well, its not so much the contact area but that the stuff is just slippery!
Your straw idea can work as long as you are only running one wire under the battery, otherwise it may not fit in that little space between the batteries.
There is another way to do it that I use but it is almost too much work By using this method I can get all three motor wires under the one middle battery space. First lay the wires out in their approximate final positions, then strip the insulation off of the wires the entire length of where they pass under the batteries (plus a little bit on either end) Then shrink wrap them (individually, duh) with the smallest diameter wrap you can get around them. Then glue two of them to the chassis right next to each other the distance of the battery slot. After that glue the third wire on top of the first two, like a little log pile. The glue, ca or shoo goo will stick to the shrink wrap really well. Too much work but it will amaze your friends I think I have a pic
Old 07-10-2008, 07:29 PM   #5097
I like that...but given the DB12R has the battery locater in the middle the wires won't fit there
However...it might work on one of the other slots if I do it right...hmmmm
Old 07-10-2008, 08:06 PM   #5098
odpurple's Avatar
Gadget, I post this stuff for your amusement, I wouldn't expect you to do this crazy stuff anyway!
So I have a solution, but only if you run your batteries in the same position all the time
1. chassis, plugs and carbon fiber strip (.007)
2. plugs glued in with epoxy
3. carbon fiber strip glued on top
Old 07-10-2008, 09:39 PM   #5099
interesting idea...could probably get away with shoe goo'ing in the spacers so that they are still removeable. I've been thinking along a different line...I'm always frustrated with my cell shrink wrap getting ripped up over time running on outdoor asphault. I've been thinking about building a small vaccuum form machine and making lexan trays for the battery to sit in to protect them. Possibly I could incorporate the 2 ideas and have the tray serve as the battery positioner as well.
Why not shrink the whole wire? The silicone is more flexible but with the heat shrink being so much thinner it shouldn't sacrafice flexability.
Old 07-10-2008, 10:08 PM   #5100
EricF's Avatar
InspGadgt...
This is the layout of my car. see attached file.
E
EricF is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
