Old 06-20-2008, 08:06 PM   #4996
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by JayBee View Post
Hey guys is it possible to reach the rollout needed for a Hacker 17.5 with the 88T spur or do I need to swap in the 76T?
You should shoot for a 81 to 86mm rollout. I run either a 76, 78 or 80T spur and 47 to 51T pinions depending upon the tire size.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-20-2008, 08:20 PM   #4997
Originally Posted by chris moore View Post
If you look at the centerline you'll see that the motor is not exactly centered in the car but is just very slightly off to the clamping side. That makes up for it, but as I said it was'nt exactly perfectly balanced in this configuration. I tried it with the esc on the other side but it was worse that way so this was as close as I could get.
I hadn't thought of that...the off-set is right for the center of mass for a brushed motor but not for a brushless. I planned on rewiring my car after this weekend's race. I think I'll try moving the ESC over to the other side for balance but put the reciever and servo on the left side and see how it balances.
Old 06-20-2008, 08:38 PM   #4998
tbeardmore's Avatar
Hey All - FYI!
The 4th Annual Midwest Carpet On-Road Championships has been announced!
Hope you can make it to "The Plex"...!
http://www.rctech.net/forum/attachme...9&d=1213690177
-Todd
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 06-20-2008, 09:39 PM   #4999
JayBee's Avatar
Trader Rating: 31 (100%+)
Thumbs up
Much appreciated
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-20-2008, 11:11 PM   #5000
Here is a pic of mine, not the best angle but the only one I have right now. It balanced out really close like this.
chris thanks bud i appreciate it and i will try it that way. im also going to run a FASST reciever and it should be a little bit more wieght than that tiny spectrum one. and good point about the motor being a little more offset i didnt really think about that. thanks
leon
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 06-22-2008, 04:18 AM   #5001
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
I showed a mate of mine my newly finished DB12R today...... can any one say green with envy
dirtdustingdavo is offline   Reply With Quote
Old 06-23-2008, 01:26 AM   #5002
Another great day for BMI at our local race. Our local hot shot just got into 1/12th with a 12R5 and smoked us all but BMI came in 2nd and 3rd I believe. I brain farted and only was able to pull off a 3rd but that was good enough to bump me up to finish 2nd place overall in our championship series that just finished. Not bad considering the first few races I was driving a different car and finishing poorly in those races. The strength of the BMI impressed one driver enough to buy one on the spot so you got mail Jason Got another order
Old 06-23-2008, 03:00 AM   #5003
Xtant3150c's Avatar
On a side note to InspGadgt's post the 2nd place BMI DB12R was my car But of course it was not driven by me I loaned a fellow racer my DB12R for this race because I wanted to see how he felt about the car?
He had no previous experience with this car and did'nt change anything but some radio adjustments. Qualified 2nd for the A-Main and ran a very good race in the Main and as mentioned finished 2nd!
Needless to say he was very impressed with the DB12R and I think now is on the look out for one
space for rent
Xtant3150c is offline   Reply With Quote
Old 06-23-2008, 12:52 PM   #5004
Well if he wants to order one have him contact me
Old 06-23-2008, 05:18 PM   #5005
chris moore's Avatar
Trader Rating: 85 (99%+)
Man If I can ever put together enough $ for a second honeymoon I'll go back to the islands and race with you guys.
chris moore is offline   Reply With Quote
Old 06-23-2008, 06:47 PM   #5006
The more the merrier
Our little race is growing fast. We had 84 entries in the last race and had up through an F main in the GT class. We had 12 1/12th scale cars and still had some normal racers that did not race.
Old 06-23-2008, 07:15 PM   #5007
Kropy's Avatar
Send a message via AIM to Kropy
Originally Posted by tbeardmore View Post
Hey All - FYI!
-Todd
Todd, That link dose not work
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 06-24-2008, 03:17 AM   #5008
radio_car_racer's Avatar
going well in the UK also
keep up to speed with what's going on over the pond here
radio_car_racer is offline   Reply With Quote
Old 06-24-2008, 06:12 AM   #5009
Scottrik's Avatar
Trader Rating: 240 (100%+)
Hey Chris,
Some may have issue with this, but when I brought it up a while back, either here or on the 1/12 thread (or both), most seemed in agreement. I've taken to balancing the main plate of the chassis with the electronics on it and ignoring the rear pod and motor. Unlike a T(axi) C(ab) we use a solid axle--regardless the weight side-to-side both tires are flat on the "road" and the rear axle is as level as your tire size is even. An extreme example would be that you could tape another motor on top of one rear tire and you wouldn't affect tweak.
What WILL affect tweak, though, is putting electronics onto the main plate in an effort to balance the rear pod out. Yes you can get the tweak to even out, but you will have different pressures on the tweak screws/springs (and this should show up even more on the "tweakless" BMI) and can manifest itself as different ride heights side-to-side. We're not talking about anything enormous here, but a difference.
In a perfect situation the rear pod would balance too but, as Brian Bodine found when he experimented with a mass-centered motor pod, it wasn't worth the effort. There was no effect on handling, it only evened up the VERY modest difference in tire wear across the rear. This wear is more easily compensated for by rotating the tires side-to-side every run or two.
When balancing I've gone on the theory that the stuff that's symetric (front suspension, hardware on the sides (hockey sticks, etc), body mounts (anything you install equal numbers of on both sides) can be left off. I've done it both ways now and obtained the same result. I do install the antenna mount as it affects placement. The IRS buttons work perfectly inserted in the rearmost hole for the battery brace. I sure wish the buttons didn't have the hole in the face--it cuts their "sensitivity" enormously. I've almost found it easier in this regard to have the front suspension mounted, etc, just to help overcome the "flat face" the hole creates on-center.
Using this method I've built 3 DB12R's now (and a CRAPLOAD of 3.2R's, a Darkside, etc, but you have to drill your holes for these) and these cars all track dead straight on or off the power as long as the diff is adjusted properly. A fact I attribute to using the Niftech alignment tool is that every time I throw a brand new car on the track I never have to adjust the trim and it drives perfectly straight hands-off every time. I've taken to counting on that--it just does. On to worrying about something else.
Now if I could just learn to drive...
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 06-24-2008, 01:04 PM   #5010
Here's my ride in a slideshow
Nosram 2007 esc
Nosram 6.5s bl
Sanwa 141
MRT PTx transponder
Spektrum Micro receiver
VXR regulator & rx li-po
Jaco Prism's
Stromfoce Racing EnerG SC4600
Blackart Audi R10
the rest, oh it's pure BMI DB12R
weigths in @ 920g
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
