Old 05-19-2008, 06:02 AM   #4786
protc3's Avatar
The GTB is a bit on the heavy side and large side but you should be pretty close buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-19-2008, 08:26 AM   #4787
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
you and adrian should get the first and 20th cars, i think that would be fair. For all the work you put into it, you should use it as a paper weight or something on your desk
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 05-19-2008, 08:44 AM   #4788
radio_car_racer's Avatar
got to race mine again for the 1st time in 8 weeks
Using a Speed Passion 10.5s all weekend and ran a best of 11.96s lap against open class 11.20s lap
lying 12th after r4 then improved in r5 only to pipped by a few others in heats 5 & 6 in r5 which put down in 15th & then finished 5th in B final running the Speed Passion 10.5s
Summer Shoot Out R1 / Chesterfield setup
FRONT
.022 BMI Linear Front Springs DB2101
No Oil on kingpin
3.5mm Ride Height
5' Castor blocks / teflon washer either side
Camber, set to run foams flat
0' Toe
Laid Down Servo / Sanwa 141
REAR
Quick Tune Brace
New Lowered Pod Plates
C12 Hot Bodies Shock / Hara Medium spring / 30wt Oil
Shock Length to give approx 1-1.5mm pod droop
Kit ball studs plus 1mm shim on motor pod
0.070 flex plates (DB3010)
Tubes in rear position / 5000wt Oil in tubes
3.5mm Ride height
172mm wide
MISC
front tyre Jaco 2X Pink
rear tyre Jaco Yellow
CS Tyre Additive, Full front/rear
Cells = Middle
Parma Zytec
Speed Passion 10.5 on 57.5mmpr (or there abouts)
Nosram Evo esc 2-6-0-0
StromForce 4600 EnerG SC4600
Didn't touch the car at all apart from changing the tyres & batteries. Wanted to change something but didn't dare as I was having such a ball and I was getting quicker each run
Car was on rails, eating the faster open class cars in & through the corners, only to loose 4 to 5 feet on the straight
All in all a good day.
Jason,
edit the above setup for 6.5BL & lower please to give a starting point for a low to medium grip carpet for the next round or maybe SlowerOne will post his setup here to from the same event
radio_car_racer is offline   Reply With Quote
Old 05-20-2008, 12:33 PM   #4789
Trader Rating: 24 (96%+)
wow - just got a hacker 10.5 brushless moto for my db12 for a large asphalt race this weekend on a huge 1/8th based track.
This thing barely fits and its tight!
Whats the spur gear that comes with the db12 kit? i got mine second hand from a snowbird racer last year, and this is my first time taking it out. with the current spur and the size of the e40 it doesnt look like i have much room for a pinion gear at all......
any way to tell on the spur how many teeth it is?
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
http://www.kolorsbykropy.net
nemix is offline   Reply With Quote
Old 05-20-2008, 12:42 PM   #4790
I believe the spur that comes with the DB12R is 88 tooth
Old 05-20-2008, 12:49 PM   #4791
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Whats the spur gear that comes with the db12 kit? i got mine second hand from a snowbird racer last year, and this is my first time taking it out. with the current pinion and the size of the e40 it doesnt look like i have much room for a spur gear at all......
Yes, it is a 88 64P spur gear....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 05-20-2008, 01:16 PM   #4792
ok so the guy i got the car from was running brushed 27t, and had a 64p 36 tooth pinion gear
What pinions do you recomend i pick up to use with the 10.5 on a large asphalt track? (asuming the original spur is whats on the car)
I'll be running new prisms, or trued down to whatever you guys recomend.. (asuming someone at 301 has a truer they will show me how to use)
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
Old 05-20-2008, 01:48 PM   #4793
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Nemix,
Im assuming your going to be racing at 301. I would start off with a 38/88 I know that pinion might be to small cauz I never raced at 301. I would gear up from there every run you make out there.
I know its not much info but I hope it get's you in the right direction
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 05-20-2008, 02:53 PM   #4794
yup.. will be my first time at 301...
so i'll pick up like 38-42 for my pre race testing and see how it goes...
thanks allot
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
Old 05-20-2008, 03:00 PM   #4795
Originally Posted by mike ivy View Post
Hey Nemix,
I'm running in the same race and planning on a 50 pinion 78 spur as a starting point on my 10.5....
And I'll have my tire truer with me...
RC Tech member #11
Old 05-20-2008, 03:18 PM   #4796
is there an advantage to a smaller spur and larger pinion combo?
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
Old 05-20-2008, 03:59 PM   #4797
KHoff7's Avatar
smaller spur = taller gearing
bigger pinion = taller gearing
taller gearing = more speed and less acceleration
at 301 you will want very tall gearing compared to most local tracks (For us).
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 05-20-2008, 04:42 PM   #4798
well looks like i need to swap out my spur as well. what brand spur gears fit well in the db12?
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
Old 05-20-2008, 05:07 PM   #4799
Kropy's Avatar
Send a message via AIM to Kropy
PRS, Kimbrough, RW, Robinson
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 05-20-2008, 05:30 PM   #4800
kropy, you got pm... email me your contact info again, about website stuff
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
