Old 08-13-2007, 02:11 PM   #466
haagar's Avatar
What length/type 4-40 screw are there the most of on this car?
I'm going to buy a bunch of 8-32 locknuts and figured I'd throw some 4-40 screws on since I am already paying for shipping.
Unless someone knows of a good place to get low profile aluminum 8-32 nylocks...
haagar is offline   Reply With Quote
Old 08-13-2007, 03:11 PM   #467
protc3's Avatar
hey guys,
i got some pics of the car with all the anodizing.i am EXTREMELY happy with the way it came out.i just cant stop messing with the car
BMI's DB12R-db12r.jpg   BMI's DB12R-db12r-1.jpg   BMI's DB12R-db12r-2.jpg   BMI's DB12R-db12r-3.jpg
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-13-2007, 03:27 PM   #468
protc3's Avatar
we have now started packaging the cars.i should be able to start shipping next week.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-13-2007, 03:29 PM   #469
protc3's Avatar
DAMN IT!!!!!!! i forgot the damper tubes again. i will take more pics tonight and get them up here.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-13-2007, 03:37 PM   #470
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by protc3 View Post
hey guys,
I still think my crome and red combo is way cooler....
Both my cars match....007 with red shims, contersunk washers..
DB12R with crome rear pod and axels, red shocks and red servo mounts..
See its all about the red and crome combo....
Car is stunning Bro. Seems your going to make alot of people very happy when you gave them a realistic date of delivery and then beat it, with your hard work and hopefully not having to ride Adrian too hard....
I think since your so far ahead you should take this weekend off and race...
Yea thats exactly what you should do.....
Let the Flames begin........
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-13-2007, 03:44 PM   #471
protc3's Avatar
i have worked an offroad race in for saturday night. then next weekend we have a carpet race that i will take the DB12R out for its virgin run
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-13-2007, 04:20 PM   #472
rcgen's Avatar
Next week!!!! Cool that will give me couple of days to build the car and convince the wife for me race at Minnreg. I guess I'll be expecting a phone call on the preorder soon
rcgen is offline   Reply With Quote
Old 08-13-2007, 04:25 PM   #473
Big B's Avatar
hey guys,
Looks great Jason, I cannot wait till I can afford one
Traxxas Slash 4x4, Team Checkpoint TC-1030 Charger and Power Supply, Team Checkpoint Lipo Balancer
Big B is offline   Reply With Quote
Old 08-13-2007, 04:50 PM   #474
Big B's Avatar
Jason, could you please give me a detailed breakdown of what Reactive Castor does for you (as well as when to change it and why), and the advantages of Bump Toe in, and Zero Bump Steer
Old 08-13-2007, 05:14 PM   #475
AdrianM's Avatar
Reactive caster - This gives your car less caster as it rolls into a corner. This allows you to set you car with some static caster (with the car level side to side) for straight line stability but as the chassis rolls into a corner the caster is reduced making the car turn in more quickly and have more mid corner steering. As the car exists the corner the chassis returns to level and the caster comes back for stability.
99.99% of the time the 10* reactive blocks are best. If you look in the pit boxes of guys like Barry Baker, Mike Blackstock and Josh Cyrul they usually only have 10* blocks. Mike Blackstock told me once that if you think you need a 5* block you have a problem elsewhere in your car.
The 5* block is a compromise. You will need to run less static caster to keep your corner entry turn in but this will cause you to lose some straight line stability. If you want to get rid of a violent turn in there are other settings to look at in a 1/12th car like pod droop, center shock angle, center shock oil and center shock spring.
0* blocks are for oval racers...I throw mine away with the bag and header card.
Bump Toe (in or out) - ...is not a good thing. Guys talk about this in regards to angled or laid down servos....but either way you need to set up your steering links to eliminate bump toe.
The reactive caster front end most of us use is designed to run with an angled servo. This allows you to run standard ball studs and you will have not bump toe. With this setting your car will have Ackermann. This means the inside wheel will trun inot the corner a couple degrees more than the outside wheel. This will give you more low speed steering. This is how most people run their servos outdoors.
With a laid down servo you will need to use longer ball studs on the steering arms of your spindles to adjust the steering link geometry to eliminate the bump toe. With a laid down servo you will have little to no Ackermann at all. This is better on high traction surfaces (like Carpet) where you already have a lot of steering. No Ackermann on a high traction surfaces gives more corner speed since the inside front wheel will be less likely to turn in past its optimum slip angle and cause drag.
That said Mod drivers run angled servos on carpet to get more steering...becuase you ALWAYS need more steering in Mod...lol!
Old 08-13-2007, 05:20 PM   #476
protc3's Avatar
what reactive castor does is reduce your castor angle of the steering hub during suspension compression.depending on the angle you have will decide how much castor reduction you get.more castor reduction will make the car more aggressive on corner entry,less will make the car push more on corner entry.less reactive castor can be used for real high bite tracks where the car seems to drill the nose on entry.all the degree blocks are set for the same static castor angle.you have some adjustment with the shims but your static castor will remain the same with all of the blocks.the blocks change the forward angle the arm is mounted at.this is what makes the upper arm pull forward as you compress your suspension.i hope that i didnt make it confusing.
bump toe is another nice adjustment.toe in as we all know will reduce steering response.using bump toe in will tone the steering down when the suspension is compressed and will return to straight when the springs are relaxed.this also tones the car out on high bite tracks when needed.using the angled mounts will eliminate all bumpsteer and allow for more aggressive steering throughout the turn and will be most aggressive for tracks with less traction such as asphalt.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-13-2007, 05:57 PM   #477
AdrianM's Avatar
Bump toe in will make your car turn into a corner harder. As the suspension compresses the outside wheel will turn into the corner more than the steering input increasing turn in.
The reason I don't like any bump toe in is that it can give you what you want in some places on the track (like entering sweepers) and fight you in other places (like chicanes). It can pull the nose of the car too deeply into a corner when you want to make a quick direction change.
Bump toe can also make your car darty and unpredictable on bumpy tracks.
Bump toe out is all bad...all the time and will make your car do weird stuff. The good thing is that it is REALLY hard to get bump toe out in any 1/12th car.
Old 08-13-2007, 06:23 PM   #478
ttso's Avatar
Huh ackman...
I still don't get, is the rod like \ / give more ackman, or like - - give more ackman.
What about rod like / \ ??
(Front on top, servo on middle)
ttso is offline   Reply With Quote
Old 08-13-2007, 06:36 PM   #479
Send a message via AIM to goop
/ \ this is more ackerman makes the car smoother and easier to drive
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 08-13-2007, 07:01 PM   #480
protc3's Avatar
??? toe out gives the effect of more steering from what i have found.toe in tones it down.the inside wheel scrubs with toe in due to the reduction of ackerman as both wheels pinch.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
