Old 05-09-2008, 04:41 PM   #4756
lorider75's Avatar
i know the cardinal rule is to change one thing at a time but i had to change several things at once....
i changed to the .022 (linear springs) from the .020 (linear springs) and i changed tire compounds, because i suck and destroyed my only set of lilacs and greys. I went to a black front yellow rear and had a noticeable push and it didnt seem to change directions very quickly, you could call it lazy even.
I just found out that the yellows are actually softer then the greys.... i thot elsewise and thusly tried them with the harder black fronts. is that why it pushed??? the rear end had to much bite?
Team High Torque * Extremercmods.com
lorider75 is offline   Reply With Quote
Old 05-09-2008, 04:49 PM   #4757
protc3's Avatar
In most cases Blacks will make the car push pretty bad. I only use blacks in real high bite when front tires are gumming up. Blacks are a synthetic rubber and do not have the high natural rubber content you find in lilacs,purples,2x pink and so on. Blacks are a 40 shore tire like purples just without rubber. If you want to go to a harder front, try a purple. Purple is 1 step harder than the lilac. You can stick with the grays, yellows are softer and hard to keep in 1 pc. The yellows work great as long as you dont swipe the boards. Post your setup and surface and i can get you going in the right direction
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-09-2008, 04:59 PM   #4758
lorider75's Avatar
i run the box stock set-up with a t-bang 27t motor geared 24/88. i have 3k in the damper tubes. i use the lrp qc2(i also have a hara twister 2.2 but with that huge cap i dont know if i can find enough room on the chassis lol)
the carpet is pretty fresh, less then a year old. it only gets run on once a week. I noticed the yellows come apart pretty easily, i absolutely destroyed them in one night... it doesnt help with the amount of boards i hit either. I was just trying something else that i had in the ole tire box and the blacks were fresh
Old 05-09-2008, 05:09 PM   #4759
protc3's Avatar
THats cool buddy. Try going to purple front and gray rear. Go back to the .020 linear springs and put 5000wt diff oil on the kingpins. Go to 10,000 in the damper tubes with the red center shock spring. If you have a tall ball stud that will help also. Run the batteries in the middle and the rest can be the kit setup. You will also want to gear up a little. I usually gear mine at 88/30 with a 1.750 rear tire. Sauce full rear and 1/2 the inside front and you should be good to go. Let me know how it works
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-09-2008, 05:23 PM   #4760
lorider75's Avatar
thanks jason.... i will set the car up as per your suggestions and it better werk hahahah j/k thanks for your help.... your customer service is absolutely amazing
Old 05-09-2008, 06:01 PM   #4761
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-09-2008, 07:57 PM   #4762
hanulec's Avatar
Trader Rating: 23 (100%+)
lowrider - it helps if you CA glue the side walls of jaco yellow rears. since yellows are super soft it is hard to get more than one race day and maybe a few practice packs in before they wear out. double pink front and yellow rears work great on carpet.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-10-2008, 04:17 AM   #4763
t4mania's Avatar
Thanks again Mike I'll give them a try.
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 05-12-2008, 01:38 AM   #4764
BMI did awesome at our race today. We had our first race were 1/12th had enough entries for an A and a B main. Frank finished first in the A with his BMI and I finished 2nd with mine Frank and I had some great battles for a good half the race before my concentration was blown. I had a couple pretty bad laps there in the middle but finally settled down, got back into 2nd, and started closing the gap back to first. I was too far though to catch up.
Changing the caster was money! Car went from a bit of push in the last race to right on the ragged edge this race. A little radio adjustments got me right where I wanted the car to be. I have just a slight tweak feeling in the car. I think I need to rebalance the electronics. The IRS balance buttons are great but with the flat spot where the pin goes through I can't seem to find where perfect balance is. It seems I can be off a little bit on one side and it will still sit balanced on the flat spot of the buttons. Maybe it's time to pick up some more postage scales and weigh the car at each wheel
Old 05-14-2008, 03:52 PM   #4765
sportpak's Avatar
Trader Rating: 26 (100%+)
Before I get flamed, I am promising right now that the search function is not working for me right now...
Anyway, I picked up DB12 and look forward to running it this fall. I've had good luck with the old AE block front end, has anyone had any luck with it on this car? I'm a machinist, I lower them for little tires and add a few degrees of caster. Fast guys at my track seem to like them, do you think it'd be worth a try on this car? I'm not exactly a "razors edge" 12th scaler, but I'm considering myself dangerous with the right tools and practice.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 05-14-2008, 04:01 PM   #4766
stiltskin's Avatar
Trader Rating: 101 (100%+)
I'll join you on the firing line. I was also wondering what front end if preferred and why.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-14-2008, 04:02 PM   #4767
sportpak's Avatar
I'm wearing my blindfold. Do you have a cigarette?
Old 05-14-2008, 04:12 PM   #4768
stiltskin's Avatar
Tony Rumple
Old 05-15-2008, 03:09 AM   #4769
protc3's Avatar
To be honest, i never was a big fan of the old school front end so i never tried it on this car. If you try it out, please keep us informed.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-16-2008, 08:17 AM   #4770
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
so no one tried the car with another front end?
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
