Old 04-29-2008, 07:51 AM   #4696
redlion's Avatar
9602 or 9650 Futaba.
redlion is offline   Reply With Quote
Old 04-29-2008, 08:19 AM   #4697
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
Originally Posted by punkboy View Post
InspGadgt: I searched for the Strawberry punch syrup you mentioned last week. I was only able to find Fruit punch syrup or Strawberry Snow-Cone syrup. May I ask where you go to find Strawberry punch syrup, or if it would even matter whether the syrup be strawberry punch or fruit punch?
Thanks for your help.
mm, you guys must have the tastiest tires over there in Hawaii.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 04-29-2008, 09:10 AM   #4698
protc3's Avatar
Originally Posted by losithrasher View Post
hey guys, what servos fit in this car, im getting in to 12th scale(im mainly a touring car guy)
josh
The Futaba 9602,9650 and a KO949 are my 1st 3 choices.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-29-2008, 01:05 PM   #4699
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by AdrianM View Post
We run ~70mm roll out with an SP GT and 10.5 in a DB12R on tracks that size. Use all the default GT settings.
Hey AdrianM, I downloaded the excel spread sheet but it is password protected ( I want to add about 15 bigger pinions )....
What's the password?
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-29-2008, 02:10 PM   #4700
Mason's Avatar
its the same as his luggage.. "ONE TWO THREE FOUR.. FIVE"
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-29-2008, 02:12 PM   #4701
Yeah well at least he's not a Mog!
LOL
Old 04-29-2008, 02:51 PM   #4702
RCSteve93's Avatar
Opened it in Open Office on Linux and I could edit it.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 04-29-2008, 04:53 PM   #4703
is someone willing to explain the excel spreadsheet on rollout? no need for a huge technical explanation, but just a sentence about what is rollout, and what each row and column are in the spreadsheet. I know one of the is pinion and gear? but which ones are which. Thanks.
Old 04-29-2008, 05:06 PM   #4704
Regional Moderator
CarbonJoe's Avatar
For a given spur size, the left hand column is pinion size, the top row is tire diameter, and the rest of the data is the rollout.
See this post for an editable rollout Excel spreadsheet
BMI's DB12R
So, after entering your spur size, measure your tire diameter, go down that column until you find your desired rollout, and the go across to find the pinion you should use. The top chart is rollouts in mm, the bottom is rollouts in inches. Both tables have the tire diameter listed in mm and inches, so it doesn't matter what units someone else gives you the rollout in, you can easily find it.
Ask others at your local track what rollouts they are using, and you can gear your car the same regardless of your spur tooth count and tire size. All motors have an optimum rollout for a given track. Rollout, by definition, is the distance the car will travel for one revolution of the motor shaft. It takes into account the gear ratio (pinion / spur) and the tire diameter. As your tires wear, to maintain the same rollout, you should change the pinion.
Too low of a rollout, the motor will run cooler, but not be as fast on top end, but may accelerate faster. Too high of a rollout, the motor will run hot, top speed will be higher, but probably won't have as much punch in the infield.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 04-30-2008, 05:39 PM   #4705
awesome! thanks for the great info. Ill type in the titles, and ill be set, thanks.
Old 05-01-2008, 06:14 PM   #4706
MarkBrown's Avatar
I'm hoping to run my DB12R outdoors on low/medium grip asphalt (sealed, treated with grape soda) in a few weeks. I've only run the car indoors on carpet to this point. Should I start with the kit setup and double-pinks all around, or start somewhere else? Are the progressive springs a big improvement outdoors? What size progressive spring would you start with?
Are the kit kingpins the best thing to run with the progressive springs, or is there some longer kingpin that is better?
I see a lot of setups now expressed in terms of Sure Lube numbers (1, 2, 3, etc.) What's the translation to diff lube weights (5K, 10K, etc.)?
Thanks for helping,
--mark
MarkBrown is offline   Reply With Quote
Old 05-01-2008, 06:23 PM   #4707
MarkBrown's Avatar
BMI's DB12R
Sounds like a useful spreadsheet! I tried opening the zip file using the zip reader that's built into Vista and the system says that the zip file is corrupt. Is there some other program I can use on Vista that can decode this zip file?
Old 05-01-2008, 06:26 PM   #4708
protc3's Avatar
Hey mark,
The kit setup is a great starting point for asphalt. Start with that and you can fine tune it. Most guys seem to like that setup for asphalt.
The new front springs are a big improvement on any surface. They allow the front end to work more efficient. I like the .020 springs on asphalt. You can run these springs with the long kingpins or the ones you have. If you use your short kingpins, you will just need to remove 2 shims from the kingpin.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-02-2008, 01:13 AM   #4709
MarkBrown's Avatar
Originally Posted by protc3 View Post
You can run these springs with the long kingpins or the ones you have. ...
If you wanted to run long kingpins, where would you get them? Do you run 1/10th king pins in a 1/12th car? You mention a long IRS king pin -- what's the part number for that? Thanks!
Old 05-02-2008, 06:09 AM   #4710
protc3's Avatar
The long kingpins part # is DB2170. You can use the long or short kingpins with the new springs. The longer kingpins will offer more roll center adjustment.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
