Old 04-04-2008, 10:40 AM   #4546
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
Originally Posted by giantbill View Post
How does yours run Ferrari?
psh, mine doesnt run. i dont have batteries or a motor. Ive watched it at the track lately, and you can definitely tell the difference between it and the others. the difference is big with the CRC especially, to me atleast.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 04-08-2008, 04:33 AM   #4547
radio_car_racer's Avatar
quote on rcchat in the UK re static camber
the guy that posted made the B final
As a side note, I encountered the following;
On friday morning in Germany I had a quick look at Andy Moores car, and noticed that he had a different setting for static caster on each side of the front end. On one side he had the thick washer at the back and the thin one at the front of the caster block. However, it was the opposite on the other side. I asked him why, and he told me to measure the static castor at the kingpin, which I did, and it turned out to be the same on both sides. I checked mine, and had 1 degree on one side and over 5 degrees on the other!
The problem is caused by the upper wishbone turnbuckes - they are difficult to screw in perfectly straight, and this results in the top pivot ball moving forwards or backwards altering the static castor!
Instead of running different shims either side, I tweaked mine with a pair of beefy pliers, and it made the car miles more consistent, and got rid of the tweak I thought it had that I spent most of the day looking for!
does/can the above happen with the AE front end?
I'm of to check mine now
radio_car_racer is offline   Reply With Quote
Old 04-08-2008, 07:33 AM   #4548
protc3's Avatar
That is very true. I always check my castor reguardless of shim locations. I usually adjust the turnbuckle angle instead of offset the shims. This way i will know when something is bent or messed up. It can happen on any of the 1/12th front ends with the exception of the speedmerchant formula front end being that there is 2 upper turnbuckles to adjust the castor and camber.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-08-2008, 03:48 PM   #4549
I can't wait to race mine If all goes well it will be raced for the first time this weekend
Old 04-08-2008, 07:56 PM   #4550
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
Adrian, check your PM's
AChupp2 is offline   Reply With Quote
Old 04-08-2008, 10:44 PM   #4551
Xtant3150c's Avatar
Mine is ready to go Although my driving is a totally different story
Xtant3150c is offline   Reply With Quote
Old 04-09-2008, 03:16 AM   #4552
protc3's Avatar
Have fun this weekend guys.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-10-2008, 09:46 AM   #4553
Been reading most of the 12th scale threads, and decided to get the DB12R but it's not for sale in www.bmiracing.com
When will the kit be back in stock? Someone told me this kit would be best in asphalt...any comments? How about the 12L4 or the upcoming 12R5 and the Gen-X? Not trying to sabotage your thread just want opinions.
T-Bar or Link is best for asphalt?
Any help is greatly appreciated. Thanks!
RC12 is offline   Reply With Quote
Old 04-10-2008, 10:10 AM   #4554
Regional Moderator
CarbonJoe's Avatar
Did you try the Online Store link on the left hand side of the main page? Then choose "Cars" under Categories in the upper left hand side. The DB12R is shown to be in stock.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 04-10-2008, 10:23 AM   #4555
protc3's Avatar
The car was pulled from the site because we are temporarily out of stock. We will have them back on there shortly. Stormer hobbies has our cars in stock along with a variety of spares.
Our car was designed to work on any surface. The suspension gives you the benefits from both a link car and a T bar car without the tweaking you usually get after tapping a board. We made sure that this car would be extremely durable as well as offering the best performance available. The pod fits brushless motors with ease and without going back to the old 3 bolt style pod. This makes our pod much more resistant to damage. If you would like any more info please feel free to ask.
I really think you enjoy running 1/12th cars buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-10-2008, 10:28 AM   #4556
Whoops! Didn't check today...did yesterday and its not there
Thanks for the info Joe!
Old 04-10-2008, 04:44 PM   #4557
AdrianM's Avatar
T-bar cars are good on asphalt. They are good on carpet too with some tuning.
Link cars like the RC12L5 and CRC Gen-X are good on carpet but are not so good on asphalt.
The DB12R is good everywhere. It is a blend of link and t-bar cars taking the best of both and putting it all together in one package.
Adrian Martinez
Old 04-10-2008, 06:34 PM   #4558
RCSteve93's Avatar
Not only that but it is tweak free and insanely durable. You will replace parts because of wear... not because they broke. That is one of my favorite things about this car.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 04-10-2008, 06:54 PM   #4559
Did IRS change their plastic a bit? The IRS lower arms that came with my BMI seem a lot less prone to stripping out then the ones I have bought for my previous car.
Old 04-10-2008, 08:01 PM   #4560
protc3's Avatar
Thats great to hear buddy. We really did spend alot of time developing the car. Im glad it has paid off.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
