Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-31-2008, 07:03 PM   #4516
protc3's Avatar
Originally Posted by Chemical X View Post
It's been done. Check out Brian Bodine's new Slapmaster which has 1/4" x 1/2" bearings.
http://www.rctech.net/forum/attachme...1&d=1204054112
He discusses it on post # 366 here. 12th scale gallery (Post your pics... body on and body off)
I did look into it and found that we lost alot of ride height adjustment.
Jason Breiner
BMI Racing
www.bmiracing.com
Copperhead 12 and Copperhead 10 coming soon!!!
protc3 is offline   Reply With Quote
Old 03-31-2008, 07:30 PM   #4517
aca
Thanks for the reply Adrian! Another question, is the 13mm rotor too much for 1/12 scale?
Allen
aca is offline   Reply With Quote
Old 03-31-2008, 10:14 PM   #4518
EricF's Avatar
from what I've read about the 13mm rotor it would seem that it's not the best way to go for 1/12. It increases the cogging effect of the motor and also lowers the rpm and increasing the torque. But with that said... the real way to see what it does for you is test it on the clock and see.
E
EricF is offline   Reply With Quote
Old 04-01-2008, 01:18 AM   #4519
radio_car_racer's Avatar
Originally Posted by protc3 View Post
Hey Guys,
The front springs are complete and will start shipping on monday. I tried them on 2 styles of kingpins. I tried them on the stock kingpins and on IRS long 1/12th kingpins. The IRS kingpins give you more roll center adjustment than the stock ones but both work fine. You will just need to remove 2 shims from the top of the stock kingpins and you are set.I will be selling the springs as a kit with all 3 pairs and 1 set of retainers. I will also be offering the kit with the IRS kingpins if desired. They fit great and are preset so they will not collapse on you.
You don't say which Monday
can't find them in the store
radio_car_racer is offline   Reply With Quote
Old 04-01-2008, 01:21 AM   #4520
Allen
E
post by Marcus Mobers on UK forum says,
First of all, Brushless is very very different from brushed motors. Usually with brushed motors when you gear lower you have more punch, less top speed, when gearing up, less punch, more topspeed.
This is not the case with Brushless...if your gear ratio is too low, you have zero punch and topspeed, same when it is too high, so its very important to find the right gear ratio.
Also, Brushless takes a lot of energy on fast open tracks, sometimes you will even have problems dumping on that kind of tracks. On small tiny technical tracks runtime is sure no issue.
I experienced that the 14mm bonded rotors are not good, simply no punch and the efficiency is bad. Daniel is right, when he says that a 14mm sintered rotor is more efficient, sure it is, and it has crazy torque. But one big disadvantage because of the strong magnet field is the braking effect off throttle. When you wanna gain runtime use that rotor with taking off all the automatic brake on your speedo.
I also tried the new LRP 12.5 and 13.0 sintered rotors. Very very good solution for 12scale. Its more driveable due to less torque and it rolls better off throttle. Ok, it has less runtime than a 14mm rotor......
With a 12.5 and 13.0 set your LRP/Nosram speedo on automatic brake program 1.
I usually run a 4.5 LRP motor...here are some good points to start with:
small tracks:
12.5 rotor = 28,00mm
13.0 rotor = 29,00mm
14.0 rotor = 30,00mm
big tracks:
12.5 rotor = 32,00mm
13.0 rotor = 33,00mm
14.0 rotos = 34,00mm
Hope this helps a little....try to find the rotor that fits to your driving style and have fun!
Markus
Old 04-01-2008, 03:09 AM   #4521
protc3's Avatar
I will get them up there today. I was real busy yesterday and it slipped my mind.
Jason Breiner
BMI Racing
www.bmiracing.com
Old 04-01-2008, 10:05 AM   #4522
Chemical X's Avatar
Any update on the rear pod droop adjuster?
Tom Camou
Team R/C Plus
Rose City Scale Racing
Chemical X is offline   Reply With Quote
Old 04-01-2008, 11:30 AM   #4523
protc3's Avatar
Website is updated with new front springs.
I will try to get back on the pod droop adjuster. We have been very busy and havent had a chance to complete it.
The super low rear pods are in production now. They are 2mm lower than the stock pod plates.
Hope i didnt miss anyone
Jason Breiner
BMI Racing
www.bmiracing.com
Old 04-01-2008, 11:40 AM   #4524
AdrianM's Avatar
Default BMI New Large OD Linear Springs are on line now!
BMI New Large OD Linear Springs are online now!
There new springs balance the front and rear roll rates in pan car chassis. They make the front roll more. This increases steering, corner speed and promotes more even tire wear.
They fill all 1/10th cars and 1/12th cars with 1/10th (or long IRS 1/12th) king pins. In 1/12th cars they must be used with modern large diameter rims like Jaco Prism's and Parma Pro 38's. You can use them with 1/12th king pins id you remove 2 shims above the upper pivot ball. This will slightly preload the springs and reduce droop range adjustment available but its good on most surfaces.
DB2100 .020" Linear Springs and perches (pair).
DB2101 .022" Linear Springs and perches (pair).
DB2102 .024" Linear Springs and perches (pair).
Note that BMI .020's feel close to AE .018's, BMI .022" are like AE .020 and so on...but they the BMI springs are smoother and maintain the same rate throughout their travel.
Adrian Martinez
BMI Racing
bmiracing.com
DB12R NOW AVAILABLE!!
Old 04-01-2008, 03:18 PM   #4525
Yay my DB12R is here!!!!! Can't wait to get home from the office and start building it
Old 04-01-2008, 04:42 PM   #4526
xtrememadness's Avatar
Send a message via AIM to xtrememadness
very nice
CRAIG SANTRY / TEAM ASSOCIATED / BMI RACING / SPEEDZONE USA / 360 RC SPEEDWAY / LONG ISLAND RACEWAY / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / TEAM ORION / TEAM UPGRADE / FUTABA / LRP / TEKIN / PROLINE RACING / JACKSON RC / HORSHAM RC / SWEEP RACING USA
xtrememadness is offline   Reply With Quote
Old 04-01-2008, 04:57 PM   #4527
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
Originally Posted by hanulec View Post
use the two screws towards the back of the chassis
thanks man
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 04-02-2008, 03:18 AM   #4528
Do you know if they'll fit inside the GRP rim?
ID is 1.32" / 33.65mm
Old 04-02-2008, 05:52 AM   #4529
Scottrik's Avatar
Trader Rating: 172 (100%+)
Note that in Adrian's announcement it says they must be used with modern large dia wheels. The GRP's are older style small dia rims and won't be appropriate.
Power corrupts.....PowerPoint corrupts absolutely
President, Magic City RC...see us at http://www.magiccityrc.com
Proud member of ROAR # 11-10690
Scottrik is offline   Reply With Quote
Old 04-02-2008, 09:20 AM   #4530
protc3's Avatar
the new springs work with standard 1/12th kingpins also. You just need to remove 2 of the kingpin shims.
Jason Breiner
BMI Racing
www.bmiracing.com
Forum Jump
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
