Old 03-30-2008, 03:07 AM   #4501
protc3's Avatar
Originally Posted by radio_car_racer View Post
I need to improve my BMI
Jason, what I'm looking for and probably a lot of others is a simple rear ride height adjuster that doesn't require the need to use the current ride height adjusters. Serpent have a cam adjustment in the rear pod on their new car I believe.
What can you come up with????
I havent really thought about it because the existing setup has always been very good and solid. The serpent car has a few things that are a little different but as burt stated, a cam does slightle change wheelbase and also if there is a locator pin,which without a clamp there needs to be, you will need to still remove the axle otherwise it will slip. I can look further into the matter and see if i can come up with something but like i said, i never really thought about it until this point. Thanks for the input on the matter. I always need to know what customers are looking for so i can always improve.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-30-2008, 07:26 AM   #4502
radio_car_racer's Avatar
Originally Posted by protc3 View Post
I can look further into the matter and see if i can come up with something but like i said, i never really prove.
Jason, you have a sketch in your email. Hope it sets you thinking more on this idea
radio_car_racer is offline   Reply With Quote
Old 03-30-2008, 10:19 AM   #4503
Originally Posted by InspGadgt View Post
You really can't get much simpler design wise then the current ride height adapters.
But it can be improved and that's what Jason likes to do
Old 03-30-2008, 12:02 PM   #4504
redlion's Avatar
Thanks for all the support Jason. The car was good started fourth and finished fourth in the A had some bad luck at our local club race.
Wes
redlion is offline   Reply With Quote
Old 03-30-2008, 03:40 PM   #4505
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
hey guys how should i mount the ball studs on the servo saver for the angled position?is it better to have it in the front, or back?
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 03-30-2008, 04:10 PM   #4506
RCSteve93's Avatar
Hey Jason,
My DB12R was running great today. I managed to win the "B" with it. I really like this car because of the durability, which keeps me on the track more. Which has really helped me get better after my 8 week hiatus from RC. My best lap time has dropped by .3 seconds every week. With my other 12th by another manufacturer, I was always having tweak issues and parts popping out and breaking because of the smallest hits. Thanks Jason and keep up the good work.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 03-30-2008, 05:07 PM   #4507
aca
Anybody, I've just installed my SpeedPassion GT and Novak 10.5 (with 13mm rotor) in my DB12R and I'm looking for suggestions on what a good starting point to set the GT and a good rollout number. I'm running on an asphalt track, (the Bass Pro Shop parking lot in the Jackson-Pearl, Miss. area) It's a 160 - 180 x 80 - 90 foot track, not bad on traction when the VHT is sprayed down.
Thanks for any help!
aca is offline   Reply With Quote
Old 03-30-2008, 05:15 PM   #4508
Chemical X's Avatar
Trader Rating: 16 (100%+)
Hi Jason,
Since you asked...
I would really like it if you could make a rear ride-height adjuster set that accomodates 1/2" flanged bearings instead of the standard 3/8" size.
I'm also curious to see your rear pod droop adjuster gadget you referenced a few weeks ago.
Thanks,
Tom
Chemical X is offline   Reply With Quote
Old 03-30-2008, 09:27 PM   #4509
Trader Rating: 14 (100%+)
Originally Posted by Chemical X View Post
Hi Jason,
Since you asked...
Thanks,
Tom
I think Jason already looked into this earlier. If i remember correctly, it would require the redesign of the rear pod plates.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 03-30-2008, 09:28 PM   #4510
Also, after thinking about it on my way home, i have made my decision on the lowered pod plates. The car will continue to come with the standard pod plates and i will offer the super low ones as an option. I need to keep to an industry standard for the kit but i can do it with no problems as an aftermarket part.
super low pod plates
when will these be available?
Old 03-30-2008, 10:24 PM   #4511
Chemical X's Avatar
It's been done. Check out Brian Bodine's new Slapmaster which has 1/4" x 1/2" bearings.
http://www.rctech.net/forum/attachme...1&d=1204054112
He discusses it on post # 366 here. 12th scale gallery (Post your pics... body on and body off)
Old 03-31-2008, 04:13 PM   #4512
nobody?
Old 03-31-2008, 04:32 PM   #4513
xtrememadness's Avatar
Send a message via AIM to xtrememadness
in front buddy
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 03-31-2008, 04:34 PM   #4514
hanulec's Avatar
Trader Rating: 23 (100%+)
nobody?
use the two screws towards the back of the chassis
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-31-2008, 05:44 PM   #4515
AdrianM's Avatar
We run ~70mm roll out with an SP GT and 10.5 in a DB12R on tracks that size. Use all the default GT settings.
Adrian Martinez
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
