Old 03-09-2008, 04:08 PM   #4306
protc3's Avatar
Thats great to hear buddy. Thats what we were looking for. 1/12th cars have always been so fragile and people were not interested in running them for that reason. We wanted to show people it isnt always the case.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-09-2008, 07:33 PM   #4307
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Well, after hearing that I am sold. I now just need to find the finances to get that car.
CarlosG. is offline   Reply With Quote
Old 03-09-2008, 08:27 PM   #4308
protc3's Avatar
Thats cool bro.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-09-2008, 08:29 PM   #4309
Fastforward's Avatar
what are the recommended bodies for the DB12R on Carpet? Stock or 17.5 motor.
Fastforward is offline   Reply With Quote
Old 03-09-2008, 08:36 PM   #4310
I ask it once for another chassis in the 12th forum: Parma Speed 8 or Protoform Speed 12
Answered by RCSteve93, I guess
Parma Speed 8* - Best for stock and 19 turn, low drag and medium downforce, very stable
Parma Speed 8 HD* - Best for mod, high downforce and medium drag, very stable and planted
Protoform Speed 12* - Best for mod, medium stability, high downforce and a little less drag than Speed 8 HD
Protoform Speed 12b* - Best for stock and 19 turn, Medium stability, good downforce and very low drag.
*Light wieght version uses thinner lexan.
PS: can't get a link to the answer, sorry!
Arn0 is offline   Reply With Quote
Old 03-09-2008, 08:48 PM   #4311
I understand that the Parma speed 8 and Protoform Speed 12 are the bodies of choice in 12th scale. My question is are there any interfearance problems with the DB12R chassis that I should be aware of with either one of these bodies.
Answered by Scottrik, I guess
Old 03-09-2008, 09:14 PM   #4312
ChestyV32's Avatar
Trader Rating: 32 (100%+)
just your battery bars on both
and maybe your topdeck depending on if you slam the speed 8 to low
just what ive found to happen, i usually heat up the spot on the body and push it up but thats just how i fix it
cheston
SXT Tire Additive
www.SuperiorHobbies.com
ChestyV32 is offline   Reply With Quote
Old 03-10-2008, 12:14 AM   #4313
Uga
Uga's Avatar
Now that's a beer from Jason together with my next order for attracting a customer!
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 03-10-2008, 09:22 AM   #4314
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
i find the parma a little nicer looking, and a bit cleaner. It has very little drag, but less downforce.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 03-10-2008, 12:10 PM   #4315
tdu verney's Avatar
Parma = Asphalt
Proto = Carpet
tdu verney is offline   Reply With Quote
Old 03-10-2008, 01:42 PM   #4316
GreaseMonkey's Avatar
I just switched from the Protoform Speed 12 to the Parma Speed 8 and picked up a crap load of steering. I won't be going back to the protoform any time soon. This is on carpet.
Speaking of which, our local track here in Ottawa had it's big race this past weekend and despite being hit with over 40cm of snow we had about 70 entries. Using the DB12R I managed 3rd in stock 12th and 1st in 19 turn 12th. I'm the first to admit I got a little lucky but you have to be good to be lucky right?
I got a little sick of rushing around switch motors and tyres between heats so I picked up a BMI 12 for a second car.
That reminds me, Jason expect a PM in a few minutes.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 03-10-2008, 02:59 PM   #4317
AdrianM's Avatar
The DB10R is on www.bmiracing.com front page with a link to the Redrc.com press release.
We are really close to turning it loose guys...we just need a few final parts to come in.
Adrian Martinez
Old 03-10-2008, 06:56 PM   #4318
hanulec's Avatar
Trader Rating: 23 (100%+)
GreaseMonkey - two cars are the way to go. what is the carpet like at your local track? 70 entries is great! it sounds like your pretty hooked up. what set-up did you run on your car?
At 360 RC Speedway's "The Gaunlet" race yesterday I ran 1/12th Stock and 19T. I really feel that tires are the key to getting this car set-up. I was a Purple Front/Grey Rear guy but I think the car responds better to equal front/rear tire hardness combos or softer front than rear. I tried two different set-up directions yesterday (I ran the same Parma Speed 8 body on both cars):
#1 - Had tons of steering that I needed to put a 50% delay into my radio. Ran this setup in Stock but proved it works well in 13.5T during practice.
Front: Jaco Magenta ; Paragon on innner 1/2 ; .018 springs ; 4deg caster; -1deg camber; 10K silicone in lower pivot ball ; Angled servo
Rear: Jaco Magenta ; Paragon full ; Thin hockey sticks w/ tweak screws touching ; 40WT ; Wind Tunnel 15# "V" Hive VCS Spring; Long ball stud ; Wind Tunnel #3 Green Shur Lube
#2 - Had a power-on push, and was carying less corner speed than #1. Ran this setup in 19T - and performed my fastest lap/run of the weekend w/o my damper tubes connected (forgot to reattach after checking tweak).
Front: Jaco Lilac ; Paragon on innner 1/2 ; .018 springs ; 6deg caster; -1deg camber; 10K silicone in lower pivot ball ; flat servo ; medium ball studs
Rear: Jaco Grey ; Paragon full ; Thin hockey sticks w/ tweak screws touching ; 40WT ; Wind Tunnel 15# "V" Hive VCS Spring; Long ball stud; Wind Tunnel #4 Red Shur Lube
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-10-2008, 06:58 PM   #4319
hanulec's Avatar
Jason - By the way, Bruce Carbone of Speed Merchant was a 360 on Sunday. I spoke to him about the Formula Front End. Thank you for follow-up up with him on the DB12R's front dimensions. He said that after the Carpet Nationals he would look to fab up the proper top plate.
Old 03-10-2008, 07:19 PM   #4320
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey mike i forbid you to put speed merchant parts on your bmi!!!! only irs parts are allowed!! hey had a great time racing with ya bro. cant believe i squeaked it in the a main must of been my bmi t-shirt when i wear the shirt i become one with my car my car was fast and smooth all day and i have never been happier with the car
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
