Old 03-05-2008, 03:58 AM   #4276
[url=http://www.propertydir.com]Property Directory[/url]|[url=http://www.wholesalebilliardcues.com]Wholesale Billiards[/url]|[url=http://www.battery4sale.com]Wholesale Batteries[/url]|[url=http://www.somethingdirectory.com]Something Directory [/url]
Hataish is offline   Reply With Quote
Old 03-05-2008, 06:37 AM   #4277
oze
Jason - when will the new springs be available in your webshop? Do you have a distributor in Europe or shall I order direct?
oze is offline   Reply With Quote
Old 03-05-2008, 07:36 AM   #4278
protc3's Avatar
I will have the springs ready by the end of this month. I do not have many distributors at this time overseas. I will have them on the webstore immediatley following the completion.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-05-2008, 09:51 AM   #4279
Originally Posted by protc3 View Post
No problem buddy. This is why i decided to go with rear flextures in place of coil springs for my rear suspension. Little by little we are figuring out the small little details that give the car a great balnce of front and rear spring tension that works efficiently as possible.
BTW,any luck on your project you were working on?
I've got a lot of it planned out in my head...just haven't drawn it up in Solid Works yet. Just went through a large office relocation at work so I've been rather tired when I get home and haven't worked on it. The new web site is nearly finished now though
Old 03-05-2008, 10:17 AM   #4280
protc3's Avatar
cool. i know alot about long work days.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-05-2008, 05:37 PM   #4281
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
what should i run, servo flat or angled? whats the difference, flat is more agressive right?
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 03-05-2008, 06:00 PM   #4282
theisgroup's Avatar
most are running with the server angled. angled get you more ackerman, so I guess that is more agressive. usually on carpet you would run it flat to calm the car down. but shef's setup for snowbirds is on an angle as well.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-05-2008, 06:06 PM   #4283
hanulec's Avatar
Trader Rating: 27 (100%+)
depending upon what servo you run your choices are limited too. w/ the BMI servo mounts and the Futaba 9650 the wiring harness hits the mount when mounting flat (so i just double stick it). if you decide to use a JR micro 3650 then the BMI servo drill patterns won't match up either.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-05-2008, 06:23 PM   #4284
xtrememadness's Avatar
Send a message via AIM to xtrememadness
ko 949 fits beautifully as is one of the best servos. the futaba has plastic gears and breaks very easily
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 03-05-2008, 08:13 PM   #4285
protc3's Avatar
This is a tricky question to answer. If the servo is mounted correctly in both applications, a flat servo will calm the car down. When i mount the servo flat i use the medium ball studs on the steering blocks to make the turnbuckles level when looking at the car from the front and i place the servo so when looking at it from the top, the turnbuckles are dead straight. This adds a slight bit of bump toe in to calm the car down on corner entry and with the turbuckles being straight when looking from the top,eliminates most all of the ackerman to keep it smooth throughout the corner.
Angled servo will eliminate all bumpsteer for more aggressive turn in and also has a little more ackerman which will give more on power steering. I like the car to be a bit more mellow on carpet due to the high bite. It allows me to keep my corner speed without needing to think too hard. In the hands of a real good driver like schreffler, the angled servo is the way to go. The flat servo will feel more smooth and easier to drive for the average guy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-06-2008, 12:13 PM   #4286
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
With the servo mounted flat which holes do you use on the servo saver?
AChupp2 is offline   Reply With Quote
Old 03-06-2008, 12:16 PM   #4287
protc3's Avatar
Middle holes on the servo saver and use medium ball studs on the steering blocks
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-06-2008, 01:29 PM   #4288
act2007's Avatar
Trader Rating: 46 (100%+)
Thumbs up
Jason, do you have any dealer here in Jersey or you're just
an online store? I'm thinking of going into 1/12 scale and so far
I've looked at the CRC Gen-X here locally. I would be interested
in your car as well, hoping to see one at a hobby shop here.
B.T.W., your car DB12R is a really cool name.
It reminds me of the Aston Martin DB12 Vanquish!
act2007 is offline   Reply With Quote
Old 03-06-2008, 01:34 PM   #4289
protc3's Avatar
I do have some hobby stores up that way carrying our products. Im sure someone else local to the area can help you. I know 360 raceway on long island,NYC hobbies,and brownies hobbies carry our products but i cant remember who in jersey.
Thanks for the props on the name. It is actually named after my favorite motorycle i have ever had. A Bimota db9. The Aston Martin db12 is also worth naming after.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-06-2008, 03:58 PM   #4290
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
I have one brand new in the box, if you are looking for one. I live in upstate NY.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
