Old 03-02-2008, 09:14 PM   #4246
protc3's Avatar
Cool. I should have the new spring done shortly. I will be making them in .018,.020 and .022. I ran the .020 today. We ran 19 turn,the bite was high and the track was sweeping. The car has not one scratch on the bottom. It just never touched down.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-02-2008, 09:19 PM   #4247
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Originally Posted by protc3 View Post
Hey dude,
Im not going to make it.
Bummer, I was hoping to finally meet the almghty Jason, the creator of the elusive DB12R.
CarlosG. is offline   Reply With Quote
Old 03-02-2008, 09:28 PM   #4248
Kropy's Avatar
Send a message via AIM to Kropy
He's nothing to write home about........LOL J/K He's a hell of a guy
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 03-03-2008, 05:26 AM   #4249
hanulec's Avatar
Trader Rating: 23 (100%+)
Jason - I'll take three (or more - lots of db12r at 360) sets of all of your spring flavors. how/when can we get our hands on them? if was act now can we have them at the track this upcoming weekend?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-03-2008, 07:56 AM   #4250
theisgroup's Avatar
put me down for the same.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-03-2008, 08:26 AM   #4251
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jason ygpm Bro,
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 03-03-2008, 09:08 AM   #4252
Originally Posted by Matt Howard View Post
I gotta say I'm loving my DB12 more and more every time I run it I'm running a copper center spring, 7000wt in the tubes, 5000 on the kingpins, batteries in the middle, flat servo, and a Jaco Lilac/yellow tire combo. This is for a 17.5 motor. If anyone is coming to the carpet nats make sure to look me up, I practically live there
Matt - How do you have your electronics laid out in you car? I finished building mine this weekend but with the speedo on the left the car is way out of balance. I am going to switch it to the right side tonight.
Thanks, Lee
LeeS is offline   Reply With Quote
Old 03-03-2008, 09:11 AM   #4253
Matt Howard's Avatar
Thanks, Lee
I have it on the left but I'm using 16g wire, I also routed the big esc cap to the right side, so it's next to the receiver. I also removed the heatsink and fan from my Losi esc to take off some more weight
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-03-2008, 11:49 AM   #4254
tdu verney's Avatar
Default NEW SPRINGS
Jason I just placed an order. If springs are good to go add one set of each new spring set.
tdu verney is offline   Reply With Quote
Old 03-03-2008, 03:41 PM   #4255
What makes the springs different from standard springs we use on the AE front end? Are they progressive?
Old 03-03-2008, 05:14 PM   #4256
protc3's Avatar
The springs will be ready at the end of the month. In order to make them so i can do them cheap, i need to do a large volume of them.
The front springs are much more linear than the AE springs. The front ends on these cars are extremely light and the progressive front AE springs do not allow the front end to roll. This makes the rear do all of the rolling which makes it harder for the car to stay flat. These new springs open a huge window for setup on these cars.
The other downfall of the stock AE springs is what you all know already, They collapse because the wire is under too much stress. The small diameter,coarse pitch spring breaks down the spring wire extremely fast making the front spring life extremely short. With my new spring kit, You may only have to replace them once a year if you use them alot.
I will be selling them as a kit. I made a mistake on wire size before. I used .022 for my testing this weekend. I will be making .020,.022,and .024 sized springs. The .018 with my new design becomes too soft.
Hope this helps.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-03-2008, 06:05 PM   #4257
tdu verney's Avatar
"He ran .070" standard flex plates and no set screws in the flex plates."
Ok thanks. Reading back it sounds like the .70 flex plate offers more grip on asphalt?? If so then the thiner .60+ flex plate w/adj screw is a carpet solution? Or is just what ever works on any surface?
Old 03-03-2008, 06:22 PM   #4258
protc3's Avatar
The set screws in the thin flex plates make the car soft off center but the spring tension ramps up and makes the car dig harder mid corner. It seems to work well on carpet. On asphalt we like the standard plates with a more linear spring rate so we leave the set screws out. It gives good rear bit and front bite balance.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-03-2008, 06:25 PM   #4259
tdu verney's Avatar
Jason as always good information thanks!
Old 03-03-2008, 06:26 PM   #4260
protc3's Avatar
Not a problem buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
