Old 02-02-2008, 11:05 AM   #3976
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
ohh, sorry i thought of 3/8 instead of 5/8. 1/2'' is too big right? I was thinking that if you got the 1/2, it would be fine, since it wouldjust come out of the arms further? I dont like the phillips thing, and would want to keep it all standard. I cant find some anodized aluminum screws to put in instead.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 02-02-2008, 12:20 PM   #3977
Scottrik's Avatar
Trader Rating: 243 (100%+)
No need to appologize. I just looked up your profile...you're at an age where fractions should be reasonably fresh for you so let's do a little refresher practice. How many eighths is 1/2? If 5/8 is "just right" (size of BMI aluminum replacement screw...and for full-engagement w/new tires mounted) you tell me if 1/2 is too big, too small, or just right.
See...that darn math stuff DOES come in handy Wait'll you get to roll-out!!
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-02-2008, 12:22 PM   #3978
Ffejdat's Avatar
ferrarrimk13- If you are having trouble with the stock steel screws stripping in the kit, you are going to have MORE stripping screws problem with aluminum or ti screws... If you are stripping the stock steel screws, you need new wrenches, or the proper size ones... The weight savings of a n aluminum screw set for most 12th cars is VERY smalll, but the reliability factor of steel screws is much better, especially if you are just staring out in 12th...
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 02-02-2008, 12:27 PM   #3979
Scottrik's Avatar
An excellent point!! I weighed my aluminum replacement screws against the full steel set from my DB12R (excluding the 8-32 front arm mounting screws) and the difference was about 15g...a shade over 1/2 ounce. I wholeheartedly agree that for that minor difference someone starting their 1/12 adventure will be MUCH better off staying with the steel screws for the added reliability. Trying to save a little weight now will likely result in BIG weight savings (large assemblies falling off your chassis) right when you don't want them--during a heat.
Old 02-02-2008, 12:34 PM   #3980
thanks guys. Maths not the problem, lol, but since the screws that are holding the front suspension are coming out of the lower arm, shouldnt added length just continue to protrude further? i have no problem with the stock screws, but i just noticed that they were a bit on the heavy side (the 5/8 screws) and thought i should look around. I want to get it right the first time, with all the parts, so later on, i wont have to pay for it on the track. Thanks for the help though.
Old 02-02-2008, 01:27 PM   #3981
well done to Randy Castor for making the show in 19t at the birds
jimmy..maddison is offline   Reply With Quote
Old 02-02-2008, 02:22 PM   #3982
AdrianM's Avatar
Jason Schreffler is 3rd in Stock with his DB12R and Paul Wynn and Leon McIntosh are in the B's of Mod and 19T respectively.
Adrian Martinez
Old 02-02-2008, 03:36 PM   #3983
hanulec's Avatar
Trader Rating: 25 (100%+)
once the bird is over I'd like to see their setups. I've still been hunting for the best rear damper tube/battery/shock oil/spring setup for carpet. I think my personal testing has been confused by running 19T and 13.5 too.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-02-2008, 10:21 PM   #3984
We still need stiffer flex plates...
Steve Dunn
sdunnmcp is offline   Reply With Quote
Old 02-02-2008, 10:56 PM   #3985
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
J, or Adrian
What tires does the DB10R use?
Id like to have a 10R for some practice fun on the weekends, sounds like the car is simple, and drives really nice Which is what I want, I just want to drive the car, not work on it the whole time
It would be really fun to motor some gas cars down the back straight
No 12th for me, I never made it would to the carpet track, we will see if the 12th scale runs on the asphalt this year, I may still buy one
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-03-2008, 07:06 AM   #3986
im guessing the DB10R should be out in a few months, so if you could wait until then, it might be a fun car to play around with, especially if thers a class for it. If not, then you can just drive it on the track, not under the clock, i gues.s
Old 02-03-2008, 09:13 AM   #3987
I honestly dont think there will be a class, It just sounds like something I would want, buy a practice card so you can practice the whole month for 30 bucks.... And just go out and run the car
A class for it would be awesome, but I just dont think it will happen
Old 02-03-2008, 09:25 AM   #3988
AdrianM's Avatar
It looks like there will be a class and it will be a big deal.
Adrian Martinez
Old 02-03-2008, 09:26 AM   #3989
adrian you have pm
Old 02-03-2008, 09:28 AM   #3990
AdrianM's Avatar
Congrats to Jason Schreffler for a 2nd in the Stock A at the Snowbirds with his DB12R!
Adrian Martinez
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
